Invalid features
I get this error when trying to display a layer on the map
"This operation cannot be completed because the instance is not valid.....................)
But when I loop through to check each feature.IsValid, all the features are valid so what I do now?
Hello Kenny,
 Have you debug and see which method cause this exception? Is that a shape file feature layer or a sql layer?
 Could you please provide a sample that can recreate the problem?
Here is another related problem.
 I check the shape to make sure it is valid before adding to the shapefile.
 But when I run this
 boundaryLayer.EditTools.Add(poly, columnValues);
 I get an error saying feature is not valid
Hello Kenny,
 Is that possible you can provide your sample? It’s really hard to find out the root cause without recreate it.
 Or if you can provide your shape file(if it is a shape file), we can made a sample to show you how to display that file or find out if it’s the file’s problem.
Attched is the shapefile. Please let me know soon.
New_folder.zip (39.1 KB)
 Hello Kenny,
 Thanks for your data, I did some test on it, everything is ok, please check the attachment, I made a sample to you.
 Let us know your queries.
001_DisplayASimpleMap.aspx.cs.zip (670 Bytes)
Oops, those boundaries didn’t get added to the shapefile because I put a trycatch around EditTools.Add.
 Here are some boundary xml that passed the valid test but error out at EditTools.Add
 “<?xml version=&#34;1.0&#34;?>\r\n<Polygon xmlns:xsd=&#34;w3.org/2001/XMLSchema&#34; xmlns:xsi=&#34;w3.org/&#34;>\r\n<Key>ec605f8c-6a47-4f96-a6fe-c01e1a4ae520</Key>\r\n<Selected>false</Selected>\r\n<Parts>\r\n<MultiPoint>\r\n<Key>0bd54f15-16d7-4078-904a-fd903e89a661</Key>\r\n<Selected>false</Selected>\r\n<RingType>OuterRing</RingType>\r\n<RingOrder>ClockWise</RingOrder>\r\n<Points>\r\n<PointShape>\r\n<Key>f3280977-baf3-46a1-a8fa-f3b6b8e61e6f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.818039</X>\r\n<Y>33.688251</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>10746aa2-1549-493f-bf67-10262fa6e59e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817708</X>\r\n<Y>33.688034</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a0831a88-bba3-44e6-8b1d-c595bdbd0abc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817575</X>\r\n<Y>33.687957</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d8186228-0bcb-413f-8b47-70b089db8fdb</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817459</X>\r\n<Y>33.687884</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e2af2409-9936-4301-9a05-cc0fef8bc53f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817185</X>\r\n<Y>33.687733</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c7834afa-9ebc-466f-bcd2-03c99a1ca11b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817058</X>\r\n<Y>33.687659</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>047054be-1f82-4138-8c58-53934833ad95</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816853445944</X>\r\n<Y>33.6875406197805</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>39d5f1e7-f6f9-4444-a85a-befdf9522cdb</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816861</X>\r\n<Y>33.687544</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a16e37a8-82a6-4d16-b3de-4a9f89b711fc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816604</X>\r\n<Y>33.687429</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2dd22d52-0866-4605-af61-d5877a9159d2</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816347</X>\r\n<Y>33.687327</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c766ddb9-17aa-43ff-9f8f-6f9b70b77b36</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816144357461</X>\r\n<Y>33.6872548140311</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>66d2f55b-e010-4c22-951f-a8b9d5fd18b0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.81597</X>\r\n<Y>33.687201</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d26a0510-3705-4c95-b0f9-06091ccd53eb</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815795</X>\r\n<Y>33.687158</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ebc68b50-17f8-41b8-ae78-200871f59e6b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815736</X>\r\n<Y>33.687143</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e5bfb8c8-4838-4404-af0c-75f35a922625</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815506</X>\r\n<Y>33.6870799999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a850863f-a09e-4619-81d8-78a747bcca21</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815268</X>\r\n<Y>33.687037</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>70689594-29c4-4bc4-aeb4-ad685125aa93</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815233</X>\r\n<Y>33.687028</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>37877a47-0d82-4bca-a85a-7170ba39ec8d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815018</X>\r\n<Y>33.686992</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f3ddb213-28d2-40e1-b678-f5da327218f2</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814795</X>\r\n<Y>33.686957</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b993ba43-0057-430b-8342-01856cf1d2de</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814326</X>\r\n<Y>33.686901</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>84915eb2-5171-44e8-9228-f10426146584</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813758</X>\r\n<Y>33.686837</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7c5ea814-e9b7-4cc5-86b2-7bc3a4ed44d2</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813495</X>\r\n<Y>33.686806</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>20f699bb-ea7c-406d-a5a3-83ca92bfce19</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813246</X>\r\n<Y>33.686766</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8ed6a9fe-48ce-4d57-9717-e3f62c602c88</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812876</X>\r\n<Y>33.686699</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a6e0fc66-6859-45ce-83ae-691863b78366</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812327</X>\r\n<Y>33.686562</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0aa232b3-0cf4-4d5f-8815-456b62b6527a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812155</X>\r\n<Y>33.686511</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e7430284-e90e-4967-b0cd-967f6b18a176</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812146</X>\r\n<Y>33.686504</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>db7c21de-533c-4753-b292-fd86312f3f01</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811697</X>\r\n<Y>33.686346</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9acbb044-2f79-4ba5-b10e-3b3a9a6bb8f1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811213</X>\r\n<Y>33.686138</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>fb923d03-67e2-46c8-a1d5-2f5d438efc03</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810971690887</X>\r\n<Y>33.6860055665026</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>335ed3f7-1bc0-469c-a818-dd42ce97f193</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810876</X>\r\n<Y>33.685956</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ba659304-4be1-486e-8643-eb066be55026</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810552</X>\r\n<Y>33.685763</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>078bdb61-216f-4cca-b2e4-8f08f86bf483</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810369</X>\r\n<Y>33.685647</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3f5698c1-8022-401d-bed7-5bd9e996df75</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810145</X>\r\n<Y>33.685491</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>919379f7-c898-4cf8-b454-010abc239d6f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809844039579</X>\r\n<Y>33.6852787763627</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>912996e1-806e-40c6-96c3-16bbe726fb6f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809785</X>\r\n<Y>33.685238</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>68482896-3632-45ca-8f5e-c0c4151fd19e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809268</X>\r\n<Y>33.684876</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>01f52968-45ff-42ca-9af8-b3cbfdb87c10</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809204</X>\r\n<Y>33.684822</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1c496894-d17d-4844-948b-37816a17f1c9</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808955</X>\r\n<Y>33.684655</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6c0f0d14-18d9-4d49-93d2-8b30f13786d1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808715</X>\r\n<Y>33.684495</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e94cfc50-03db-45a3-a83c-27a1b8f729eb</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808621</X>\r\n<Y>33.684437</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>57dc9ce0-c713-4df8-8774-f97fa58d7e56</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808295</X>\r\n<Y>33.68421</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f4c82f97-fd4a-4b9c-af18-2eb8caef8c4c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808663</X>\r\n<Y>33.68385</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c57a1257-fdec-4793-8431-4b71e915cf53</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809409</X>\r\n<Y>33.683065</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f9599673-0178-4d73-a3a6-e289226fe413</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809461</X>\r\n<Y>33.68301</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>fb1eeb9f-cfed-4a2a-9ec0-79674f360f9f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809755</X>\r\n<Y>33.682716</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8ac77d7a-013e-49f2-8a30-72abb1200cc0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809893</X>\r\n<Y>33.682581</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a72e23f7-e4aa-4819-9cc6-134fac52f7e0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810153</X>\r\n<Y>33.6823319999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0d219742-83ab-4f7b-ad2f-e9cc5f546015</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810268</X>\r\n<Y>33.682213</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>201251ce-a1c8-435d-a50d-f1fbf7a9a318</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810369</X>\r\n<Y>33.682114</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>46913290-dcab-4c37-9eab-d0185587931f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810583</X>\r\n<Y>33.6818969999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0ef35f28-e253-4ddb-8a58-451c7ad4f199</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810847</X>\r\n<Y>33.681619</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0241f047-77a0-4768-b51b-c45b7f1c336e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811193</X>\r\n<Y>33.681276</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3f99b948-1696-4362-a20a-627835efb094</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811475</X>\r\n<Y>33.680994</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3ae14815-b589-4929-b2ae-2ad9c4a12c09</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811572</X>\r\n<Y>33.680884</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2dc9c145-53fa-4aef-a0bd-78859508d9f0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811793</X>\r\n<Y>33.680665</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>51cb5dcd-416b-4864-97ca-cf71e5371432</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812457</X>\r\n<Y>33.6799589999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9609cfb8-cd02-4486-8f40-fede9a118f85</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813012</X>\r\n<Y>33.679403</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f536bedd-8f7d-4b77-a63a-73ab788e4e5b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813684</X>\r\n<Y>33.678752</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>275284f8-826b-4e37-9eff-c93ebee56371</Key>\r\n<Selected>false</Selected>\r\n<X>-117.81426</X>\r\n<Y>33.678167</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>74e41c8b-80b3-426c-9c02-6b2a88b53c51</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814726</X>\r\n<Y>33.677712</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a8a39dd8-ed2f-4cf7-b820-d95985a410c7</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814969</X>\r\n<Y>33.677448</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a9b6b8c6-ab41-4ebd-bdd6-1fcfe8b5ceb0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815271</X>\r\n<Y>33.677151</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>81ddbdec-7166-4d58-8bd3-d446eeb75f58</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815623</X>\r\n<Y>33.676816</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c18adfc0-8b46-4c2c-aac3-b3ae615b6897</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816327</X>\r\n<Y>33.676111</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cde9108e-8a73-4db4-b000-d5a471bd0b50</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816463</X>\r\n<Y>33.675965</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>da32d41d-9767-407f-bc06-8a07401113b0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816716</X>\r\n<Y>33.675719</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f8807180-329b-4d6f-92b3-01c9d10dfe32</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817254</X>\r\n<Y>33.675175</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d4cf111f-1032-4e06-8c43-518d26067999</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817581</X>\r\n<Y>33.674861</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>93482268-af2e-4d24-a63b-35d21d18b3f4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.819073</X>\r\n<Y>33.673359</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>000d2d99-2b9a-4e42-b1f5-2e11c735b653</Key>\r\n<Selected>false</Selected>\r\n<X>-117.819326</X>\r\n<Y>33.673102</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7038e836-4b88-4cd3-82b6-12ac43449e53</Key>\r\n<Selected>false</Selected>\r\n<X>-117.819935</X>\r\n<Y>33.672478</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>291f194a-6e5e-4686-8c82-4defa3fb27d0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.820409</X>\r\n<Y>33.671995</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6b58b0e1-f6aa-453a-9b96-3aff2df81492</Key>\r\n<Selected>false</Selected>\r\n<X>-117.820768</X>\r\n<Y>33.671639</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d366e17f-c71d-4b2f-a223-c3def606f473</Key>\r\n<Selected>false</Selected>\r\n<X>-117.821268</X>\r\n<Y>33.671142</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>42b7727e-25fa-424f-be6e-601d0f673682</Key>\r\n<Selected>false</Selected>\r\n<X>-117.821375</X>\r\n<Y>33.671038</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>65682872-bdae-4278-b635-56abc6b5e17a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.821681</X>\r\n<Y>33.670704</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>34728e6d-5fa6-4738-997d-b2cd0d2df7f4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822257</X>\r\n<Y>33.670081</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>64c79b0a-2921-4429-90c6-9cda5c2bcdf6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822482</X>\r\n<Y>33.669853</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b290008b-548b-4d8b-95ce-58ee66c1c0d0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822657</X>\r\n<Y>33.669676</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>12d19f4c-4a83-417d-884c-bdb1f89b3e1a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822731</X>\r\n<Y>33.669601</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5a9bfe6b-8eb1-4372-b248-90053942faa3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.823045</X>\r\n<Y>33.669709</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d51cc895-b727-4547-b7ab-7f5a71089bce</Key>\r\n<Selected>false</Selected>\r\n<X>-117.823132</X>\r\n<Y>33.669742</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2dc88535-81cc-45a6-807b-30dbcf323cc9</Key>\r\n<Selected>false</Selected>\r\n<X>-117.823605</X>\r\n<Y>33.669913</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f435876f-acec-49b5-b5e9-cc025f104b8a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.823994</X>\r\n<Y>33.670046</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>970775a4-6198-48a8-8270-0a326e4bd981</Key>\r\n<Selected>false</Selected>\r\n<X>-117.826409</X>\r\n<Y>33.670872</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>590b6f2c-9f2c-4b11-b2fc-a77a43d87636</Key>\r\n<Selected>false</Selected>\r\n<X>-117.826451</X>\r\n<Y>33.670884</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7d162f3d-5f91-45eb-81c5-1aa77bf5b566</Key>\r\n<Selected>false</Selected>\r\n<X>-117.826543</X>\r\n<Y>33.670912</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f07bd640-8a9a-4ea1-93a2-3d2eb9cd3155</Key>\r\n<Selected>false</Selected>\r\n<X>-117.8291</X>\r\n<Y>33.671783</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c05919f0-2ac1-4063-8d51-480597f4b225</Key>\r\n<Selected>false</Selected>\r\n<X>-117.829481</X>\r\n<Y>33.671913</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5fcfd478-a7de-4eec-8fe6-34e1245cbe7c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.830777</X>\r\n<Y>33.672352</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>48f4eca3-253b-47b0-9749-02a9981e5295</Key>\r\n<Selected>false</Selected>\r\n<X>-117.830866</X>\r\n<Y>33.672379</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cb6e2a08-6c3c-4510-9c20-6955c32e2426</Key>\r\n<Selected>false</Selected>\r\n<X>-117.831286</X>\r\n<Y>33.672508</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>aa57be9b-bf3f-495f-b72d-18e1deb242e0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.831719</X>\r\n<Y>33.672656</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