I have read your code above and I found out there is a problem in your code below:
WinformsMap1.InteractiveOverlays.Clear()
When you set the track mode to track overlay you have clear the InteractiveOverlays, the InteractiveOverlays includes the EditOverlay and TrackOverlay, if you clear it and set the track mode to TrackOverlay, obviously, it dose not work because of the TrackOverlay had been cleared.
When I try after remarks the code of InterectiveOverlay.Clear() and run after, its not working,
After tab file load, map moving automatically with mouse move and after pressing track zoom, mouse creating zoom area but not area not release by mouse. So further help required.
And one more thing in my trackmode=Rectangle, I want to create rectangle area, not with filled color(sky blue by default), only out line required. Can we do with?
1)When you want to use the original interactive overlay, you can first clear the InterativeOverlays and then add a default interactive overlay instance instead of ModeInterativeOverlay distance, which is very similar with you have done, probably I am missing something here.
2) Try the following code snippet here to remove the fill color : winformsMap1.TrackOverlay.TrackShapeLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.FillSolidBrush.Color = GeoColor.StandardColors.Transparent;
Any more questions please feel free to let me know.
