Internalfeatures clear problem
I am having a problem with Internalfeatures.clear method. I need to show a point on a road feature layer when the mouse hovers over a road. This point shoudl disappear when the mouse moves away. Showing the point works fine but when the moves moves away the point does not disappear. I am using Internalfeatures.clear to remove the point shape when the mouse moves away. Also, is there a better way to do this instead of adding a point feature and removing it. eg. Can the point feature's visibility be controlled. I have already tried the isvisible property of the inmemoryfeaturelayer which did not work.
Private Sub WinformsMap1_MouseMove(ByVal sender As System.Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles WinformsMap1.MouseMove Dim MousePoint As PointShape = ExtentHelper.ToWorldCoordinate(WinformsMap1.CurrentExtent, e.X, e.Y, WinformsMap1.Width, WinformsMap1.Height) Dim ProjectionToWGS84 As New Proj4Projection(Proj4Projection.GetEpsgParametersString(26918), Proj4Projection.GetEpsgParametersString(4326)) ProjectionToWGS84.Open() Dim PointVertex As Vertex Dim FeatureDistance As Double PointVertex = ProjectionToWGS84.ConvertToExternalProjection(MousePoint.X, MousePoint.Y) InfoForm.Latitext.Text = Format(PointVertex.X, "0.0000") InfoForm.Longitext.Text = Format(PointVertex.Y, "0.0000") If ControlForm.MseTool3.Checked = True Then 'WinformsMap1.TrackOverlay.TrackMode = TrackMode.Point Dim RoadDOTLayer As FeatureLayer = WinformsMap1.FindFeatureLayer("ROAD_DOT") Dim TrackPoint As InMemoryFeatureLayer = DirectCast(WinformsMap1.FindFeatureLayer("TrackingPoint"), InMemoryFeatureLayer) TrackPoint.InternalFeatures.Clear() TrackPoint.IsVisible = False Dim tolerance As Double = 0.0001 Dim searchingBoundingBox As RectangleShape = New RectangleShape(MousePoint.X - tolerance, MousePoint.Y + tolerance, MousePoint.X + tolerance, MousePoint.Y - tolerance) RoadDOTLayer.Open() Dim selectedFeaturesRoadDOTLayer As Collection(Of Feature) = RoadDOTLayer.QueryTools.GetFeaturesInsideBoundingBox(searchingBoundingBox, New String(0) {"STREET_NAM"}) RoadDOTLayer.Close() If selectedFeaturesRoadDOTLayer.Count > 0 Then FeatureDistance = selectedFeaturesRoadDOTLayer.Item(0).GetShape().GetDistanceTo(MousePoint, GeographyUnit.Meter, DistanceUnit.Feet) If FeatureDistance <= 10.0 Then WinformsMap1.Overlays("InMemoryOverlay").Lock.EnterWriteLock() Try Dim TrackingShape As PointShape = New PointShape() TrackingShape.Id = "TrackingPoint" TrackPoint.InternalFeatures.Add("TrackingPoint", New Feature(TrackingShape)) TrackPoint.IsVisible = True Dim Point As PointShape = TrackPoint.InternalFeatures("TrackingPoint").GetShape() Dim PointOnRoad As PointShape = selectedFeaturesRoadDOTLayer.Item(0).GetShape().GetClosestPointTo(MousePoint, GeographyUnit.Meter) Point.X = PointOnRoad.X Point.Y = PointOnRoad.Y TrackPoint.Open() TrackPoint.EditTools.BeginTransaction() TrackPoint.EditTools.Update(Point) TrackPoint.EditTools.CommitTransaction() TrackPoint.Close() Finally WinformsMap1.Overlays("InMemoryOverlay").Lock.ExitWriteLock() End Try Else TrackPoint.InternalFeatures.Clear() TrackPoint.IsVisible = False End If Else TrackPoint.InternalFeatures.Clear() TrackPoint.IsVisible = False End If Else 'TrackPoint.IsVisible = False 'WinformsMap1.TrackOverlay.TrackMode = TrackMode.None End If WinformsMap1.Refresh() End Sub
Sorry about the source code not getting posted correctly
Here it is again
            RoadDOTLayer.Open()
                    Try
                        TrackPoint.Open()
                        TrackPoint.Close()
                    Finally
                    End Try
                Else
                End If
            Else
            End If
        Else
        End If
    End Sub
Madduri,
Thanks for your post and codes!
I cannot compile you code because it lacks so many contexts here, but according to analyze you code, I found one potential problems, please fixed them and have a try:
I guess the InmemoryLayer “TrackPoint” is one layer in the Overlay “InMemoryOverlay” which was added to the Map control, and you did a great job for locking when adding features to it?
But I did not see any lock when you remove the features or set it to Invisible status, I think this is the problem,; can you try the following code snippet?
            RoadDOTLayer.Open()
            Try
                        TrackPoint.Open()
                        TrackPoint.Close()
Else
End If
Else
End If
Finally
            End Try
        Else
        End If
Any more questions just let me know!
Thanks Yale. That fixed the problem.
Madduri,I am glad to hear that!