8aecda9c-6d7d-4a3d-a989-407fefb85706</Key>\r\n<Selected>false</Selected>\r\n<X>-117.831795</X>\r\n<Y>33.672682</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>494657cd-8596-4691-94be-d2024bb74bb2</Key>\r\n<Selected>false</Selected>\r\n<X>-117.831993</X>\r\n<Y>33.672749</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>28e030f1-483f-4e49-b232-b48fe7b03a98</Key>\r\n<Selected>false</Selected>\r\n<X>-117.832272</X>\r\n<Y>33.67284</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6c10c682-06ac-49e3-9f26-c23d9d776181</Key>\r\n<Selected>false</Selected>\r\n<X>-117.832654</X>\r\n<Y>33.672978</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>aa40aeca-b872-425e-80fe-0b5feb337d13</Key>\r\n<Selected>false</Selected>\r\n<X>-117.833947</X>\r\n<Y>33.673399</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cea27098-afc9-421c-adb7-00a79c6eaf43</Key>\r\n<Selected>false</Selected>\r\n<X>-117.834687</X>\r\n<Y>33.673646</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2d2a014b-6be8-4a64-a224-7cd8326c6c33</Key>\r\n<Selected>false</Selected>\r\n<X>-117.835213</X>\r\n<Y>33.673827</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>405e65ed-23d2-4c95-be17-ea3e91fc329c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.835739</X>\r\n<Y>33.674013</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>383f0edf-ee4b-4c45-954b-92f3f7d82b46</Key>\r\n<Selected>false</Selected>\r\n<X>-117.835867</X>\r\n<Y>33.674061</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>535e4fd0-3845-4a61-aea1-04183fe52cfd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.836027</X>\r\n<Y>33.674111</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5ea0e2c0-12b7-4ba9-8a1c-ec84026c23aa</Key>\r\n<Selected>false</Selected>\r\n<X>-117.840087074487</X>\r\n<Y>33.6751396231072</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>38d87e8c-8f2e-44b5-bfaa-c146416dfe2d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.854217990178</X>\r\n<Y>33.6849435870455</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>fc4e1479-242b-4653-b7f4-2432ff6b6975</Key>\r\n<Selected>false</Selected>\r\n<X>-117.846063</X>\r\n<Y>33.693514</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>93c88fd4-7bb3-4f1c-a7e3-1d12ff67f1c4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.844824</X>\r\n<Y>33.692681</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>df91c76b-726a-4571-a22d-840f2b247a01</Key>\r\n<Selected>false</Selected>\r\n<X>-117.844077</X>\r\n<Y>33.692148</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>74955b0b-f009-495f-b5b8-2326abcbe250</Key>\r\n<Selected>false</Selected>\r\n<X>-117.843462</X>\r\n<Y>33.691716</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7dacd5fe-e1f6-4c47-ab10-8c3b8cda9945</Key>\r\n<Selected>false</Selected>\r\n<X>-117.842435</X>\r\n<Y>33.691011</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3820862a-bab2-4692-a595-15f017dcfab3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.841474</X>\r\n<Y>33.690329</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>719de6e6-7ab9-4f22-b907-c4846c52f2a0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.841345</X>\r\n<Y>33.690239</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>705d10dc-0d51-48ce-a57c-93c283a54f89</Key>\r\n<Selected>false</Selected>\r\n<X>-117.841196</X>\r\n<Y>33.69013</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a6455400-5830-401a-b414-4f2467d8df26</Key>\r\n<Selected>false</Selected>\r\n<X>-117.840491</X>\r\n<Y>33.689663</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3e3d6a04-8c64-4d37-9ad5-9cfd660e4ebf</Key>\r\n<Selected>false</Selected>\r\n<X>-117.839779</X>\r\n<Y>33.689183</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>939da927-5ac5-4dbf-aa07-1db5796e635a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.839587</X>\r\n<Y>33.689043</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c0e782cb-83cd-4f26-ab26-70c91efda3f4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.839557</X>\r\n<Y>33.689022</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>995cb50c-f2de-4d4a-9974-bcf073a492c6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.838005</X>\r\n<Y>33.687909</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d43a8f43-90ad-4e08-af9d-9f51691022f1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.837448</X>\r\n<Y>33.687526</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>202fc9a8-31bc-4bc1-8f87-eab24afceae2</Key>\r\n<Selected>false</Selected>\r\n<X>-117.836812</X>\r\n<Y>33.687057</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>037d31fa-5272-4b89-8a45-528dcdb877e8</Key>\r\n<Selected>false</Selected>\r\n<X>-117.836249</X>\r\n<Y>33.686672</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2317e7fd-97b1-445f-a7c3-ec7982b78331</Key>\r\n<Selected>false</Selected>\r\n<X>-117.834913</X>\r\n<Y>33.685741</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a44a5e4d-0b53-483a-98e2-e15aedf83b75</Key>\r\n<Selected>false</Selected>\r\n<X>-117.832229</X>\r\n<Y>33.688413</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c0db7db4-9ae2-4ce3-8026-e0044db4e952</Key>\r\n<Selected>false</Selected>\r\n<X>-117.832148</X>\r\n<Y>33.688496</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d64fdf8d-38df-4bbd-8adc-75284dc6a93b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.83177</X>\r\n<Y>33.688875</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cfcc0a9d-02bf-4196-b9bc-369470614c04</Key>\r\n<Selected>false</Selected>\r\n<X>-117.831682</X>\r\n<Y>33.68897</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>664c42e8-3712-4eb7-9903-82737ae5f4bd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.831444</X>\r\n<Y>33.68927</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d6daec76-160e-413b-862b-bf374a02b9c4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.831396</X>\r\n<Y>33.689336</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>27c4f39e-97ae-4f0b-b0f7-2268abcbae90</Key>\r\n<Selected>false</Selected>\r\n<X>-117.831291</X>\r\n<Y>33.689495</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>31ca13ad-1443-4678-a805-4c7b840048ec</Key>\r\n<Selected>false</Selected>\r\n<X>-117.831065</X>\r\n<Y>33.689809</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>62cf2bd3-4f60-4124-ad34-3362d312bcaf</Key>\r\n<Selected>false</Selected>\r\n<X>-117.831008</X>\r\n<Y>33.689889</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a8c1e766-1972-433b-b80b-a54343743017</Key>\r\n<Selected>false</Selected>\r\n<X>-117.830965</X>\r\n<Y>33.689947</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b7dff91c-7089-4ba0-a114-67b00ba2bb4a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.830869</X>\r\n<Y>33.690059</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d4201a24-ee06-48f4-addb-67d4395a0871</Key>\r\n<Selected>false</Selected>\r\n<X>-117.830455</X>\r\n<Y>33.690487</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2d556001-67e6-4d2d-a3a7-b2696d02a6c5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.830133</X>\r\n<Y>33.690809</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>136d6400-1e4e-40c8-a6b5-f358f5f8c0e5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.828727</X>\r\n<Y>33.692203</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7e23acce-781e-40af-92fd-6c8f67f4e302</Key>\r\n<Selected>false</Selected>\r\n<X>-117.828626</X>\r\n<Y>33.692292</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d80fe49e-8404-4e2d-914d-7a691d1503e1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.82828</X>\r\n<Y>33.692638</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3e3b8630-cb0b-44d6-9e87-3eb5877cdd36</Key>\r\n<Selected>false</Selected>\r\n<X>-117.827918</X>\r\n<Y>33.692996</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>aa2b6404-fa4f-4b57-b419-b150889013ce</Key>\r\n<Selected>false</Selected>\r\n<X>-117.826889</X>\r\n<Y>33.694054</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9c40a16f-7aa5-42f2-b31e-aab48fb54664</Key>\r\n<Selected>false</Selected>\r\n<X>-117.826754</X>\r\n<Y>33.694183</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>dd882cf2-2830-448f-8902-2afd44fea24c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.818512</X>\r\n<Y>33.688569</Y>\r\n</PointShape>\r\n</Points>\r\n</MultiPoint>\r\n</Parts>\r\n</Polygon>\r\n”
here is another one
 "<?xml version=&#34;1.0&#34;?>\r\n<Polygon xmlns:xsd=&#34;w3.org/2001/XMLSchema&#34; xmlns:xsi=&#34;w3.org/&#34;>\r\n<Key>74a5f73f-23a3-4417-bbbf-7ce52a7bd47a</Key>\r\n<Selected>false</Selected>\r\n<Parts>\r\n<MultiPoint>\r\n<Key>3a9b48e5-be34-4720-9f0f-814f20902e18</Key>\r\n<Selected>false</Selected>\r\n<RingType>OuterRing</RingType>\r\n<RingOrder>ClockWise</RingOrder>\r\n<Points>\r\n<PointShape>\r\n<Key>6582bd9b-6474-49ac-aa57-6e30553dc54c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809014</X>\r\n<Y>33.665615</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>89d652c4-ebab-4e82-8dc3-e9e8a8769666</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809437</X>\r\n<Y>33.665679</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3f39c569-e055-4fb8-aaad-16f77bf90031</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810342</X>\r\n<Y>33.66583</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5ecf37d8-7a8f-467d-8510-8c3b8839d0e4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811101</X>\r\n<Y>33.665973</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7e892246-401a-414c-aaa3-05822b5e5801</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811722</X>\r\n<Y>33.666102</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4a38e8db-e46b-4b00-9e82-a47e27d44234</Key>\r\n<Selected>false</Selected>\r\n<X>-117.8123</X>\r\n<Y>33.666231</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f87983f7-0597-4429-961b-a71724270559</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812869</X>\r\n<Y>33.666389</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>669297af-14d7-49cb-b003-5da307189007</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813921</X>\r\n<Y>33.666683</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9fff866a-b7f0-4719-bb13-b6b21fd9c2d6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814412</X>\r\n<Y>33.666834</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4f498d0b-76f2-486a-b711-1af3da13dd4d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815266</X>\r\n<Y>33.667121</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3d16d599-72b6-41e4-8b68-63ceab060234</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815999</X>\r\n<Y>33.667372</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2b19ffa9-85be-42c4-8218-dc1de1efb3f3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816608</X>\r\n<Y>33.667553</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9543798f-2721-4a63-a065-e6950317d9df</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817648</X>\r\n<Y>33.667861</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2b17c608-6cd1-44c7-8959-e3431cc36728</Key>\r\n<Selected>false</Selected>\r\n<X>-117.819496</X>\r\n<Y>33.668452</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>93cfd9b3-eb60-4bfb-9c18-fc30685f518a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.819996</X>\r\n<Y>33.668646</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1bfd4df7-7be2-467c-8cb1-c4ff17555cfe</Key>\r\n<Selected>false</Selected>\r\n<X>-117.820373</X>\r\n<Y>33.668783</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1f958ba0-fe98-465e-bb31-d21886936f20</Key>\r\n<Selected>false</Selected>\r\n<X>-117.82073</X>\r\n<Y>33.668909</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d6f7ecc7-dcf1-4408-9f3b-51d7657997ff</Key>\r\n<Selected>false</Selected>\r\n<X>-117.821128</X>\r\n<Y>33.669034</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>29d36148-72af-47e2-9e45-9cb7d5c1b109</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822001465116</X>\r\n<Y>33.6693415581395</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e4e6d2e2-cfa1-411e-8a97-4cacbc5138ea</Key>\r\n<Selected>false</Selected>\r\n<X>-117.821958</X>\r\n<Y>33.669325</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>16d5b115-207c-4bca-bfe7-fa3da7d3b35a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822273</X>\r\n<Y>33.669445</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0a504d3a-86a3-47be-8af9-a38b3d1fb172</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822422</X>\r\n<Y>33.669497</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>bc223fb8-c422-48fb-ae1d-87fffea03932</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822731</X>\r\n<Y>33.669601</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>921926e6-d600-4940-92a4-374c61206fa3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822657</X>\r\n<Y>33.669676</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2f87006e-80db-4c83-8833-60a312dac9f8</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822482</X>\r\n<Y>33.669853</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>34ed1fed-7f17-4fde-9940-11cf3aa74a11</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822257</X>\r\n<Y>33.670081</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>59e71f64-6769-4c5c-9937-236d0262268c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.821681</X>\r\n<Y>33.670704</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>52a9aa62-d39f-441b-ab5b-acfccaf54512</Key>\r\n<Selected>false</Selected>\r\n<X>-117.821375</X>\r\n<Y>33.671038</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>20913e28-50b2-4121-8832-84f22321e619</Key>\r\n<Selected>false</Selected>\r\n<X>-117.821268</X>\r\n<Y>33.671142</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c0a6a72a-59a2-4f9c-b942-cf56f6096075</Key>\r\n<Selected>false</Selected>\r\n<X>-117.820768</X>\r\n<Y>33.671639</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9781454e-d531-4341-9dbd-5763785f62d8</Key>\r\n<Selected>false</Selected>\r\n<X>-117.820409</X>\r\n<Y>33.671995</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0b6111a7-9b85-4a57-8e0f-a36abc99751c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.819935</X>\r\n<Y>33.672478</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>92aa7a59-7192-44b6-8402-3cb60a35480c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.819326</X>\r\n<Y>33.673102</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>af40531e-f4bb-48bd-b3a4-55b6c87825a0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.819073</X>\r\n<Y>33.673359</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4c93740a-292c-45bb-b595-7f6a306fdd25</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817581</X>\r\n<Y>33.674861</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>840c4663-513a-46f4-a7f7-ea34388e6c18</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817254</X>\r\n<Y>33.675175</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6762d2f1-0d53-4bf6-8b1f-af45c9e2c65e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816716</X>\r\n<Y>33.675719</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7b58ecfc-21d5-4395-a456-65d1d3fac2c0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816463</X>\r\n<Y>33.675965</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e46a6941-cd47-4294-ad8a-b7871039b330</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816327</X>\r\n<Y>33.676111</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>908ed7cb-3cec-4130-b30a-760ca0f52666</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815623</X>\r\n<Y>33.676816</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>31f71e17-ebac-4f4e-adad-5dd3204e8bba</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815271</X>\r\n<Y>33.677151</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3e13ccd0-d6af-49a4-a187-74fe93640ee8</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814969</X>\r\n<Y>33.677448</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6284b694-79a2-4ab6-b212-3e7e846b5633</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814726</X>\r\n<Y>33.677712</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d83ea336-d812-43ac-9f93-81ce84119f1d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.81426</X>\r\n<Y>33.678167</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>754729a3-1d0b-442a-b285-170e313593bd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813684</X>\r\n<Y>33.678752</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>133e1266-2fc8-426e-af28-0c6837dbeb85</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813012</X>\r\n<Y>33.679403</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3e920136-8a81-4d77-a972-56c62d6ff0ef</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812457</X>\r\n<Y>33.6799589999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0105540f-50b6-458d-88e2-1f16fa2a6a6c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811793</X>\r\n<Y>33.680665</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d9b8c846-7568-4a7e-8373-c75b516bc2fc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811572</X>\r\n<Y>33.680884</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>753b69bc-f5da-4f19-a752-3123bf239937</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811475</X>\r\n<Y>33.680994</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d888a66d-f86a-4b2f-9545-080d8a366e12</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811193</X>\r\n<Y>33.681276</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>786b2899-51a6-4eee-abea-4e4d89917aca</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810847</X>\r\n<Y>33.681619</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e1d677b2-cfd0-43d3-9c66-4d66c2f8d4c7</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810583</X>\r\n<Y>33.6818969999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ac68dc71-5943-448c-aaf0-6d684613de92</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810369</X>\r\n<Y>33.682114</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>60e959f2-b31f