Kwong,
I have put together the code for you new custom layer. The first part is how to use it and the second part is the actually new class.
// Here I create my custom layer
SimpleCustomLayer customLayer = new SimpleCustomLayer();
// Here I add my cusotm layer to the layers collection.
Map1.StaticLayers.Add("CustomLayer", customLayer);
_+_+_+_+_+
New Class
_+_+_+_+_+
using System;
using System.Collections.Generic;
using System.Text;
using System.Drawing;
// What this sample does is creates your own layer. You can use this layer just like any other layers
// in the system. The advantage is that you can place it where you want and it will seamlessly integrate
// with the rest of the system. As you can see it is really easy to create your own layers.
// The basic flow of events is that when the map needs to draw it will first call the OpenCore.
// This is where you do anything special to get your source ready. Then it will call the GetBoundingBox
// method to make sure the current extent of the map is within the are you have data. If not then it will
// never call the DrawCore because there is no need. Then if you are int he extent it wil call the DrawCore.
// The DrawCore is where you place your code that need to do the drawing on the canvas. As you can see below
// it is faily simple.
namespace ThinkGeo.MapSuite.Core
class SimpleCustomLayer : Layer
protected override void OpenCore()
// Here you should do anything you need to do it initilize your source.
// Maybe for you it is nothing and if so you can leave it blank.
protected override void CloseCore()
// Here you should do anything you need to do it close your source.
protected override RectangleShape GetBoundingBoxCore()
// Here you will want to pass back a rectangle that defines the entire extent of
// of image source. So if a user pans outside off of where you have imagry for the map
// control we will not try and fetch it. If your data is for the whole world or you are
// fine to just passing back a transparent image if the user goes off the edge then you can use
// the default code I added
//This assumes that your map is in decimal degrees and covers the whole world, if not you need to know the bounds.
return new RectangleShape(-180.0, 83.0, 180.0, -90.0);
protected override void DrawCore(GeoCanvas canvas, GeographyUnit mapUnit, System.Collections.ObjectModel.Collection<simplecandidate> labeledInLayers)
// Here is where you will call your API. You will get a bitmap back and then draw it in the canvas.
// I have provided a mock method call to simulate what you will do.
Bitmap customImage = GetImage(canvas.CurrentWorldExtent.UpperLeftPoint.X, canvas.CurrentWorldExtent.UpperLeftPoint.Y, canvas.CurrentWorldExtent.LowerRightPoint.X, canvas.CurrentWorldExtent.LowerRightPoint.Y, (int)canvas.CanvasWidth, (int)canvas.CanvasHeight);
// Here we draw the image you generated to the canvas.
canvas.DrawWorldImageWithoutScaling(canvas.ToGeoImage(customImage), canvas.CurrentWorldExtent.GetCenterPoint().X, canvas.CurrentWorldExtent.GetCenterPoint().Y, DrawingLevel.LevelOne);
customImage.Dispose();
private Bitmap GetImage(double upperLeftX, double upperLeftY, double lowerRightX, double lowerRightY, int screenWidth, int screenHeight)
// In here you would get your image and return it.
// I am just returning an image with some text so you can verify it works..
Bitmap customImage = new Bitmap(screenWidth, screenHeight);
Graphics g = Graphics.FromImage(customImage);
g.DrawString("SimpleCustomLayer Test", new Font("Arial", 20, FontStyle.Bold), Brushes.Black, new PointF(screenWidth / 2, screenHeight / 2));
g.Dispose();
return customImage;
} </simplecandidate>
