IOException when displating 2 maps controls
My application contains 2 WPF GIS Controls on 2 different tabs. Both use the same shape files. When the maps are loading the layers, if one map is performing a slow SQL search I get the following error. I'm guessing that the SQL search on the first map locks the dbf file which causes an exception on the second map.
Any ideas on how to fix the issue?
IOException
The process cannot access the file 'C:\KernMobileGisData\UnityV5\Assets\Addresses.dbf' because it is being used by another process.
Here is the stack trace:
  at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.<>c__DisplayClass2.<DrawException>b__0()
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
   at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
   at System.Windows.Window.ShowHelper(Object booleanBox)
   at System.Windows.Window.Show()
   at System.Windows.Window.ShowDialog()
   at Caliburn.Micro.WindowManager.ShowDialog(Object rootModel, Object context, IDictionary`2 settings) in C:\Projects\Blue Spire\Caliburn.Micro\src\Caliburn.Micro.WPF\WindowManager.cs:line 54
   at KernMobile.Windows.Helpers.DialogHelper.ShowWindow(Screen viewModel) in C:\Source\Source_V5\Work\Src\KernMobile.Windows\KernMobile.Windows\Helpers\DialogHelper.cs:line 93
   at KernMobile.Windows.ViewModels.JobListViewModel.OnShowPopup(GridData gridData) in C:\Source\Source_V5\Work\Src\KernMobile.Windows\KernMobile.Windows\ViewModels\JobListViewModel.cs:line 66
   at KernMobile.Controls.UserControls.GridControl.ShowGridPopup(GridData gridData) in C:\Source\Source_V5\Work\Src\KernMobile.Windows\KernMobile.Controls\UserControls\GridControl.cs:line 155
   at KernMobile.Controls.UserControls.GridBase.EditButtonClick(Object sender, RoutedEventArgs e) in C:\Source\Source_V5\Work\Src\KernMobile.Windows\KernMobile.Controls\UserControls\GridBase.xaml.cs:line 140
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
   at System.Windows.Controls.Primitives.ButtonBase.OnClick()
   at System.Windows.Controls.Button.OnClick()
   at Telerik.Windows.Controls.RadButton.OnClick() in c:\TB\102\WPF_Scrum\Release_WPF\Sources\Development\Core\Controls\Buttons\RadButton.cs:line 384
   at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
   at System.Windows.UIElement.OnMouseLeftButtonUpThunk(Object sender, MouseButtonEventArgs e)
   at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
   at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
   at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
   at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
   at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
   at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
   at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Application.RunDispatcher(Object ignore)
   at System.Windows.Application.RunInternal(Window window)
   at System.Windows.Application.Run(Window window)
   at System.Windows.Application.Run()
   at KernMobile.Windows.App.Main() in C:\Source\Source_V5\Work\Src\KernMobile.Windows\KernMobile.Windows\obj\x86\Debug\App.g.cs:line 50
   at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
Hello Steve,
 Thanks for your post, but sorry to say, for this situation, we can’t do anything, because if one control is writing something into dbf file, it must be locked, before unlock, another control can not operate it.
 Maybe you can add something like flag, once one control finished the operate, change to another.