-4235-b036-d0e96e6208b5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810268</X>\r\n<Y>33.682213</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0ac275bc-d809-487a-9041-3667039b8791</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810153</X>\r\n<Y>33.6823319999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6edc877d-c0e3-422d-b0ad-bf9156b987da</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809893</X>\r\n<Y>33.682581</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>dd58bf1d-4958-44ea-a534-ac5bdeed24e5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809755</X>\r\n<Y>33.682716</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4eed44cd-0f32-4f6b-8a15-cdeed1df5201</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809461</X>\r\n<Y>33.68301</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>bdf8cbbc-28e9-4d26-b646-e9c592f19208</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809409</X>\r\n<Y>33.683065</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>aaba800b-c1df-4942-9f73-06a3c734152b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808663</X>\r\n<Y>33.68385</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e91d2a5d-ead7-487b-9036-1b259f11b0b3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808288453082</X>\r\n<Y>33.6842052956277</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>24e8999f-9235-4ae5-8ce1-daf968f559b4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808128</X>\r\n<Y>33.68409</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a34f7809-ef96-4912-b35f-c2d4deb41fcc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.807814</X>\r\n<Y>33.683859</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e2b36cbe-36b7-4a57-bf5e-b304bc3e5f64</Key>\r\n<Selected>false</Selected>\r\n<X>-117.807349</X>\r\n<Y>33.6835369999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>17521b38-43bd-46b4-a726-76197eabce73</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80588</X>\r\n<Y>33.682504</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6088acdf-107c-4fef-afc4-8421b8ba9eff</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805793</X>\r\n<Y>33.682439</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c26abe91-bc9a-470d-9a79-41dbee5b76b4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805731</X>\r\n<Y>33.682392</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5ebb042b-5b62-4c34-8663-c5c49e823b19</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805663</X>\r\n<Y>33.682341</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6e8d8559-762a-4a2d-a62a-53f8112ce304</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805616</X>\r\n<Y>33.682305</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1d8f578b-d210-444b-9c0f-ed6a7f559d6e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805591</X>\r\n<Y>33.682288</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f9125f1f-8f6c-4bdf-92ea-6c4f0355bad0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805558</X>\r\n<Y>33.682265</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9ec92b4c-9a8f-424f-8edb-82469c66da7c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805462</X>\r\n<Y>33.682199</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d5398bc0-0a6f-4cfe-b811-830df2df99e6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805372</X>\r\n<Y>33.682136</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a9af0d82-a6c2-41b0-8f55-003619f0b314</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805188</X>\r\n<Y>33.68201</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f30ab413-0d92-4bf1-a548-fa61ac339c25</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805165</X>\r\n<Y>33.681994</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7d22fd9d-903b-4000-9319-7fe91d04a390</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805152</X>\r\n<Y>33.681985</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>65be21f6-bdde-4910-8ae4-5a5b66fab970</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805064</X>\r\n<Y>33.681933</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>294ba73a-8873-4b01-a1e6-56e5dad9aaa0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804751</X>\r\n<Y>33.681746</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>97325c54-f68a-429b-b2b5-20663b61a7f5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804685</X>\r\n<Y>33.681707</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>41782dc3-5165-4c5a-ae6e-507e8e04f418</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80465</X>\r\n<Y>33.681689</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>bada82a2-a138-4de2-9bf8-d40fbaec48fc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804591</X>\r\n<Y>33.681657</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cccdc3ad-51c9-4ad0-82c2-8775545c3177</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804535</X>\r\n<Y>33.681628</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ab13c4a8-40b2-4ec5-99ef-4f2d435858fe</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804475</X>\r\n<Y>33.681596</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>52f899a4-a3ee-4d54-9823-30e8000190c1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804417</X>\r\n<Y>33.681566</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>47c11648-cf48-4fc4-9826-ecc8d8de9ccc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804369</X>\r\n<Y>33.681541</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>de3313bd-0218-4406-9d07-6df638a8200f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804291</X>\r\n<Y>33.6815</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c90fe7ea-072a-42f7-824d-74859bfc786d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804245</X>\r\n<Y>33.681476</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d1fe55f8-0384-4ef2-9348-f093c85ed788</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804136</X>\r\n<Y>33.681424</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f7850bf0-6b5f-414d-9b95-53de6c76a41e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803987</X>\r\n<Y>33.681352</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>039250ca-65a6-46be-9c59-d62b5748839f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803955</X>\r\n<Y>33.68134</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7fd942cd-72a0-4e68-8cd1-3bd3ee6399c7</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803908</X>\r\n<Y>33.681323</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>81c9ab62-e41e-4ddb-81f1-a2fe5aa4a7c7</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803835</X>\r\n<Y>33.681295</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>25b32753-fea7-4191-b55e-680852039d52</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803756</X>\r\n<Y>33.681265</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1c00a105-d37e-4be6-b9ec-81948045223a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803463</X>\r\n<Y>33.681135</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>82857337-af94-42c1-9e85-9eaa231e90f0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803398</X>\r\n<Y>33.681109</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b1152d62-d1c1-49f5-8c8e-f337bdf86130</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803319</X>\r\n<Y>33.6810769999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>93377b10-f552-4bb9-b5cb-7f6e389c2a99</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803181</X>\r\n<Y>33.681022</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b3fecf3f-a620-4cd3-84da-d85bf598848f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803148</X>\r\n<Y>33.681009</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>731d8455-9db6-449f-b49b-b6be99d00194</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803065</X>\r\n<Y>33.680979</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9988adbd-f1f8-46e4-af3a-6bb98b0b5c09</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802985</X>\r\n<Y>33.68095</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9426e522-247b-49cb-91e6-1b04171ae30c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802892</X>\r\n<Y>33.680916</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d362748b-05b5-41f4-a40e-be557203c4df</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802842</X>\r\n<Y>33.680898</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5e543ce5-7fe9-4876-9835-30b394bb25b2</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802809</X>\r\n<Y>33.680885</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1ce2f8c1-22dc-443b-979a-47f55e3acce8</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802735</X>\r\n<Y>33.680854</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a5356b67-7ea5-4fe9-a668-47555711cf45</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802659</X>\r\n<Y>33.680824</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a60ab486-7146-459f-89a1-6c9d8a3c5ff6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802552</X>\r\n<Y>33.68078</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c9e9e876-fbf1-4e71-bd89-80a4993cdacb</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802414</X>\r\n<Y>33.680722</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>580baf32-dc97-4549-9a2f-11d8a6f9b62a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802383</X>\r\n<Y>33.680709</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>22a03023-166e-4e7b-8b70-3cef9d1e0bd7</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802164</X>\r\n<Y>33.680616</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>266e5f3c-908a-49a6-bd16-a48d241a6f1f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80207</X>\r\n<Y>33.680563</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>bfe8cf1c-5c87-499e-9fe9-e467609b420c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801983</X>\r\n<Y>33.680513</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1cd36db2-ef74-421e-8a10-76153422b4fc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80194</X>\r\n<Y>33.680487</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>745c5244-21a7-48a2-a7ab-f065e383434e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801865</X>\r\n<Y>33.680443</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8580ddcf-9fde-4d9e-a1f3-b85e62f28111</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801801</X>\r\n<Y>33.680405</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4dcaca50-2a09-44e8-bdd1-58bc63f18107</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801768</X>\r\n<Y>33.680384</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1d39d77d-9a14-4d38-8c8a-da90b86eb9ed</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801721</X>\r\n<Y>33.680354</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ce5a58c9-7605-41ed-912c-4e054a74c332</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801677</X>\r\n<Y>33.680326</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1001d05d-d371-4571-bf16-7a8c44fcbcea</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801643</X>\r\n<Y>33.680304</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>bcc3c520-ed41-465e-bc82-93c6a0492ef7</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801598</X>\r\n<Y>33.680275</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>14dfdc23-8515-4c1b-890f-4a3b1099030b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801497</X>\r\n<Y>33.680207</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>26b63125-27be-449c-95de-7dcc8c84d5fe</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801425</X>\r\n<Y>33.680159</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ca055566-3d6d-4e58-8357-90cba64d0531</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801393</X>\r\n<Y>33.680134</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ee828647-9c0f-44fe-a1bc-0e74d0f27c3e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801318</X>\r\n<Y>33.6800759999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4697ffa2-2243-453c-a76f-fa4896b57a58</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801255</X>\r\n<Y>33.680026</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>89ac895f-6d12-43ab-864b-4c116d8e3994</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801216</X>\r\n<Y>33.679993</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>92a87698-ba30-4f0d-836f-09da6e89c556</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801174</X>\r\n<Y>33.679958</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0067c614-cb49-45b7-898e-af306de8895a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.8011</X>\r\n<Y>33.679903</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5a84a6cc-fa4b-43af-b142-72c445cbf490</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801058</X>\r\n<Y>33.679864</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ebb24e2f-fef9-4cf2-8422-38027c1d698a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800991</X>\r\n<Y>33.679801</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e2323dc2-fd71-4feb-8d2e-6de525204de2</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800806</X>\r\n<Y>33.679627</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f20f5ee9-5f33-4e34-9f8a-84cc8865ef18</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800745</X>\r\n<Y>33.679566</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9088780a-e804-4313-b256-c0d22a745738</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800704</X>\r\n<Y>33.679527</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>aa4388ee-a5a2-48cf-99a9-b671a56f3b81</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800689</X>\r\n<Y>33.679512</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d509de3d-2caf-4da2-ad35-fb59928d012e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800668</X>\r\n<Y>33.679492</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9cc6e6b2-78c7-4393-b065-697bbb9c5fcb</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800592</X>\r\n<Y>33.67941</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4af2f577-23e8-435f-9ab8-b55bc1c381a5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80046</X>\r\n<Y>33.679268</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8ff310a8-cb53-4209-bfff-14442f330026</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800325</X>\r\n<Y>33.679123</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>fee97666-473e-4b81-af9e-a12bdeda85ca</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800078</X>\r\n<Y>33.6788839999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6495a454-487c-4c57-818f-563126bd7bd6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799995</X>\r\n<Y>33.678804</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>373b4d5d-eccf-4850-a7f1-96d425cb38c8</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799952</X>\r\n<Y>33.678758</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6f59c8a6-9f21-4eaa-a862-e0dad64f7a36</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799874</X>\r\n<Y>33.678672</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7df2041e-bced-4fdb-8dd5-854011f940fa</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799709</X>\r\n<Y>33.678493</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e8eb5f3d-8a55-48dc-a995-f9acdefe36f4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799656</X>\r\n<Y>33.678441</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>04da7e8e-0f4d-4d4e-a178-4b08aeebb503</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799528</X>\r\n<Y>33.678318</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cedeb3e0-047b-49d7-9840-05a72f29a0e4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799389</X>\r\n<Y>33.678187</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>664634ad-f86d-48dc-9c8a-a3cb68bd138e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799367</X>\r\n<Y>33.678169</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>844eb1eb-58df-45dc-b0e1-9ecee3055615</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799104</X>\r\n<Y>33.677952</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8a031e89-5068-4215-8846-8244d740d97f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.79889</X>\r\n<Y>33.677803</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>eec4b237-bd40-422a-9486-5138c285c8f0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802436</X>\r\n<Y>33.674291</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e87272a1-2199-4b05-949b-be9e07959585</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803955009648</X>\r\n<Y>33.6722764741885</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a55f050b-78be-4735-a9bf-88f72e8f9e4a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804839740764</X>\r\n<Y>33.6692657474041</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1284fe06-d5e4-4bbf-a0ca-eef51479cab3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805202</X>\r\n<Y>33.667757</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>389d0caa-053c-4143-a4f7-d77a5484695a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805217</X>\r\n<Y>33.667654</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3e2536de-2a10-4633-8b9a-0522e0811129</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805218</X>\r\n<Y>33.667527</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e6c378da-4a9a-4b34-8ebf-5732fc3cb978</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805228</X>\r\n<Y>33.667444</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d44982a9-3407-4124-acc1-80dcad04944e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805245</X>\r\n<Y>33.667362</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>48d5528f-e09e-46f4-91c2-4a8bfbe185b8</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80529</X>\r\n<Y>33.667217</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b522c56c-98fc-4521-9c2d-7df1dd8b6d4c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80532</X>\r\n<Y>33.667155</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>edeb1a20-a467-4b41-a963-a9041ee9a4cb</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805352</X>\r\n<Y>33.667102</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f19c4778-3c6f-4489-9f99-8df684e1db4a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805426</X>\r\n<Y>33.667005</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>82485a2c-d083-467c-8a41-275770c080f3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805559</X>\r\n<Y>33.6668459999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2632e793-16cc-4c4d-9cd7-5f41450b22e8</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805875</X>\r\n<Y>33.666519</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ce15478e-87d2-44df-a700-78dd1898ea8f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805988</X>\r\n<Y>33.666411</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6b2397ef-936b-4e8d-8226-c03bcc4f6526</Key>\r\n<Selected>false</Selected>\r\n<X>-117.806323</X>\r\n<Y>33.666077</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0b0d68ed-a388-4f59-8e17-a43c66661b89</Key>\r\n<Selected>false</Selected>\r\n<X>-117.806384</X>\r\n<Y>33.666018</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>05a037b3-4ea0-45d0-b2a5-01c0830b86db</Key>\r\n<Selected>false</Selected>\r\n<X>-117.807184</X>\r\n<Y>33.665345</Y>\r\n</PointShape>\r\n</Points>\r\n</MultiPoint>\r\n</Parts>\r\n</Polygon>\r\n"
