InMemoryLayer doesn't show object
I am properbly missing something v.small
please look at the following code:
DataManager dataManager = new DataManager(
                new QueryRequest(
                    new QueryActionStatement(
                        "SELECT","DataNode")));
            dataManager.Execute();
            var results = dataManager.GetResult() as Feature[];
            //foreach (var feature in results)
            //    map.EditOverlay.Features.Add(feature);
            InMemoryFeatureLayer featureLayer = new InMemoryFeatureLayer();
                featureLayer.InternalFeatures.Add(feature);
            featureLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
            featureLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle = LineStyles.InternationalBorder2;
            featureLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country2;
            LayerOverlay staticLayer = new LayerOverlay();
            staticLayer.Layers.Add(featureLayer);
            map.CustomOverlays.Add(staticLayer);
DataManager is a class I made which fetch me data from mssql server with features , now , when i run the following script , i dont see anything on the map , but if I am uncommeting the
lines , i see the objects v.clearly
p.s all the fetched features are lines
Add this code after this  staticLayer creation.
staticLayer.IsBaseOverlay = false;
Best of luck
Raja.
still the same
Arik,
The EditOverlay is a special Overlay that is used to edit the features and just take effect when the map is in editing mode. In other words, the features in EditOverlay don’t display when the map is in normal mode. Normally, the EditOverlay always have the highest Z-Index, but it seems thtat it's strange about making the InMemoryOverlay invisible.  I did a simple test but it works fine. Could you have a check on your machine and give some changes based on your scenarios?
DataProviders.zip (2.3 KB)
