I want to TileCache software to improve the performance of my map,I foud that the tilecache can be used in any WMS-C supporting client, like OpenLayers in the website tilecache.org/. which means the client must support the WMS-C protocol .The WMS-C protocol is basically the WMS protocol but restricted to specific tile bboxes. The advantage is that it can also call a WMS and cache the tiles locally.
I want to use Mapserver + TileCache-2.10 as the server,use the Map Suite Desktop Edition 3.0 as client. so I have to known that " is Map Suite Desktop Edition 3.0 Support WMS-C protocol?" .
I do not think the MapSuite component support the WMS-C protocol in current version. While just want to let you know that the TileCache system is compatible with OpenLayer cache system which can apply the WMS-C protocol, you can take a look at its cached folders. So potentially we can support it while it need some time for its supporting.
Do you have any plan to support WMS-c? My customer is not satisfied with the performance of ThinkGeo, actually not satified with Mapserver’s performance to create WMS. So we try to use Tilecache as a proxy. Any suggestion will be greatly appreciated.
We have developed our own WMS server that supports caching however it is not in Beta yet. The WMS cached server is what drives our WMS images in our new samples and works with load balancing hardware and is quite fast. I expect we may have something out around the end of November. The technology is quite stable, as it is running in production now, and running our own complex maps. We are working on adding a plugin system to allow you to easily drag and drop your own plug-ins and have be automatically available.