"<?xml version=&#34;1.0&#34;?>\r\n<Polygon xmlns:xsd=&#34;w3.org/2001/XMLSchema&#34; xmlns:xsi=&#34;w3.org/&#34;>\r\n<Key>bd529329-73c5-4591-b8ee-c27ef8911f7a</Key>\r\n<Selected>false</Selected>\r\n<Parts>\r\n<MultiPoint>\r\n<Key>b6a118c0-0468-40a4-ba18-5a9bd0a90b82</Key>\r\n<Selected>false</Selected>\r\n<RingType>OuterRing</RingType>\r\n<RingOrder>ClockWise</RingOrder>\r\n<Points>\r\n<PointShape>\r\n<Key>b2ddf0e9-20b8-4a9e-bc54-d1d48a6f4413</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802484</X>\r\n<Y>33.701035</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c63094fd-7843-4edc-965e-6f85f3641b6d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802426</X>\r\n<Y>33.700977</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f1093d18-2aa0-436a-b8ab-385516472d2a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802199</X>\r\n<Y>33.7007</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>877db45d-9518-423e-a951-d8081d95bba9</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80217</X>\r\n<Y>33.700649</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>854588ee-0b99-4a6c-8db6-a716b3075bc9</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802123</X>\r\n<Y>33.700586</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>174ef38f-0994-454f-ad41-786f124f1edd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802014</X>\r\n<Y>33.70044</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5ad858ec-2a79-43d9-ab21-292b7ae56f7f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801888</X>\r\n<Y>33.700246</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>fefa3021-4cdc-44cc-bba3-691708096ccf</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801801</X>\r\n<Y>33.70009</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c1dfc8ab-5881-436c-ad32-728591c13889</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801648</X>\r\n<Y>33.699785</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a82d27d0-a210-444f-9aff-ac844a42cd68</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801601</X>\r\n<Y>33.699663</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1c0cab97-e230-4568-908d-1148c152ca89</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801521</X>\r\n<Y>33.699438</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>72c4e3e0-ef37-4946-bebc-4c1b89facd65</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801428</X>\r\n<Y>33.699155</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>43a35d09-208c-4f0f-a3ac-7d30a041968b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801387</X>\r\n<Y>33.699012</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>34cde690-c203-4c03-bd91-626c81a06c89</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801359</X>\r\n<Y>33.6988929999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9634bcc7-5c5c-4257-b6e9-5ad1a3684cfa</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801328</X>\r\n<Y>33.698747</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d8fa6db9-c629-4864-84db-8435cbf622b3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801283</X>\r\n<Y>33.698478</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c15ae44c-30aa-4b01-b8bc-863716fa3d75</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801236</X>\r\n<Y>33.697918</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b5771718-9237-4c54-954c-9342cd8d57af</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801202</X>\r\n<Y>33.69753</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2383ae30-330b-43e1-a902-36d3c84a3afc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801147</X>\r\n<Y>33.697002</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>92189786-612f-4369-989c-96e53d724075</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801105</X>\r\n<Y>33.696779</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>bdb60a36-9c4d-4080-a1fd-48f03c8aee1a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80106</X>\r\n<Y>33.696533</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1022a009-798f-4c1d-8cf3-b7c42c88089f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80095</X>\r\n<Y>33.696205</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>bea3a997-c2fe-4cbe-a717-5c8fe6639b99</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800904</X>\r\n<Y>33.696069</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c2ba0e32-8f85-437d-9407-33fb87665806</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800862</X>\r\n<Y>33.695949</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>be9fdda7-bd68-4a70-b8e3-c5a40cb79f5c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800759</X>\r\n<Y>33.695709</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2a1b2254-c9a5-40e3-9537-a6b7b10d246d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80061</X>\r\n<Y>33.695402</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3ea4eb96-8786-4f8d-965c-20f4b852a0f6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800456</X>\r\n<Y>33.695184</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6d0726b7-6bd6-44b4-b488-96d91e14593b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800347</X>\r\n<Y>33.695028</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>afa62402-8a30-4281-9641-77a0460a0e6f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800299</X>\r\n<Y>33.69496</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>51b3bb8a-8d56-4d75-8c11-be5760d5c6f5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800115</X>\r\n<Y>33.694732</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8a9c7b5c-0b38-4d3f-81f7-18d226d0b70a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799951</X>\r\n<Y>33.694557</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>43eb5947-9f02-4f6b-91cd-c132bc165390</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799753</X>\r\n<Y>33.694353</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>307773d3-e63f-496c-902f-abe4c6811b6c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799505</X>\r\n<Y>33.694135</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cd42664a-241f-40f8-b759-415caf162650</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799387</X>\r\n<Y>33.694042</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7562177c-5589-4176-aebd-97b2282a6c1a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799311</X>\r\n<Y>33.693983</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>70b73f37-ea50-4c30-9f41-958065f4411d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799014</X>\r\n<Y>33.693755</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b2e7e23f-59d6-41e4-9d41-e942c56290d8</Key>\r\n<Selected>false</Selected>\r\n<X>-117.798879</X>\r\n<Y>33.693635</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>dee4dfbb-6cf5-4718-b71a-7cfb658f1ccd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799764</X>\r\n<Y>33.692775</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3e8f78f1-927d-43e9-953f-178ff1387259</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799844</X>\r\n<Y>33.692697</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>fca9211c-d344-4f6f-9de8-25565ec3e6db</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800813</X>\r\n<Y>33.691727</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>275ee723-cfd3-48d6-ad1f-deabe8ef4dbc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801724</X>\r\n<Y>33.690766</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cd67668b-8768-46c0-b94a-55fa3bd6b780</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802206</X>\r\n<Y>33.690275</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7abf62cd-38b4-4462-896d-730e021765d0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803582</X>\r\n<Y>33.688919</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>032b8c39-87fa-4fc9-9d28-36bfc126b6dd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804</X>\r\n<Y>33.688521</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>42920abb-06c1-4dbe-b96c-5cb611124fc0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804071</X>\r\n<Y>33.6884509999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3532aeae-ab59-498b-b0d3-22a954241663</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804093</X>\r\n<Y>33.688428</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b4fbe2e3-f93c-4a14-a71d-6e6dd6d7b45d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804435</X>\r\n<Y>33.688082</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a8b77b65-c02d-4ed2-858a-6c491c37cfde</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804988</X>\r\n<Y>33.687509</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e1c35eca-2dae-45be-b4c3-0d087a1fef41</Key>\r\n<Selected>false</Selected>\r\n<X>-117.807396</X>\r\n<Y>33.685106</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>06f2a9b4-e4da-4698-87ad-26eaa876ee22</Key>\r\n<Selected>false</Selected>\r\n<X>-117.807782</X>\r\n<Y>33.684703</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>69a9b4a1-9f5f-4eec-9fe4-dbbeaefe2ada</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808288453082</X>\r\n<Y>33.6842052956277</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ff6abee9-5261-42ba-bee0-6adacb623ee6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808295</X>\r\n<Y>33.68421</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>eaf2779d-0552-49a2-9bff-155cd05508b3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808621</X>\r\n<Y>33.684437</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1f3de9d4-14a8-4037-9ce4-03f09e5419f8</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808715</X>\r\n<Y>33.684495</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5df963c2-1cc7-4f2d-9739-7cb67ac47272</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808955</X>\r\n<Y>33.684655</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>88a57ef2-4eb4-426c-be21-a27c77a907a6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809204</X>\r\n<Y>33.684822</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>787e8f61-292e-4cd1-88bb-aa1a84ee0cad</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809268</X>\r\n<Y>33.684876</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a4bf4ad2-3006-42b5-b58d-747e607f2345</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809785</X>\r\n<Y>33.685238</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>097b95dd-8a88-4635-854b-b5d10046a425</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809844039579</X>\r\n<Y>33.6852787763627</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8f4bff98-abf3-4f16-a851-f1158022d376</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810145</X>\r\n<Y>33.685491</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>42d3f68e-2899-42bc-97be-dd7c4727954e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810369</X>\r\n<Y>33.685647</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>44566237-29f2-4b7e-a3d7-125b35e9ce66</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810552</X>\r\n<Y>33.685763</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e6e0047b-bce0-4b91-85a9-8ec1e12d9441</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810876</X>\r\n<Y>33.685956</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>05d8c138-4a59-402e-b0c5-d39a3ba7b668</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810971690887</X>\r\n<Y>33.6860055665026</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4733ca0f-ed59-4445-9f78-3e59399bb311</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811213</X>\r\n<Y>33.686138</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>dc471106-9ae3-493e-a19f-9c27565bcba1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811697</X>\r\n<Y>33.686346</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c185bc5f-ccdc-4255-a552-caca7bb785ae</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812146</X>\r\n<Y>33.686504</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2b557954-6f0d-4479-a046-f85291548232</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812155</X>\r\n<Y>33.686511</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7a9039e2-94a4-4576-a5fb-fad125cde0b4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812327</X>\r\n<Y>33.686562</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>df8dbb43-c3a9-465d-a4d9-70baeea946cd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812876</X>\r\n<Y>33.686699</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>64394331-bd33-49db-a341-a4faecd048a4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813246</X>\r\n<Y>33.686766</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f17f5f0e-2135-411e-8ad4-94d2de111ef7</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813495</X>\r\n<Y>33.686806</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5974c1ef-1af9-4189-a233-5635cb2ba412</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813758</X>\r\n<Y>33.686837</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1376704c-2f27-4b06-8f4d-0d803e178334</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814326</X>\r\n<Y>33.686901</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>181dd73a-9503-4a97-b922-56c227831d84</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814795</X>\r\n<Y>33.686957</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>94532c98-a6c6-4a91-9c03-c85e51f8ae1f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815018</X>\r\n<Y>33.686992</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>206a654c-1433-4d6c-8e6a-f5a16dfbe4e6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815233</X>\r\n<Y>33.687028</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6bdec62c-076e-439f-ba3c-6c831cf25cac</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815268</X>\r\n<Y>33.687037</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1515bd2d-2d05-4b46-9eb6-2f5697832580</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815506</X>\r\n<Y>33.6870799999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ae7d8dc4-93c8-4e2a-9f95-d33dc0b2da33</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815736</X>\r\n<Y>33.687143</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>77d8839a-1fcd-422b-a4d4-ec3e7d361b60</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815795</X>\r\n<Y>33.687158</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>fd9da51c-fe05-4651-8b1f-f2b30e8e626a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.81597</X>\r\n<Y>33.687201</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>60b0cda0-8ae7-464a-8945-846886ca90ed</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816144357461</X>\r\n<Y>33.6872548140311</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a3ef4b68-e299-4ca5-a92a-33edf10c5ac5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816347</X>\r\n<Y>33.687327</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9e9fe747-0ea5-4eb3-9abf-8e4792a147ef</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816604</X>\r\n<Y>33.687429</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5ca05ab3-59ce-41a7-966a-3421d4cf1ff6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816861</X>\r\n<Y>33.687544</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>379166d0-c8bd-4031-836d-7d435ff1f496</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816853445944</X>\r\n<Y>33.6875406197805</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5afb679b-bc5c-4e97-8c54-2a588dcff366</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817058</X>\r\n<Y>33.687659</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9b79fa17-4399-4624-9515-145f9775ade4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817185</X>\r\n<Y>33.687733</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>40edd12b-f6b1-4f60-b890-683f5e1bd123</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817459</X>\r\n<Y>33.687884</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c11d847c-6810-4112-b16c-fd025425123b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817575</X>\r\n<Y>33.687957</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cd57b4ba-b57b-4317-ac34-09fa9e2e9269</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817708</X>\r\n<Y>33.688034</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c4e5c18b-7ca1-4517-bd72-279ca19f6538</Key>\r\n<Selected>false</Selected>\r\n<X>-117.818039</X>\r\n<Y>33.688251</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>66eb9561-a756-4b8c-9a2f-98c172b68075</Key>\r\n<Selected>false</Selected