InvalidOperationException(Object is currently in use elsewhere) on globe button click
I've searched on forums but couldn't find similar problem.
I have a one LayerOverlay and I'm loading an image on it with code:
            GdiPlusRasterLayer imageMapLayer = new GdiPlusRasterLayer(mapToLoad.Path);
            imageMapLayer.UpperThreshold = double.MaxValue;
            imageMapLayer.LowerThreshold = 0;
            LayerOverlay overlay = new LayerOverlay();
            overlay.Layers.Add(imageMapLayer);
            overlay.RenderMode = RenderMode.GdiPlus;
            overlay.TileType = TileType.SingleTile;
            imageMapLayer.DrawingExceptionMode = DrawingExceptionMode.DrawException;
            wpfMap1.Tag = mapToLoad;
            wpfMap1.Overlays.Clear();
            wpfMap1.Overlays.Add(overlay);
            wpfMap1.Refresh();
And when zooming in/out fastly (while it is still refreshing) if I click on globe button I get below exception;
System.InvalidOperationException was unhandled
  Message=Object is currently in use elsewhere.
  Source=System.Drawing
  StackTrace:
       at System.Drawing.Image.get_Width()
       at ThinkGeo.MapSuite.Core.GdiPlusRasterSource.GetImageWidthCore()
       at ThinkGeo.MapSuite.Core.GdiPlusRasterSource.GetBoundingBoxCore()
       at ThinkGeo.MapSuite.Core.RasterSource.GetBoundingBox()
       at ThinkGeo.MapSuite.Core.RasterLayer.GetBoundingBoxCore()
       at ThinkGeo.MapSuite.Core.Layer.GetBoundingBox()
       at ThinkGeo.MapSuite.WpfDesktopEdition.LayerOverlay.GetBoundingBoxCore()
       at ThinkGeo.MapSuite.WpfDesktopEdition.Overlay.GetBoundingBox()
       at ThinkGeo.MapSuite.WpfDesktopEdition.PanZoomBarMapTool.RxY=(Object SBY=, MouseButtonEventArgs SRY=)
       at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
       at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
       at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
       at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
       at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
       at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
       at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
       at System.Windows.Input.InputManager.ProcessStagingArea()
       at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
       at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
       at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
       at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
       at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
       at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
       at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
       at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
       at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
       at System.Windows.Forms.Application.Run(Form mainForm)
       at WinformsMapTest.Program.Main() in D:\__nanodems__\nanodems.maps.V2\WinformsMapTest\Program.cs:line 24
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
  InnerException:
What can be the reason and how we can I avoid this situation?
Regards
Hello ABDULKADIR,
 Thanks for your post, I have tested this situation with our websamples(LoadAStandardImageWithWorldFile) but I can’t recreate this problem, could you please provide a self-contained sample to me?
