Is there an example to center map based on vehicle position
I know i can get the position of a vehicle. Is there a way to center the map based on this position?
Bob,
Take a look at the following sample in our code community; hope it was what you expect.
code.thinkgeo.com/projects/s...ngonmoving
You can also can one step further if you want. You can have the map centering and rotating according to a moving vehicle position and direction as you can see in this recently posted project.
code.thinkgeo.com/projects/s...ngrotating