>\r\n<X>-117.818512</X>\r\n<Y>33.688569</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8f468080-71ab-42ba-a53d-c6cbd4494327</Key>\r\n<Selected>false</Selected>\r\n<X>-117.818054</X>\r\n<Y>33.689006</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>22302516-c683-4d66-af33-2cee5b3e0565</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817638</X>\r\n<Y>33.689417</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1e9dafd0-190d-43d0-9d86-471def0e6d09</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817527</X>\r\n<Y>33.689517</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8cf8bad3-2603-406c-b3a2-2cfa0ef831cc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.81674</X>\r\n<Y>33.690283</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>da454616-a661-4db1-8be8-6d4702df0035</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816235</X>\r\n<Y>33.690764</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>594919ee-ebf5-4ee4-a2cd-f513f34b2025</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815403</X>\r\n<Y>33.691483</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b7988ed7-6c6b-49e8-b5a1-96e9a945a37a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815288</X>\r\n<Y>33.6915669999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>031d9c63-2171-4462-a417-78cdba3ab85c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815164</X>\r\n<Y>33.691656</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f578f3bd-4318-47a0-bd01-0313e4c3a505</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814841</X>\r\n<Y>33.691855</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4553e92f-de96-4a44-8c3b-b02633705507</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814713</X>\r\n<Y>33.691928</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e01db1b7-c5da-47b5-b216-c2ba4743ab94</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814589</X>\r\n<Y>33.691987</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>26f65655-86ab-4d82-a885-a610ec3550f3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814044</X>\r\n<Y>33.692223</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3a35fa49-4e38-4b70-9e99-d46dd64bbea8</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813826</X>\r\n<Y>33.692293</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cf6532e5-50e9-4489-881a-b2401c325d19</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813765</X>\r\n<Y>33.692321</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0066c42e-404a-4827-9880-f067c12ed815</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813482</X>\r\n<Y>33.692403</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4fe57f72-ec0d-49d0-85c0-6f64132a0703</Key>\r\n<Selected>false</Selected>\r\n<X>-117.81318</X>\r\n<Y>33.692482</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b6ad5473-24c3-4986-9ff9-de900308626c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812631</X>\r\n<Y>33.692615</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>532f12b6-a1ab-4388-b89a-9503625b55de</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812418</X>\r\n<Y>33.692645</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4618e496-df77-4398-b025-181d36545198</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812074</X>\r\n<Y>33.69272</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f4d17df2-d2c3-4620-880c-f91e60d5287f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811938</X>\r\n<Y>33.692746</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1d374f0a-a35b-4dc8-be40-784db2c051b3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811807</X>\r\n<Y>33.69278</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ea6dfe86-d047-4ef8-bc36-a60a7be1d9b1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.81158</X>\r\n<Y>33.6928439999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>dee92564-658f-454e-b551-347f904b85ea</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811467</X>\r\n<Y>33.692886</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e8f21dd2-11f1-4daf-88b2-2ad8789a9bb1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811218</X>\r\n<Y>33.692976</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3a7a4555-3eaf-4746-95a5-12a2c0fe3184</Key>\r\n<Selected>false</Selected>\r\n<X>-117.81091</X>\r\n<Y>33.693097</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>52f032b6-6ca5-4a9d-9133-43817a8a2530</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810851</X>\r\n<Y>33.693123</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c14f1fe4-24df-422b-8346-a5a95391b527</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810661</X>\r\n<Y>33.69321</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a20b74f1-8d92-4a4b-a6dc-a02a02a78c6e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810552</X>\r\n<Y>33.6932659999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a3ab7e0b-64a7-4c5b-8760-a27bc3207898</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810488</X>\r\n<Y>33.6933</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ad7c15c4-dbc7-4c6f-889f-6988c186d31c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810267</X>\r\n<Y>33.693432</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9ff74365-1c75-4898-95c0-4d3009490682</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810058</X>\r\n<Y>33.693572</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6fbda098-fff9-4db3-9093-722d66447fc1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.8099</X>\r\n<Y>33.693688</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ec35f282-a4bf-48f6-bdd0-6a8aa6637677</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80956</X>\r\n<Y>33.693963</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5bc1c46f-54ed-4452-96c6-c0fbd9e7f9c0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809533</X>\r\n<Y>33.69399</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>548c528f-2485-4ba8-b65e-fe0230daa6f4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809216</X>\r\n<Y>33.694295</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>78110c18-f075-41df-ad99-6c5f6d2c14b2</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809071</X>\r\n<Y>33.694434</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3349361c-5bf9-49c8-b9c6-c9a86baad3ea</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808509</X>\r\n<Y>33.694993</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>15da1c11-5ceb-42ac-86a3-aa3ddc41f6cd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808356</X>\r\n<Y>33.695147</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a8c2c1aa-f963-4262-8a7e-dc2921ef133a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808225</X>\r\n<Y>33.6952709999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>16b6284c-c935-4e62-8026-c9533f9bb5f6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.807733</X>\r\n<Y>33.695774</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c2b89c0c-266c-4011-bede-e451f2c8ea95</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805446</X>\r\n<Y>33.698162</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1bfc461a-48c9-457d-a9b4-bfbf76e0beef</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805401</X>\r\n<Y>33.698176</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0b0ce50f-8471-44aa-94e3-40db1e82393d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805358</X>\r\n<Y>33.698254</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e00118e3-6371-47bb-997b-db1f19a056b1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805143</X>\r\n<Y>33.698462</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6aa11525-452c-492c-95aa-a853c03ac1a1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803307</X>\r\n<Y>33.700278</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>51eb8fa4-d7d7-455b-b233-ad0d9c842624</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802858</X>\r\n<Y>33.700732</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>10d26bbf-3f50-4a73-9d59-785d4d8feb9d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802725</X>\r\n<Y>33.700768</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e3ec4bea-77e4-4423-8ae0-c066c7c3f290</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802609</X>\r\n<Y>33.700882</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1fab947d-07df-445a-ace4-3e953b6f171c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80255</X>\r\n<Y>33.70095</Y>\r\n</PointShape>\r\n</Points>\r\n</MultiPoint>\r\n</Parts>\r\n</Polygon>\r\n"
"<?xml version=&#34;1.0&#34;?>\r\n<Polygon xmlns:xsd=&#34;w3.org/2001/XMLSchema&#34; xmlns:xsi=&#34;w3.org/&#34;>\r\n<Key>3d279dfc-c641-4d76-83ae-e754b56df198</Key>\r\n<Selected>false</Selected>\r\n<Parts>\r\n<MultiPoint>\r\n<Key>0808e616-5cd7-41ba-a426-327ab365d339</Key>\r\n<Selected>false</Selected>\r\n<RingType>OuterRing</RingType>\r\n<RingOrder>ClockWise</RingOrder>\r\n<Points>\r\n<PointShape>\r\n<Key>8abfe76e-db1d-4f42-a25f-b1428be2ccf3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.860436</X>\r\n<Y>33.650284</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e8cc9c7a-e027-437a-8f3f-dcc449e61494</Key>\r\n<Selected>false</Selected>\r\n<X>-117.859998</X>\r\n<Y>33.6503559999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3d1548cc-92cb-4e27-be71-70d5de4c702a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.859872</X>\r\n<Y>33.650367</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9d8111c6-88aa-4cd3-9512-57a5b0151dc1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.859742</X>\r\n<Y>33.650377</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>16931375-f4e1-4d4f-9bd5-8759849954dd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.859716</X>\r\n<Y>33.650384</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>788623ac-6212-4a0d-8d9b-f4e1e96aabfb</Key>\r\n<Selected>false</Selected>\r\n<X>-117.859523</X>\r\n<Y>33.650395</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>633eb3aa-d802-4a91-927b-2c4c9d90dc29</Key>\r\n<Selected>false</Selected>\r\n<X>-117.859127</X>\r\n<Y>33.650426</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5e011429-842a-4e46-80c6-6c30559c9e14</Key>\r\n<Selected>false</Selected>\r\n<X>-117.858782</X>\r\n<Y>33.650441</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>767fd82a-db20-402a-9258-437d32e664d2</Key>\r\n<Selected>false</Selected>\r\n<X>-117.858541</X>\r\n<Y>33.650454</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a4607f10-56ce-4cc6-a546-ea974af064bc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.857821</X>\r\n<Y>33.650494</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>782a9dc1-a925-4ea1-b107-527241c42380</Key>\r\n<Selected>false</Selected>\r\n<X>-117.85668</X>\r\n<Y>33.650553</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>86d73ff3-c55b-4b44-bda5-80953d00c396</Key>\r\n<Selected>false</Selected>\r\n<X>-117.856419</X>\r\n<Y>33.650576</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>44d725e5-3bf3-4a22-9232-da6b519d7819</Key>\r\n<Selected>false</Selected>\r\n<X>-117.855816</X>\r\n<Y>33.65063</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>74a1a37a-c28c-4274-8135-8d3b6474bf23</Key>\r\n<Selected>false</Selected>\r\n<X>-117.855083</X>\r\n<Y>33.650688</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>79f04ee1-7afb-4752-a0ce-d0e1e85d92b4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.854447</X>\r\n<Y>33.650746</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e6c9c753-d0b6-4c85-981d-9c595d05b7f6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.853606</X>\r\n<Y>33.650828</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a7cd5078-19ff-4895-886d-57cbfd388da8</Key>\r\n<Selected>false</Selected>\r\n<X>-117.853506</X>\r\n<Y>33.6508379999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4acc59a6-df42-445b-8e39-57cae6f88071</Key>\r\n<Selected>false</Selected>\r\n<X>-117.853412</X>\r\n<Y>33.650847</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>fb535472-82cf-456b-86a6-834d37e89be6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.853039</X>\r\n<Y>33.650885</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d069eff2-6532-4a6c-bac5-d0bc1e130339</Key>\r\n<Selected>false</Selected>\r\n<X>-117.85202</X>\r\n<Y>33.651047</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>bd75c509-2ba0-4fd7-b336-04730cfdc2b1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.851588</X>\r\n<Y>33.651135</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2c5d35ab-3def-4db0-93fc-4e6d10fbc8ff</Key>\r\n<Selected>false</Selected>\r\n<X>-117.851191</X>\r\n<Y>33.651228</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2ffd434d-dac7-4b06-b17c-a8f32346fc44</Key>\r\n<Selected>false</Selected>\r\n<X>-117.850304</X>\r\n<Y>33.651494</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6d40286d-a185-4b1e-8be5-ba2c41a04aec</Key>\r\n<Selected>false</Selected>\r\n<X>-117.849779</X>\r\n<Y>33.651682</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c0e6ed8f-4041-4c13-85b2-b2b87c753fd8</Key>\r\n<Selected>false</Selected>\r\n<X>-117.849259</X>\r\n<Y>33.651883</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cb5d0578-d6c3-4cf2-aedb-7285c0baee13</Key>\r\n<Selected>false</Selected>\r\n<X>-117.848684</X>\r\n<Y>33.652133</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cf3ac26d-eafe-4159-920e-6311e5a59cea</Key>\r\n<Selected>false</Selected>\r\n<X>-117.848214</X>\r\n<Y>33.652376</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ea466949-813d-4665-96b8-c60e762ea0f0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.847512</X>\r\n<Y>33.652777</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>41897bc6-0559-4562-9427-c07547721a51</Key>\r\n<Selected>false</Selected>\r\n<X>-117.847168</X>\r\n<Y>33.653005</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f4fc092e-602f-4c31-8406-1e796efa7abd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.84709</X>\r\n<Y>33.653058</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6430b128-f923-4185-9ebb-c3f1c8ce1655</Key>\r\n<Selected>false</Selected>\r\n<X>-117.846875</X>\r\n<Y>33.653212</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0a229b61-77f8-450c-bef4-b9a60c8e1f47</Key>\r\n<Selected>false</Selected>\r\n<X>-117.846217</X>\r\n<Y>33.653744</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c529e6c8-7546-4d64-85ef-b636616db557</Key>\r\n<Selected>false</Selected>\r\n<X>-117.846019</X>\r\n<Y>33.653919</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e392df89-0665-4e58-8b6e-b539a2cd14fc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.845938</X>\r\n<Y>33.653991</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>eae42d5f-5e30-4f36-a9ee-02b65010ed4e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.845197</X>\r\n<Y>33.654696</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4fa9d146-4f50-462d-8e6e-2446abd4dea4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.844881</X>\r\n<Y>33.654998</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4b0bad66-0462-4711-827d-d193a81c025b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.844829</X>\r\n<Y>33.6550469999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f34b527b-d7a2-4642-82ce-15172a20611d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.844228</X>\r\n<Y>33.655616</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8c864645-cb73-49c7-9342-a939f230805a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.843735</X>\r\n<Y>33.656076</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>71cf35df-db34-4e85-b6e7-731ca64c2c2f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.843657</X>\r\n<Y>33.656153</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>975aac1c-a8da-4d10-b5fb-700865c09eef</Key>\r\n<Selected>false</Selected>\r\n<X>-117.843479</X>\r\n<Y>33.656318</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c4999df9-4e8a-4c32-8c5a-bbf04c8f3fcf</Key>\r\n<Selected>false</Selected>\r\n<X>-117.843269</X>\r\n<Y>33.656502</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>03a3c6c8-0afa-49fa-b35c-8c44652f9e60</Key>\r\n<Selected>false</Selected>\r\n<X>-117.84306</X>\r\n<Y>33.656662</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>aabce6fd-f3cb-4328-a890-f1e2c1c25fc5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.842876</X>\r\n<Y>33.656781</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>02e69cc5-d7bb-4edf-a1c2-43e3689dbda9</Key>\r\n<Selected>false</Selected>\r\n<X>-117.842737</X>\r\n<Y>33.656881</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>73e11327-3aa1-412c-ab7e-7d16cca932c3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.842544</X>\r\n<Y>33.657</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ed9cd0de-5b58-4ad5-945c-1236ed2597e7</Key>\r\n<Selected>false</Selected>\r\n<X>-117.842288</X>\r\n<Y>33.657136</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>09136d0a-5762-4b72-9129-8dc5033ef60b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.842204</X>\r\n<Y>33.657181</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>db6dfcdf-f7be-4f18-a033-7386bd71e99e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.841861</X>\r\n<Y>33.657324</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>248566ca-c8d4-4cb2-9006-fafb7244dab0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.841595</X>\r\n<Y>33.65742</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ed46527d-f33f-4523-8421-acbcd802b7b2</Key>\r\n<Selected>false</Selected>\r\n<X>-117.84128</X>\r\n<Y>33.657521</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c2801a2f-f880-483a-889c-6f1e1cd57697</Key>\r\n<Selected>false</Selected>\r\n<X>-117.840955</X>\r\n<Y>33.657582</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>bd461bae-82fd-4767-876f-8c8ba3dd3539</Key>\r\n<Selected>false</Selected>\r\n<X>-117.840677</X>\r\n<Y>33.657633</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b0912694-7223-406c-bc46-8693b03b89b3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.840523</X>\r\n<Y>33.657659</