Inverse Distance Weighting (IDW) Interpolator
Does ThinkGeo have the ability to perform interpolation like the MapInfo Inverse Distance Weighting (IDW) Interpolator?
If so, do you have an example?
I should say I’m trying to create a IDW interpolated grid layer based on points.  I’d rather not create a grid file using another library and load it using ThinkGeo if all possible.
Actually, we have a blog that shows how to create a GRID from some sample points using the IDW interpolation.
gis.thinkgeo.com/Support/Discussion...fault.aspx
As you can see, this is for 2.x and in 3.x, we don't have the API yet for creating a GRID. We currently can also display one as you can see in the sample app of "How Do I" Load a GridFileFeatureLayer in the DataProviders section.
Now, I don't know in what context, you want to use the IDW interpolation. Using a GRID or something else. In any case, you can see that you can get the IDW interpolation algorithm as the code for it can be found in the CalculatecellValueHandlerIDW in the blog.
Private Sub CalculateCellValueHandlerIDW(ByVal CellExtent As StraightRectangle, ByRef CellValue As Double)
        Dim CellULx As Double = CellExtent.UpperLeftPoint.X
        Dim CellULy As Double = CellExtent.UpperLeftPoint.Y
        Dim CellLRx As Double = CellExtent.LowerRightPoint.X
        Dim CellLRy As Double = CellExtent.LowerRightPoint.Y
        Dim xp As Double = CellExtent.Center.X
        Dim yp As Double = CellExtent.Center.Y
        Dim CellCenterPointShape As New PointShape(xp, yp)
        Dim CenterRecords() As Integer = Map1.Layers(0).QueryByDistance(CellExtent, 15, MapLengthUnits.metres, Map1.MapUnit)
        If CenterRecords.GetLength(0) = 1 Then
            Dim NearestRecords() As Integer = Map1.Layers(1).QueryByDistance(CellCenterPointShape, 200, MapLengthUnits.metres, Map1.MapUnit)
            If NearestRecords.GetLength(0) > 0 Then
                Dim NearestPointShapes() As PointShape = CType(Map1.Layers(1).GetShapes(NearestRecords), PointShape())
                Dim NearestValues(NearestRecords.GetLength(0) - 1) As String
                For i As Integer = 0 To NearestRecords.GetLength(0) - 1
                    NearestValues(i) = Map1.Layers(1).DataQuery(NearestRecords(i), "pH")
                Next i
                'This is the algorithm for IDW interpolation
                Dim Power As Double = 2
                Dim Zi, Zx1, Zx2, Zx, Di As Double
                For i As Integer = 0 To NearestValues.GetLength(0) - 1
                    Zi = CDbl(NearestValues(i))
                    Di = CellCenterPointShape.DistanceTo(NearestPointShapes(i), Map1.MapUnit, MapLengthUnits.metres, DistanceTypes.Shortest)
                    Zx1 = Zx1 + (Math.Pow((1 / Di), Power) * (Zi))
                    Zx2 = Zx2 + ((Math.Pow((1 / Di), Power)))
                Next
                Zx = Zx1 / Zx2
                CellValue = Zx
            Else
                CellValue = -9999
            End If
        Else
            CellValue = -9999
        End If
    End Sub
This is what I was looking for.  Thanks.
Peter,
 I am glad that it’s working with you, Thank Val very much.
 If you don’t mind, I will close this post.
Peter,
 I want to let you know that we posted a new sample in the Code Community for creating GRID using the IDW interpolation interpolation. You may want to check it if you are interested,  Create GRID: wiki.thinkgeo.com/wiki/Map_Suite_De...reate_GRID
Thank you.
