Interactively pan map features in print preview
With TG 10 for WinForms I was able to figure out a way to pan map features (layers in the MapPrinterLayer) interactively using the mouse. It wasn’t perfect, but it was usable. I am now upgrading to TG 14 for WinForms and I am unable to get it working so that it is usable. I have attached two sample projects, on using TG 10 and one using TG 14 so you can see what I was doing in the older version and how that compares to the newer one.
The projects are mostly identical except for the version of TG, one uses TG 10 and the other TG 14. When the project starts there will be a MapView on the left and Print Preview on the right. Please ignore the MapView and just look at panning the Print Preview.
Maybe it’s not possible. Would you please have a look and see if you can help me out?
Steve
PageLayoutControl.zip (1.1 MB) PageLayoutControl_TG_14.zip (438.8 KB)
Hi Steve,
This issue was recreated and fixed in the latest beta 051. Thanks for your sample which helps a lot!
