Sometimes, I get the following exception upon map launch even after setting DrawingExceptionMode to DrawException.. Is this an error from the WorldMapKitWmsWpfOverlay ?
Type : System.InvalidOperationException, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Message : The enumerator is not valid because the collection changed.
Source : PresentationCore
Help link :
Data : System.Collections.ListDictionaryInternal
TargetSite : Boolean MoveNext()
Stack Trace : at System.Windows.Media.VisualCollection.Enumerator.MoveNext()
at ThinkGeo.MapSuite.WpfDesktopEdition.TileOverlay.xe960bd1c67737f90(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.OnOpened(EventArgs args)
at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.set_IsOpened(Boolean value)
at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.CommitDrawingCore(GeoCanvas geoCanvas, Object nativeImage)
at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.x72e495c788ab064e(Object xe0292b9ed559da7d, RunWorkerCompletedEventArgs xfbf34718e704c6bc)
at System.ComponentModel.BackgroundWorker.OnRunWorkerCompleted(RunWorkerCompletedEventArgs e)
at System.ComponentModel.BackgroundWorker.AsyncOperationCompleted(Object arg)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter)
at System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.Run()
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at System.Windows.Application.Run(Window window)
at System.Windows.Application.Run()
at OCC600.Infrastructure.Shell.App.Main()
TIA.