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>33eff8b5-bc81-4638-ac00-421149303d9b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.8403</X>\r\n<Y>33.657679</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6630bd8e-cf9e-4733-8ae9-28354a88db43</Key>\r\n<Selected>false</Selected>\r\n<X>-117.840075</X>\r\n<Y>33.65769</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1fdc1f90-aeb8-4253-b117-95cb87822761</Key>\r\n<Selected>false</Selected>\r\n<X>-117.839843</X>\r\n<Y>33.657699</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>25159457-d9f2-40dd-88d7-e1b6546b771f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.839685</X>\r\n<Y>33.657697</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1e1a98fc-6514-4e40-9a0b-ae2069b69831</Key>\r\n<Selected>false</Selected>\r\n<X>-117.839589</X>\r\n<Y>33.657697</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f47ac0cb-48a6-4281-b1b9-da019ae63f76</Key>\r\n<Selected>false</Selected>\r\n<X>-117.839224</X>\r\n<Y>33.657688</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e33108e3-9e9d-4747-a681-bae9bdcc8259</Key>\r\n<Selected>false</Selected>\r\n<X>-117.839131</X>\r\n<Y>33.657683</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2b7bd298-9da0-495b-94a6-6abfbafde82f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.838799</X>\r\n<Y>33.657675</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c938120e-1e80-4690-a3b6-41e2bff2fcc2</Key>\r\n<Selected>false</Selected>\r\n<X>-117.838537</X>\r\n<Y>33.657658</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6f390e9a-9f6b-4560-817d-3bf08ddc6232</Key>\r\n<Selected>false</Selected>\r\n<X>-117.838199</X>\r\n<Y>33.657639</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ade62812-04f1-4492-abc8-36e9b354f310</Key>\r\n<Selected>false</Selected>\r\n<X>-117.838036</X>\r\n<Y>33.65763</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>dd4d0da5-0689-4dbd-8d1d-a371ea6c75d9</Key>\r\n<Selected>false</Selected>\r\n<X>-117.83779</X>\r\n<Y>33.657624</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>808a6d4b-b0e8-4ee9-b45c-ca2db0e91275</Key>\r\n<Selected>false</Selected>\r\n<X>-117.837611</X>\r\n<Y>33.657617</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9ad94622-28c7-425c-a5b3-289d7ce40fe5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.835829</X>\r\n<Y>33.657586</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>eab082a2-479c-4703-a8c4-71cbaad30b4a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.834636</X>\r\n<Y>33.657581</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>20dd0c66-337b-491d-8205-f8f65f83e4d4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.834039</X>\r\n<Y>33.657578</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>51acfd7d-dd6b-4fff-a8ac-94721bfb4a6f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.831506</X>\r\n<Y>33.657523</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f9eeaff5-e6fb-42f7-a5c5-b138941f9b37</Key>\r\n<Selected>false</Selected>\r\n<X>-117.830541</X>\r\n<Y>33.657497</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0de72ede-8404-4d00-8868-bc88cc886a82</Key>\r\n<Selected>false</Selected>\r\n<X>-117.829731</X>\r\n<Y>33.65747</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>481b3a66-6f41-4901-b1b4-526ddb6afd0e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.828357</X>\r\n<Y>33.657428</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1ecfbc63-a7b1-427e-b323-e75f9605eb68</Key>\r\n<Selected>false</Selected>\r\n<X>-117.827896</X>\r\n<Y>33.657417</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f19a88b0-798f-4b97-ad9c-e4c1ef6e5377</Key>\r\n<Selected>false</Selected>\r\n<X>-117.82771</X>\r\n<Y>33.657413</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6d7d4fdc-6bd9-4e48-b726-ee15a4931b14</Key>\r\n<Selected>false</Selected>\r\n<X>-117.826975</X>\r\n<Y>33.657403</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1621f7d6-dc26-45d9-82b2-d569c74d5e48</Key>\r\n<Selected>false</Selected>\r\n<X>-117.826291</X>\r\n<Y>33.657379</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d7e7ae3a-8a0c-4f78-b304-0990204b1224</Key>\r\n<Selected>false</Selected>\r\n<X>-117.825883</X>\r\n<Y>33.657369</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8ef054c8-90e2-4224-a593-126d8093ffab</Key>\r\n<Selected>false</Selected>\r\n<X>-117.825596</X>\r\n<Y>33.657362</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ce9c6628-63a7-4b90-add5-ca227f6300d3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.825003</X>\r\n<Y>33.657352</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a1858c2c-7d71-4cc2-a296-f872fa64cd7f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.823835</X>\r\n<Y>33.657322</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>08bda92f-a444-4684-b923-d90843579591</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822418</X>\r\n<Y>33.657273</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>34f8d165-9e85-4dbf-be69-6560c5363fb8</Key>\r\n<Selected>false</Selected>\r\n<X>-117.821938</X>\r\n<Y>33.657288</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7451114b-ff7a-48f4-bdb1-90a31f95467e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.821606</X>\r\n<Y>33.657308</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0bd6927e-5499-43a7-9f8e-653402ec309d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.821405</X>\r\n<Y>33.657332</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d4655fab-6586-4982-935c-0a0689a222a5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.821262</X>\r\n<Y>33.657352</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>99fadf57-d916-4e81-9cb8-d241b96c0f84</Key>\r\n<Selected>false</Selected>\r\n<X>-117.820782</X>\r\n<Y>33.657441</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>38f34fbc-64a3-4872-8af4-2b8a10a931f3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.820426</X>\r\n<Y>33.65751</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ad63cd83-05f1-4766-a884-cc8c5a75b8bf</Key>\r\n<Selected>false</Selected>\r\n<X>-117.82013</X>\r\n<Y>33.657584</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c54868df-0ade-4602-9225-8a4abd0867d5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.819875</X>\r\n<Y>33.657663</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f58bf8ce-4a70-459d-945b-ef44cd0d15dd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.819251</X>\r\n<Y>33.657921</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>73d96250-0db3-4b50-97f2-9b3db7bde485</Key>\r\n<Selected>false</Selected>\r\n<X>-117.818617</X>\r\n<Y>33.658212</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f350d70d-b744-478f-8ddc-eab86361bbfb</Key>\r\n<Selected>false</Selected>\r\n<X>-117.81816</X>\r\n<Y>33.658422</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5155d12b-47da-49fc-a487-a71faafdbc17</Key>\r\n<Selected>false</Selected>\r\n<X>-117.818091</X>\r\n<Y>33.658449</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>799bdc7d-650e-4f6c-9991-aa59bd106de9</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817867</X>\r\n<Y>33.658538</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f5562999-fc87-424f-a78e-17cd34619841</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817589</X>\r\n<Y>33.6586149999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>66eccbf9-51f8-4744-93b7-85242ddfeddd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817223</X>\r\n<Y>33.658673</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f4b03f8e-8cc9-4aeb-ad49-e5215d86dc96</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816737</X>\r\n<Y>33.658727</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>59ce52b1-5ede-46f0-986d-44806dbea57e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816335</X>\r\n<Y>33.658734</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5cd8c417-204f-4d8c-8281-1f28f46c6549</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816008</X>\r\n<Y>33.658715</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cf620e53-b7ce-4c65-bdbd-c3cfcb995a5c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.81573</X>\r\n<Y>33.658677</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>56418335-d78a-4649-8643-99928cb9d7d9</Key>\r\n<Selected>false</Selected>\r\n<X>-117.81534</X>\r\n<Y>33.658596</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>49ea917b-8fc4-408b-a674-7fc870b07d99</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815059</X>\r\n<Y>33.658519</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>379ecb5d-1615-4c45-a20b-2f23a211c6be</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814727</X>\r\n<Y>33.6584069999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c576a7e4-60a4-468c-8a32-61fd8e01dbbb</Key>\r\n<Selected>false</Selected>\r\n<X>-117.81448</X>\r\n<Y>33.658296</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>bd33b755-bd9d-42a5-99af-0353cecdfdfa</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814365</X>\r\n<Y>33.658246</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0317e44f-2751-47d1-b7d0-217e0b630ff0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814253</X>\r\n<Y>33.6581989999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ea1ae2d3-e956-44fa-92a1-dae1756d84ad</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814098</X>\r\n<Y>33.658123</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c29098cc-5c30-4538-89f7-2083117941d9</Key>\r\n<Selected>false</Selected>\r\n<X>-117.81402</X>\r\n<Y>33.658085</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2afbb5c3-e990-420e-aa0a-95b9f583d6ba</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813732</X>\r\n<Y>33.657944</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e70dfd32-5cdb-4c93-aef9-e094f6b4274c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813412</X>\r\n<Y>33.65781</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0ccdee3e-eede-4350-9a5c-a1f706b43c23</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813053</X>\r\n<Y>33.657679</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>165b2f7e-8668-478d-84f0-bf19fc79a0c6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812864</X>\r\n<Y>33.657632</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9839d24b-f9ea-4889-9329-16db83ce459a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812504</X>\r\n<Y>33.657564</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ec0872d6-44f9-4a32-a7d6-a6587489acf6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812395</X>\r\n<Y>33.657542</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ee4a3387-f5a4-4866-b186-2d3edba4e2b3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812244</X>\r\n<Y>33.657514</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>de143a95-02cd-4528-ace1-96927d206601</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812111</X>\r\n<Y>33.657503</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0d26d772-84d7-4f39-8d26-1148385aadf4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811968</X>\r\n<Y>33.657492</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>615a4633-ee26-4617-b59b-0c1681e6f532</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811835</X>\r\n<Y>33.657489</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8addf48a-5169-4f7d-a5a4-d41232beaadf</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811656</X>\r\n<Y>33.657492</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>969d4fec-7ebe-44fc-98d8-aaf18014807a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811494</X>\r\n<Y>33.657499</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a058b357-9ea5-443e-82b2-832e0d9ebaf9</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811351</X>\r\n<Y>33.65751</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d294961e-44a0-4483-a07b-fe7e99730b9a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811172</X>\r\n<Y>33.657525</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e35806ee-e85c-4776-966b-78601567da4b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810946</X>\r\n<Y>33.657557</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>70e6ff5d-65b0-4a14-b4a2-a21ef31efe64</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810729</X>\r\n<Y>33.657596</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>21bc72aa-c7ed-4d93-a850-92443a8a049b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810469</X>\r\n<Y>33.657654</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>06976521-7bed-4d2c-8ec3-fd201aa0f870</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810245</X>\r\n<Y>33.657725</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9f5cafc5-6465-4b59-bd81-54889e6ec59a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810024</X>\r\n<Y>33.657799</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4f086534-bb03-4202-a698-66be21814e46</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80973</X>\r\n<Y>33.657913</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e9389ef8-0577-4cb2-834c-3060421b766e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809439</X>\r\n<Y>33.658014</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cf905f3f-fe61-4825-a83c-cacd1f7859ee</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809192</X>\r\n<Y>33.6581</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3f0c8806-77f2-4970-a9c8-6dc97e2302df</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808933</X>\r\n<Y>33.658186</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7b7fea2f-d86e-47e3-b6a6-15e30aac2fe1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808707</X>\r\n<Y>33.658257</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c7a0967c-10be-4272-8260-702af7122d22</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808453</X>\r\n<Y>33.658327</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>02d98b4c-6f16-4fc6-be50-ba9be4430879</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808252</X>\r\n<Y>33.658378</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>facc5d5e-8f1d-4492-8883-8bd9e9b92fcb</Key>\r\n<Selected>false</Selected>\r\n<X>-117.808054</X>\r\n<Y>33.658406</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a31d63ec-d246-4018-849e-cd7afaa01314</Key>\r\n<Selected>false</Selected>\r\n<X>-117.807978</X>\r\n<Y>33.658417</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>78c3a0f0-1096-4727-a659-cb301e4d5682</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80782</X>\r\n<Y>33.658433</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d28fba42-861e-4a46-8ed5-9fb047f83772</Key>\r\n<Selected>false</Selected>\r\n<X>-117.807428</X>\r\n<Y>33.658479</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8b4b6744-3b92-4446-8e31-9b4cdabe4751</Key>\r\n<Selected>false</Selected>\r\n<X>-117.807319</X>\r\n<Y>33.658478</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>197fe438-eeab-4533-8cdf-72114dfac438</Key>\r\n<Selected>false</Selected>\r\n<X>-117.807248</X>\r\n<Y>33.658475</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9abf7377-dbf7-4935-a972-3c0b8af6deb9</Key>\r\n<Selected>false</Selected>\r\n<X>-117.806997</X>\r\n<Y>33.658475</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7a3d1da0-2376-4b54-bfe7-f8bac3e4e605</Key>\r\n<Selected>false</Selected>\r\n<X>-117.806721</X>\r\n<Y>33.658461</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2337aa45-7b86-4e10-9991-ef111dc428cd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.806454</X>\r\n<Y>33.658443</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>83078c52-e7a5-4938-a9d7-59746a1bf3f5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.806049</X>\r\n<Y>33.658409</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e5ac5a7d-1f0d-4f6e-b8c9-fd4d3b68f471</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805681</X>\r\n<Y>33.658374</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f4b2a0b7-7631-4c27-aae2-444e118141b3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805284</X>\r\n<Y>33.658336</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>918347c4-ca61-4fd7-b68d-f41584149b8c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804887</X>\r\n<Y>33.6582969999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>82b766ba-360e-4314-9eb2-868fbf58fce1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804549</X>\r\n<Y>33.65827</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ed5cb76e-cee8-481a-bb3f-a481b5d9286b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804369</X>\r\n<Y>33.658263</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5342b71b-f719-4ef9-8956-50c791d9af2c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804052</X>\r\n<Y>33.658261</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>01616c06-e82e-4c0e-ab1a-8f859b9adef9</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803662</X>\r\n<Y>33.658261</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4207a7eb-24ee-4142-8bc3-42e2fb0d2453</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803345</X>\r\n<Y>33.65828</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0b3dfedd-8a84-47f1-94f8-e282dc2b2f05</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803097</X>\r\n<Y>33.658293</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>449f76a0-8a0d-4bc0-ac21-02121dfc8f0b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802792</X>\r\n<Y>33.658317</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9188c68a-2744-4262-9ec8-9397e6f01142</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802528</X>\r\n<Y>33.65836</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7a656cda-29cf-4cad-b20a-51bb6ab6854f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80219</X>\r\n<Y>33.658421</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>26adbe0d-287a-459a-baf1-7dccb42c47b9</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801909</X>\r\n<Y>33.658481</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ed8ebab1-7263-4cd2-90a9-4e93ef3ae417</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801609</X>\r\n<Y>33