'Index was outside the bounds of the array' exception inside MapSuite
When I zoom in on my map with one feature layer I now get
Application_Error got called.
Within this Server.GetLastError().InnerException gives
{"Index was outside the bounds of the array."}
[System.IndexOutOfRangeException]: {"Index was outside the bounds of the array."}
Data: {System.Collections.ListDictionaryInternal}
HelpLink: null
InnerException: null
Message: "Index was outside the bounds of the array."
Source: "WebEdition"
StackTrace: " at ThinkGeo.MapSuite.WebEdition.Map.xd8262f22d29c57d5(String[] x2ad333ebea325bde)\r\n at ThinkGeo.MapSuite.WebEdition.Map.x57b61acc3e039aed(String x96adbb16060a076f, NameValueCollection x13e9d0e2d3dc9cb2)\r\n at System.Web.UI.Page.ProcessPostData(NameValueCollection postData, Boolean fBeforeLoad)\r\n at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)"
TargetSite: {Void xd8262f22d29c57d5(System.String[])}
(Version 3.1.16)
It seems to be related to the tooltip hover. If I set a breakpoint insode the tooltip hover client javascript code
var beginToolTipsRequestDelegate = function(sender){return function(){
When I step out of the last curly brace I get the  unhandled exception.
When I step into your code of which the
var listeners=this.listeners[type];if(listeners!=null){for(var i=0,len=listeners.length;i<len;i++){if(listeners.obj==obj&&listeners.func==func){listeners.splice(i,1);break;}}}},remove:function(type){if(this.listeners[type]!=null){this.listeners[type]=[];}},triggerEvent:function(type,evt){if(evt==null){evt={};} evt.object=this.object;evt.element=this.element;if(!evt.type){evt.type=type;} var listeners=(this.listeners[type])?this.listeners[type].slice():null;if((listeners!=null)&&(listeners.length>0)){var continueChain;for(var i=0,len=listeners.length;i<len;i++){var callback=listeners;continueChain=callback.func.apply(callback.obj,[evt]);if((continueChain!=undefined)&&(continueChain==false)){break;}} if  (!this.fallThrough){OpenLayers.Event.stop(evt,true);}}
 It fails if I step in on that marked in bold
Matt
beginToolTipsRequest.apply(sender, arguments);
Matthew,
It is a known issue exists in 3.1.16 if you are using callback communicating with the server. Please have a look at the similar post here for the replies.
gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/12/aft/5353/afv/topic/afpgj/1/Default.aspx#6763c
