hi i am trying to add mouseover popup i did done with mouseover marker mouseover marker display fine but issue is with data because data is only display last record in popup i am using foreach loop my code is.
foreach (var ans in allAnswers)
if (ans.strAnswer != “0.0,0.0”)
string Lat = ans.strAnswer.Split(’,’)[0].ToString();
string Long = ans.strAnswer.Split(’,’)[1].ToString();
var basicInfo = from q in db.tblAnswers
where q.nQuestionnnaireId == ans.nQuestionnnaireId
select q;
if (query.strAnswer == “19302”)
StringBuilder contentHtml = new StringBuilder();
myFeature =
new Feature(Convert.ToDouble(Long),
Convert.ToDouble(Lat));
myData.EditTools.Add(myFeature);
string ImageUrl = string.Empty;
ImageUrl = “/ftp/pictures/” + picture.strAnswer;
// contentHtml.Append(“Picture”)
contentHtml.Append("")
.Append("
.Append(“Date: “)
.Append(”” + Date.strAnswer + “”);
markerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.WebImage =
new WebImage("/a.png", 30, 30);
markerOverlay.FeatureSource.InternalFeatures.Add(myFeature);
//markerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup=new CustomPopup(contentHtml.ToString());
markerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.ContentHtml = contentHtml.ToString();
markerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.Width = 250;
markerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.Height = 290;
markerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.IsVisible = false;
markerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.AutoPan = true;
markerOverlay.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
problem is with contentHtml its only show last record of my loop. what can i do to achieve all contentHtml record according to myfeature.
Hi Raja,
It looks you create duplication post, I will reply you in another post.
thinkgeo.com/forums/MapSuite/tabid/143/aft/12828/Default.aspx