.658551</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1ecb04bc-6764-443e-951b-4bc6ef01bebe</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801543</X>\r\n<Y>33.65857</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>86e68664-1fc5-4b30-b5bf-73c7d77220fb</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801486</X>\r\n<Y>33.658588</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2e8b6914-09bd-46eb-be60-14f33217dae7</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800999</X>\r\n<Y>33.65872</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>69a2b9dc-986e-4863-b309-14b95b1a170b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800852</X>\r\n<Y>33.658774</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>acd7f133-da60-4ad3-977b-4382d555bbb1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80063</X>\r\n<Y>33.658856</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0a02bdc5-c1cc-4ac0-911f-dff49647cb9c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800548</X>\r\n<Y>33.65889</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3104e575-4a4d-490d-a3bb-f2fa1afd147f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.8003</X>\r\n<Y>33.658992</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>93b2996f-be96-4146-9851-68f854637587</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800173</X>\r\n<Y>33.659051</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>52572b89-6f85-4ac1-8e2e-7ae6dcd9dc69</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800056</X>\r\n<Y>33.659105</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1f3374b8-9f74-4862-b7e0-010cbc7ff9a5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799863</X>\r\n<Y>33.659196</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d4a098a0-b958-453c-a3d6-eb733bae11c7</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799714</X>\r\n<Y>33.659266</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2046e337-9772-4149-bee8-0bbc295fca22</Key>\r\n<Selected>false</Selected>\r\n<X>-117.79944</X>\r\n<Y>33.659428</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5815d944-5d6e-414f-85b2-e629f3711262</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799101</X>\r\n<Y>33.659636</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>783cfb40-89db-42d2-8a12-4588437f2dca</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799081</X>\r\n<Y>33.659649</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3cad942f-f361-4766-a2b7-95c524dfddda</Key>\r\n<Selected>false</Selected>\r\n<X>-117.798586</X>\r\n<Y>33.6599739999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>67ea429a-9a1f-4481-b509-94996655a967</Key>\r\n<Selected>false</Selected>\r\n<X>-117.798321</X>\r\n<Y>33.660171</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ed0d95f5-bde4-4f87-b01f-229df9a4782b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.798085</X>\r\n<Y>33.66037</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>bef4b216-f154-4c9f-a98b-f71deab558bd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.797821</X>\r\n<Y>33.660609</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a4d32902-c291-4ed6-a157-a6ad35ebe66a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.797738</X>\r\n<Y>33.66069</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>349077e9-32a4-4840-b362-c3d9b62f0914</Key>\r\n<Selected>false</Selected>\r\n<X>-117.79767</X>\r\n<Y>33.660756</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5f5ef3cd-b9d7-4e98-acac-370883e0999a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.797495</X>\r\n<Y>33.660915</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a1e052f6-3f83-4ad3-a5e9-d5fef18aed0a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.79729</X>\r\n<Y>33.661116</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>75b13ba5-01e6-4cad-9489-e65d03453126</Key>\r\n<Selected>false</Selected>\r\n<X>-117.797192</X>\r\n<Y>33.6612079999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ef09d9fe-ac56-48d7-b587-50601feee013</Key>\r\n<Selected>false</Selected>\r\n<X>-117.797057</X>\r\n<Y>33.661339</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a785d0d0-893f-4db4-90c4-e38cf46f6f86</Key>\r\n<Selected>false</Selected>\r\n<X>-117.796803</X>\r\n<Y>33.661594</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c585bece-f31a-48ae-8ace-7f07be84c816</Key>\r\n<Selected>false</Selected>\r\n<X>-117.796613</X>\r\n<Y>33.661779</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6ca12633-30ff-467e-b349-3b3b26b92cbd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.796553</X>\r\n<Y>33.661837</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b3d601ea-45f5-40c3-acc1-62381764457a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.79637</X>\r\n<Y>33.662026</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0c08d5bf-3a17-4dc2-9377-bf7b32dddaa0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.795936</X>\r\n<Y>33.662471</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>15cc2c08-4ac7-4830-83ff-17b9f8fd7bf5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.795891</X>\r\n<Y>33.662516</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>322f16da-5c27-4513-8731-6454fa70302a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.795758</X>\r\n<Y>33.662656</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>77ae4c02-d870-4b03-bb5c-b8fb6b99763d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.795714</X>\r\n<Y>33.662701</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9ae160f3-0bcb-439b-9ad4-ba614db0e2f9</Key>\r\n<Selected>false</Selected>\r\n<X>-117.795427</X>\r\n<Y>33.662985</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>56286e35-77ae-4681-a161-482711f8cf34</Key>\r\n<Selected>false</Selected>\r\n<X>-117.794828</X>\r\n<Y>33.663607</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>87a1d53b-94ec-4af7-a033-f7139e1023bc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.79542</X>\r\n<Y>33.663686</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ac8dea46-4c60-44ed-9459-22421e8ee304</Key>\r\n<Selected>false</Selected>\r\n<X>-117.795902</X>\r\n<Y>33.663759</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ab44023e-f92a-4282-b71f-81b5b7af849b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.796116</X>\r\n<Y>33.663791</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a766004d-dd68-4df0-bf2b-98bb5813be98</Key>\r\n<Selected>false</Selected>\r\n<X>-117.79672</X>\r\n<Y>33.663875</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>fab4d894-a16a-4299-935e-3e155910e047</Key>\r\n<Selected>false</Selected>\r\n<X>-117.797239</X>\r\n<Y>33.663959</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f31e4640-64bc-4b40-8956-fdaa2c62eb8c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.797797</X>\r\n<Y>33.664028</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>33bc78ce-d978-45a6-b9af-a7a8a2dca550</Key>\r\n<Selected>false</Selected>\r\n<X>-117.798338</X>\r\n<Y>33.664107</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5dc595be-50f5-40fc-b31c-b05206fb95b4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.798729</X>\r\n<Y>33.664154</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>524665c3-20e3-4bfc-b8ae-10fe9bc7db3e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799089</X>\r\n<Y>33.6642129999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1a221215-465d-403b-8e86-faf0335daf91</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799158</X>\r\n<Y>33.6642239999999</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ff047904-7727-4b1e-8977-27dc4beeb245</Key>\r\n<Selected>false</Selected>\r\n<X>-117.799585</X>\r\n<Y>33.664294</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>67358fda-9bf1-45ce-af14-00aa6abf1b16</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800114</X>\r\n<Y>33.664347</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cf380116-e814-4546-a3c8-b24097ffa4ef</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800198</X>\r\n<Y>33.66436</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b2f61a11-d87d-420e-9d54-4a3c84d212c1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800385</X>\r\n<Y>33.664389</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f542b25f-18cd-44a7-b3ce-c79d6e6c9744</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800459</X>\r\n<Y>33.6644</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5e99eec7-ec24-459d-b86e-50eb96b0402f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800508</X>\r\n<Y>33.664407</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0df89102-c4d3-411c-9be5-88afe4f40273</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800557</X>\r\n<Y>33.664415</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3ee74192-5f17-450b-ac50-fbfb0c88b6d2</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800713</X>\r\n<Y>33.664439</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>260f1543-7d48-4c5e-9d09-904cbeefe0a1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.800988</X>\r\n<Y>33.664477</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e82a742f-dadb-4ca9-95a4-e9a894493ee5</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801082</X>\r\n<Y>33.664489</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9045b31d-3fff-495f-85a2-75a1ce2aa0c2</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80123</X>\r\n<Y>33.664509</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>26c4215c-1f3c-407a-a6db-4d635695f19c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80171</X>\r\n<Y>33.66458</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>70574645-32c9-465a-9de7-fc589466297e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.801787</X>\r\n<Y>33.66459</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9bef55f0-a880-4406-a2d2-e562c729bc33</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802231</X>\r\n<Y>33.66465</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4662e5b8-bebe-4173-8649-49a08fbece58</Key>\r\n<Selected>false</Selected>\r\n<X>-117.802729</X>\r\n<Y>33.664729</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e9a41d3f-239b-4687-90de-1a9fcac4e33b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803242</X>\r\n<Y>33.664793</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8375587f-4453-47f7-ae20-cbbaa6e98e90</Key>\r\n<Selected>false</Selected>\r\n<X>-117.803816</X>\r\n<Y>33.664874</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8eda9c45-bc6c-44af-8b9f-e5baae5bc906</Key>\r\n<Selected>false</Selected>\r\n<X>-117.804104</X>\r\n<Y>33.664908</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1d0f24a9-3d65-4188-b98f-a4d8d73dc3a2</Key>\r\n<Selected>false</Selected>\r\n<X>-117.805826</X>\r\n<Y>33.665154</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f2996d8c-0241-46eb-8ed6-ef8623566e4a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.807184</X>\r\n<Y>33.665345</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>623b92b0-bf31-4bc7-a751-54a5e39027b7</Key>\r\n<Selected>false</Selected>\r\n<X>-117.80737</X>\r\n<Y>33.665372</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>4bd9b986-9847-4361-9e61-fe31963440fa</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809014</X>\r\n<Y>33.665615</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9a0018eb-6697-4d10-a07d-ba25ee0af3d3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.809437</X>\r\n<Y>33.665679</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b46747c5-6dca-4f6b-9e9d-65707648da2b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.810342</X>\r\n<Y>33.66583</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e809868c-13ff-47df-8697-1131c48154bc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811101</X>\r\n<Y>33.665973</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>33e388b6-8d92-40f8-90ba-e5face9d39c4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.811722</X>\r\n<Y>33.666102</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>126c61db-29db-46f1-888b-a2b716bd2d32</Key>\r\n<Selected>false</Selected>\r\n<X>-117.8123</X>\r\n<Y>33.666231</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>20655428-af45-4094-90c1-aba748b18020</Key>\r\n<Selected>false</Selected>\r\n<X>-117.812869</X>\r\n<Y>33.666389</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>56fab71f-6318-4097-99c2-7767cdb3e60b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.813921</X>\r\n<Y>33.666683</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>28b04e8d-023d-4582-adbe-9c81659dfb20</Key>\r\n<Selected>false</Selected>\r\n<X>-117.814412</X>\r\n<Y>33.666834</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d235d525-2a7b-4d04-8aba-c47d94485290</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815266</X>\r\n<Y>33.667121</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>45cbc8be-c272-41bd-b41e-4dd2cfc6b49e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.815999</X>\r\n<Y>33.667372</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d9b61ff5-8314-47f3-b5e7-f3b08f20b977</Key>\r\n<Selected>false</Selected>\r\n<X>-117.816608</X>\r\n<Y>33.667553</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>89688c4f-2f2d-4fd5-b61b-bf7a0f8966dc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.817648</X>\r\n<Y>33.667861</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5a603698-28c1-4d9c-b58d-0f52924ec631</Key>\r\n<Selected>false</Selected>\r\n<X>-117.819496</X>\r\n<Y>33.668452</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>24484432-dbf5-4939-983b-1787f32a9cdb</Key>\r\n<Selected>false</Selected>\r\n<X>-117.819996</X>\r\n<Y>33.668646</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>aefab684-168c-4677-afa2-323d06d4f16f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.820373</X>\r\n<Y>33.668783</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>85178840-6ff3-4c09-92a4-dcd039c80be6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.82073</X>\r\n<Y>33.668909</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>573490e6-4343-4fe4-acdd-5eb36fc3da27</Key>\r\n<Selected>false</Selected>\r\n<X>-117.821128</X>\r\n<Y>33.669034</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>951ff137-5554-4aaf-b7a6-5ae1454ecf8c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822001465116</X>\r\n<Y>33.6693415581395</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c6892ea0-aaf6-429c-bd87-de4680191e06</Key>\r\n<Selected>false</Selected>\r\n<X>-117.821958</X>\r\n<Y>33.669325</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>422086f8-4c7f-45c6-8d9f-e72c66a8599f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822273</X>\r\n<Y>33.669445</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2dea5484-1a24-46cd-ba58-e24eb25a17fd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822422</X>\r\n<Y>33.669497</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ca4b89b3-380a-48f9-9dc5-cd38f4d39575</Key>\r\n<Selected>false</Selected>\r\n<X>-117.822731</X>\r\n<Y>33.669601</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d3a48592-2fde-4471-b111-e2bf17676dda</Key>\r\n<Selected>false</Selected>\r\n<X>-117.823045</X>\r\n<Y>33.669709</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>730edc54-24d8-45bf-bcf6-dbcac05a1be3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.823132</X>\r\n<Y>33.669742</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3f19ff1b-8893-4bce-a81b-c7b3387740a1</Key>\r\n<Selected>false</Selected>\r\n<X>-117.823605</X>\r\n<Y>33.669913</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>46e52c6c-7501-4216-b95b-89af6aebb5ac</Key>\r\n<Selected>false</Selected>\r\n<X>-117.823994</X>\r\n<Y>33.670046</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8f09caf0-7954-495c-979d-5e4a03014f4f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.826409</X>\r\n<Y>33.670872</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8a3e8f1a-1096-46a2-a78e-bedace4831f6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.826451</X>\r\n<Y>33.670884</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7663210d-814c-42d9-be11-6a00cc57c492</Key>\r\n<Selected>false</Selected>\r\n<X>-117.826543</X>\r\n<Y>33.670912</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>08e3b14e-1290-4295-aeeb-21448e8ad702</Key>\r\n<Selected>false</Selected>\r\n<X>-117.8291</X>\r\n<Y>33.671783</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6de04cd2-2df3-4b1e-965f-c22fe4d46e5b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.829481</X>\r\n<Y>33.671913</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>28cf1ef5-95e0-4f9d-81f7-8fa725fcdf72</Key>\r\n<Selected>false</Selected>\r\n<X>-117.830777</X>\r\n<Y>33.672352</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>276284f0-5f17-4bf5-8242-32f7f893b561</Key>\r\n<Selected>false</Selected>\r\n<X>-117.830866</X>\r\n<Y>33.672379</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2935a628-e74e-496c-83a2-5d29502d6c3d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.831286</X>\r\n<Y>33.672508</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>91dd3c2e-fc6f-43c6-9271-f1f812d77065</Key>\r\n<Selected>false</Selected>\r\n<X>-117.831719</X>\r\n<Y>33.672656</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>0cc9f7f5-89a3-4dc9-a5b2-31dc77b9950c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.831795</X>\r\n<Y>33.672682</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>fd8b3e79-eba0-4082-a915-dcac8f0025da</Key>\r\n<Selected>false</Selected>\r\n<X>-117.831993</X>\r\n<Y>33.672749</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>16787163-da4f-4b45-9736-43b17e660d56</Key>\r\n<Selected>false</Selected>\r\n<X>-117.832272</X>\r\n<Y>33.67284</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>725edd19-6680-44a5-a867-5cf8b62774dd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.832654</X>\r\n<Y>33.672978</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>274736ac-a404-45ba-b7e7-ef0c9720e93e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.833947</X