Install MapSuite 2.0 and 3.0 into GAC
Is it possible to install the MapSuite assemblies (DesktopEdition.dll and MapSuiteCore.dll) into GAC ?
When I try :
gacutil -i  DesktopEdition.dll
I get  :
Microsoft (R) .NET Global Assembly Cache Utility.  Version 1.1.4318.0
Copyright (C) Microsoft Corporation 1998-2002. All rights reserved.
Failure adding assembly to the cache: Unknown Error
And Drag and Drop to folder assembly is not possible.
Thank for help.
Eric,
Following post may give you a solution for your problem, hope it helps, take a look if you are interested.