>\r\n<Y>33.673399</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>dd461f13-be6a-4d95-9be8-fefb04e1601b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.834687</X>\r\n<Y>33.673646</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e84cea97-6ed3-441e-9951-7a64ebda80ae</Key>\r\n<Selected>false</Selected>\r\n<X>-117.840087074487</X>\r\n<Y>33.6751396231072</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>224b0d76-1779-4301-89c1-c9e0217692ed</Key>\r\n<Selected>false</Selected>\r\n<X>-117.846705</X>\r\n<Y>33.668625</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d02c36a9-0b65-421f-be50-0462237d1e9f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.846942</X>\r\n<Y>33.668387</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>22d3508b-60bc-4a88-906e-cb37d7407b99</Key>\r\n<Selected>false</Selected>\r\n<X>-117.847522</X>\r\n<Y>33.667809</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2f5f26b6-e0f8-46ec-8900-19520dd676fd</Key>\r\n<Selected>false</Selected>\r\n<X>-117.84768</X>\r\n<Y>33.667666</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a7be47fd-c641-45bb-9189-1a5da4d0177d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.84795</X>\r\n<Y>33.6674</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b2f07f34-2207-414e-aa63-a34312f7c679</Key>\r\n<Selected>false</Selected>\r\n<X>-117.848243</X>\r\n<Y>33.667107</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3bae5fd8-4b9f-43e3-b55d-c0af731fd1b4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.848635</X>\r\n<Y>33.666699</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d322a896-bf4e-4e94-93af-d15c9536d1be</Key>\r\n<Selected>false</Selected>\r\n<X>-117.848923</X>\r\n<Y>33.666425</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3a7c337f-b58b-4f08-b7ae-38d9252c4da3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.849213</X>\r\n<Y>33.666122</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1d86ff2e-8ddb-4f29-ace4-1be5b9764b71</Key>\r\n<Selected>false</Selected>\r\n<X>-117.849481</X>\r\n<Y>33.665847</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d40f95dc-2e60-447e-b1a5-c21c2c705373</Key>\r\n<Selected>false</Selected>\r\n<X>-117.849682</X>\r\n<Y>33.665647</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>671a5d79-1dce-42fd-9af0-7ef9539c78db</Key>\r\n<Selected>false</Selected>\r\n<X>-117.850102</X>\r\n<Y>33.665204</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>2b477572-fcc6-4a45-9ea5-b6395bc0678b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.850163</X>\r\n<Y>33.665133</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>9352c2fb-fe4b-4afc-9591-77fca83b353e</Key>\r\n<Selected>false</Selected>\r\n<X>-117.85023</X>\r\n<Y>33.665054</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>1e34c903-c54d-468c-812e-0f0fb324d905</Key>\r\n<Selected>false</Selected>\r\n<X>-117.850584</X>\r\n<Y>33.664685</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>338a77a1-5135-4326-a6ce-75c23d21cf2c</Key>\r\n<Selected>false</Selected>\r\n<X>-117.850924</X>\r\n<Y>33.664348</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d75e3145-94dc-4ae9-9be8-6ba6be01e89b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.851274</X>\r\n<Y>33.664027</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>eb37cdad-f1f5-4d29-a2aa-1d62c59fec41</Key>\r\n<Selected>false</Selected>\r\n<X>-117.851593</X>\r\n<Y>33.66426</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>35f51acb-dfc2-4fc1-bdc4-49649552f0b4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.852204</X>\r\n<Y>33.664695</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>87162d97-dca3-4e28-a42e-ee5e903c3cd0</Key>\r\n<Selected>false</Selected>\r\n<X>-117.852573</X>\r\n<Y>33.664952</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7d4116e1-27cb-46f3-8c88-20c7e9abd5f6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.852923</X>\r\n<Y>33.665191</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>374bcc6c-5c66-49da-90c3-9ae612290272</Key>\r\n<Selected>false</Selected>\r\n<X>-117.853503</X>\r\n<Y>33.664588</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>025b9adb-7427-4743-90b5-1d73f2977616</Key>\r\n<Selected>false</Selected>\r\n<X>-117.85388</X>\r\n<Y>33.664243</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>270c6265-54df-46ad-8d09-edfb06198f5a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.85397</X>\r\n<Y>33.664153</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5271c5d6-b969-4d06-b183-f177c78d0c31</Key>\r\n<Selected>false</Selected>\r\n<X>-117.854001</X>\r\n<Y>33.664116</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>5061bc38-6a41-4ce9-8d6d-794504a84813</Key>\r\n<Selected>false</Selected>\r\n<X>-117.854041</X>\r\n<Y>33.66401</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f7b8b713-88a0-4beb-a732-5a6c3b15befc</Key>\r\n<Selected>false</Selected>\r\n<X>-117.85392</X>\r\n<Y>33.663632</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>453810d9-1ccf-465e-85b7-c583f90aa14b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.853912</X>\r\n<Y>33.663501</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>660079fe-876e-4c7a-9378-2e1eddd42223</Key>\r\n<Selected>false</Selected>\r\n<X>-117.853961</X>\r\n<Y>33.663376</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>ab9c8e59-c63b-49f2-889c-319f5d2d79eb</Key>\r\n<Selected>false</Selected>\r\n<X>-117.854094</X>\r\n<Y>33.663259</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>3932b64c-ba61-453a-a35c-14a5ff6b4d8d</Key>\r\n<Selected>false</Selected>\r\n<X>-117.854169</X>\r\n<Y>33.663114</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>998dbc4e-862e-42f8-b209-0ae480632ef3</Key>\r\n<Selected>false</Selected>\r\n<X>-117.857909</X>\r\n<Y>33.659522</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>201a79c9-ee2f-48cb-a76f-4873da436651</Key>\r\n<Selected>false</Selected>\r\n<X>-117.856604</X>\r\n<Y>33.657466</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>86129f27-b944-48ad-b96a-578e0704b893</Key>\r\n<Selected>false</Selected>\r\n<X>-117.856251</X>\r\n<Y>33.656204</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>64df9740-737b-41db-83e9-f0a387be5b3b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.856604</X>\r\n<Y>33.655176</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>6659f8b8-efe4-48c2-8806-a7b22c9d0702</Key>\r\n<Selected>false</Selected>\r\n<X>-117.857345</X>\r\n<Y>33.65456</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>35e31b75-e86d-43e9-9825-298d6088da48</Key>\r\n<Selected>false</Selected>\r\n<X>-117.858579</X>\r\n<Y>33.653972</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>7ffe38ff-5432-4fea-8b6b-9eda8ee90d02</Key>\r\n<Selected>false</Selected>\r\n<X>-117.859585</X>\r\n<Y>33.653677</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>edb0be93-54ba-4cf1-b179-fd48e63b77eb</Key>\r\n<Selected>false</Selected>\r\n<X>-117.860115</X>\r\n<Y>33.653837</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c1772aba-8e89-49c9-9ac3-ce416848761f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.861333</X>\r\n<Y>33.654204</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>b6f04d8f-c6b9-4212-b6b8-6d5ef1a80e24</Key>\r\n<Selected>false</Selected>\r\n<X>-117.861427</X>\r\n<Y>33.654193</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>65ff0688-a7b5-4c45-be6b-99dcaed9d164</Key>\r\n<Selected>false</Selected>\r\n<X>-117.861401</X>\r\n<Y>33.65415</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d26d71b8-0664-437e-b061-bca6eaabad44</Key>\r\n<Selected>false</Selected>\r\n<X>-117.861253</X>\r\n<Y>33.653905</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d511298d-61c5-469b-817d-f43d7b2adc9a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.861197</X>\r\n<Y>33.653812</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>8b35f87c-3296-4a9c-bd29-0b95d9ac4ff7</Key>\r\n<Selected>false</Selected>\r\n<X>-117.861175</X>\r\n<Y>33.653774</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>78b9f24b-92f1-4784-9ba0-770620f28b35</Key>\r\n<Selected>false</Selected>\r\n<X>-117.860924</X>\r\n<Y>33.653351</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>29a38ba6-8cf7-426e-8463-c499d175bb63</Key>\r\n<Selected>false</Selected>\r\n<X>-117.860684</X>\r\n<Y>33.652955</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>cc7e81c1-05d4-4461-b6f6-db7d9f548e9f</Key>\r\n<Selected>false</Selected>\r\n<X>-117.860254</X>\r\n<Y>33.652237</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>a639b0b5-085d-4bbd-abcc-a9ca06d112b9</Key>\r\n<Selected>false</Selected>\r\n<X>-117.860179</X>\r\n<Y>33.65208</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>defdac87-1e46-4d5b-a9df-1c17ca5a82b4</Key>\r\n<Selected>false</Selected>\r\n<X>-117.860103</X>\r\n<Y>33.651926</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c4d3ba2d-8a4b-47de-96f5-c459e5338b1b</Key>\r\n<Selected>false</Selected>\r\n<X>-117.860069</X>\r\n<Y>33.651831</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>d494e9dc-ae43-47b7-aede-57c6d3eca971</Key>\r\n<Selected>false</Selected>\r\n<X>-117.860052</X>\r\n<Y>33.651775</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>dc808255-fbe5-4ece-8870-464950b9d5f8</Key>\r\n<Selected>false</Selected>\r\n<X>-117.860027</X>\r\n<Y>33.651719</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>f38c10ee-eea8-404f-8ef3-1f451235d652</Key>\r\n<Selected>false</Selected>\r\n<X>-117.859968</X>\r\n<Y>33.651544</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>68988baa-eb1c-4409-9759-f6433426045a</Key>\r\n<Selected>false</Selected>\r\n<X>-117.859913669435</X>\r\n<Y>33.6513783112487</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>c8ceb57c-c58b-4764-985f-696365f3a8be</Key>\r\n<Selected>false</Selected>\r\n<X>-117.861521</X>\r\n<Y>33.651305</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>fa87c9e3-9e27-4c34-a468-22315c09dc34</Key>\r\n<Selected>false</Selected>\r\n<X>-117.861483</X>\r\n<Y>33.651174</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>e426a2df-3257-47c4-93e7-64f77deab0c6</Key>\r\n<Selected>false</Selected>\r\n<X>-117.861363</X>\r\n<Y>33.650653</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>01204d56-3d8a-48b7-9d44-7948d9c0bf74</Key>\r\n<Selected>false</Selected>\r\n<X>-117.861338</X>\r\n<Y>33.650527</Y>\r\n</PointShape>\r\n<PointShape>\r\n<Key>298a7014-2b5f-404b-a741-3a19a9910991</Key>\r\n<Selected>false</Selected>\r\n<X>-117.861247</X>\r\n<Y>33.650073</Y>\r\n</PointShape>\r\n</Points>\r\n</MultiPoint>\r\n</Parts>\r\n</Polygon>\r\n"
Hello Kenny,
 Have you tried the sample?
The shapefile is working.
 The problem boundaries never got added to the shapfile because I placed a try/catch around EditTools.Add.
 The XML i posted above a for those boundaries that passed the isvalid test but error out when adding to the shapefile.
Hi Kenny,
 Could you send us a sample that shows how to recreate your problem? It’s very hard to find out the problem from the xml info above.
 Edgar
string boundaryXml = dr["BoundaryXml"].ToString();
                     if (boundaryXml != string.Empty)
                         string studyblockID = dr["StudyblockID"].ToString();
                         string studyblockCode = dr["StudyblockCode"].ToString();
                         try
                             MultipolygonShape poly = XmlShapes.GetMultiPolygonShape(boundaryXml); // convert xml, to polygon, check isvalid before converting
                             Dictionary<string, string> columnValues = new Dictionary<string, string>();
                             columnValues.Add("NAME", studyblockCode);
                             columnValues.Add("SBID", studyblockID);
                             columnValues.Add("AREA", "0");
                             boundaryLayer.EditTools.Add(poly, columnValues);
                         catch(Exception ex)
any updates on this guys, we have quite a few boundaries with this issue and need to get them fixed.
Kenny,
 Are you sure every coordinates in your post are the full data? If so, I found none of the polygons’ start and end point are the same, that’s why it’s not valid.
 Edgar
I don’t think that’s the problem. I have other polygons that do the same thing but no error.
 But I went ahead to make the start and end point the same, and the result was the same.
 Passed IsValid test but error out when adding to the shape file.
 Here is the poly wellknowntext
 “MULTIPOLYGON(((-13115444.107742 3987018.17339278,-13115407.2595214 3986989.12249224,-13115407.2609906 3986989.14174815,-13115392.4554983 3986978.84021445,-13115379.5424374 3986969.07383388,-13115349.0408969 3986948.87216889,-13115334.9033216 3986938.97202814,-13115312.1324682 3986923.13446702,-13115312.9733819 3986923.58669119,-13115284.3642728 3986908.20137483,-13115255.7551636 3986894.55528537,-13115233.1970994 3986884.89788153,-13115213.7877156 3986877.69837368,-13115194.3068047 3986871.94562376,-13115187.7389548 3986869.93885121,-13115162.1354719 3986861.51041031,-13115135.6414331 3986855.7576685,-13115131.7452509 3986854.55360662,-13115107.8115604 3986849.73736038,-13115082.9873139 3986845.05490068,-13115030.7784727 3986837.56296913,-13114967.549002 3986829.00076762,-13114938.2719759 3986824.85345356,-13114910.5534227 3986819.50208279,-13114869.3652111 3986810.53854232,-13114808.2508106 3986792.21013057,-13114789.1038582 3986785.38715264,-13114788.1019828 3986784.45066579,-13114738.1195314 3986763.31284,
 -13114684.2408979 3986735.48588809,-13114657.3784903 3986717.76851662,-13114646.7262295 3986711.1373604,-13114610.6587145 3986685.31727472,-13114590.2872477 3986669.79849465,-13114565.3516817 3986648.92844411,-13114531.8489209 3986620.53672265,-13114525.276665 3986615.0815837,-13114467.7244883 3986566.65265234,-13114460.6000409 3986559.42846459,-13114432.8814877 3986537.08702378,-13114406.1648099 3986515.68209126,-13114395.7007778 3986507.92281306,-13114359.4106238 3986477.5546539,-13114400.3761964 3986429.39386108,-13114483.4205365 3986324.37727611,-13114489.20915 3986317.01946216,-13114521.9370803 3986277.68868195,-13114537.29917 3986259.62867488,-13114566.2422376 3986226.31806954,-13114579.0439791 3986210.39857739,-13114590.2872477 3986197.15464692,-13114614.1096187 3986168.12507489,-13114643.4979643 3986130.93522333,-13114682.0145081 3986085.0500686,-13114713.4066045 3986047.32538464,-13114724.2045951 3986032.61011593,-13114748.8062026 3986003.31340974,-13114822.7223444 3985908.86882842,-13114884.5046618 3
 985834.49092219,-13114959.3113596 3985747.405172,-13115023.4313863 3985669.14895437,-13115075.306269 3985608.28337543,-13115102.3569053 3985572.96811024,-13115135.9753915 3985533.23856651,-13115175.1598523 3985488.42594619,-13115253.5287738 3985394.1193603,-13115268.6682246 3985374.58929873,-13115296.8320557 3985341.68255767,-13115356.7219418 3985268.91351331,-13115393.1234153 3985226.91100241,-13115559.2120955 3985025.99665446,-13115587.3759267 3984991.61951775,-13115655.1694966 3984908.15172228,-13115707.9349352 3984843.54485411,-13115747.8986324 3984795.92594545,-13115803.5583778 3984729.44706838,-13115815.4695633 3984715.53604411,-13115849.5333275 3984670.86036841,-13115913.6533542 3984587.52865849,-13115938.7002396 3984557.03181118,-13115958.1811505 3984533.35668284,-13115966.4187928 3984523.32486349,-13116001.373113 3984537.77068612,-13116011.0579087 3984542.1846911,-13116063.7120278 3984565.05728948,-13116107.0153097 3984582.84711965,-13116375.85188 3984693.33194408,-13116380.5272986 3984694.93705831,-1
 3116390.7686918 3984698.68232571,-13116675.4126297 3984815.18750274,-13116717.8253557 3984832.57643633,-13116862.0954158 3984891.29772169,-13116872.0028505 3984894.90929117,-13116918.7570366 3984912.16458321,-13116966.9583761 3984931.96138425,-13116975.4186574 3984935.43920417,-13116997.4599166 3984944.40128342,-13117028.5180545 3984956.57367089,-13117071.0421 3984975.03292043,-13117214.9782016 3985031.34719081,-13117297.3546248 3985064.38680794,-13117355.9086769 3985088.59808559,-13117414.4627291 3985113.47823615,-13117428.7116239 3985119.8989289,-13117446.5227424 3985126.58715434,-13117898.4881669 3985264.18128168,-13119471.5345061 3986575.69453848,-13118563.725152 3987722.31356336,-13118425.8003029 3987610.86308266,-13118342.6446433 3987539.55139708,-13118274.1831565 3987481.75313216,-13118159.8580394 3987387.43019878,-13118052.8800088 3987296.18520379,-13118038.5197945 3987284.1441295,-13118021.9331903 3987269.56106752,-13117943.4529493 3987207.08155264,-13117864.1934719 3987142.86313311,-13117842.8201297
 3987124.13282831,-13117839.4805449 3987121.32328522,-13117666.7126952 3986972.41848382,-13117604.7077389 3986921.17855336,-13117533.9085427 3986858.43336202,-13117471.2356694 3986806.92637127,-13117322.5128297 3986682.3740562,-13117023.7313164 3987039.84683425,-13117014.7144376 3987050.95114416,-13116972.6356701 3987101.65650282,-13116962.8395549 3987114.36632433,-13116936.3455161 3987154.50269504,-13116931.0021806 3987163.3327154,-13116919.313634 3987184.60506501,-13116894.1554291 3987226.61472638,-13116887.8102181 3987237.31784935,-13116883.02348 3987245.07761974,-13116872.3368089 3987260.06201875,-13116826.2505397 3987317.32400915,-13116790.4056637 3987360.40447963,-13116633.8904596 3987546.90999332,-13116622.6471911 3987558.81754995,-13116584.1306473 3987605.10996592,-13116543.8329916 3987653.0080954,-13116429.2852356 3987794.56295157,-13116414.2571043 3987811.82259483,-13115496.7618612 3987060.71759428,-13115444.107742 3987018.17339278)))”
Here is the stack trace if helpful
  at 3RQ=.Xjs=.Ejw=(Feature Ezw=)\r\n   at ThinkGeo.MapSuite.Core.FeatureSource.AddFeature(Feature feature)\r\n   at ThinkGeo.MapSuite.Core.EditTools.Add(BaseShape shape, Dictionary`2 columnValues)\r\n
Hello Kenny,
 Thanks for your further information, I test with the MULTIPOLYGON you provide, and directly add into the sample code I provide, it works fine, could you please let us know what’s your dlls version?
6.0.123.0
 Show me the code you used to add that polygon to my shapefile.
