Is there any way to make areastyle and linestyle from image?
 hi hi hi dears
you know there is :
new PointStyle(new GeoImage(imgpath));
we can use images as point styles but for line and polygons no defined api
is there alternate way to do that or it's impossible?
thanks
another question:
how can minimize overlayswitcher at startup page?
best regards
Hossein,
  It is possible to use a GeoImage for Styles to represent polygon based features but you will need to create a custom style. Below in the code, you can see the custom ImageStyle taking a GeoImage. You can also see in the capture where I use an image of a forest to represent some polygons. This can also be done for line based features but this is going to require some more work. I will contact you back when I that solution. Thank you.
InMemoryFeatureLayer inMemoryFeatureLayer = new InMemoryFeatureLayer();
ImageStyle imageStyle = new ImageStyle(new GeoImage(@"C:\ThinkGeo\Support\Posts\10037\Forest.png"));
inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(imageStyle);
inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
   class ImageStyle : Style
         private GeoImage geoImage = null;
        public ImageStyle(GeoImage geoImage)
            this.geoImage = geoImage;
        protected override void DrawCore(IEnumerable<Feature> features, GeoCanvas canvas, Collection<SimpleCandidate> labelsInThisLayer, Collection<SimpleCandidate> labelsInAllLayers)
            // Loop through all of the features being passed in to draw.
                WellKnownType shapeWellKnownType = feature.GetWellKnownType();
                if (shapeWellKnownType == WellKnownType.Polygon)
                    PolygonShape polygonShape = new PolygonShape(feature.GetWellKnownBinary());
                    canvas.DrawArea(polygonShape, new GeoTextureBrush(geoImage), DrawingLevel.LevelOne);
                else if (shapeWellKnownType == WellKnownType.Multipolygon)
                    MultipolygonShape multiPolygonShape = new MultipolygonShape(feature.GetWellKnownBinary());
                    canvas.DrawArea(multiPolygonShape, new GeoTextureBrush(geoImage), DrawingLevel.LevelOne);
Hossein,
 I extented the class ImageStyle so that it can handle having an Image for representing line based feature. You can see the result in the screen shot below. I use an actual image of a pavement to draw my streets. Keep in mind that this is a fairly intensive operation and that ImageStyle should be limited to the lower zoom levels to avoid performance issues. Also you can see the new code for ImageStyle.
ShapeFileFeatureLayer streetLayer = new ShapeFileFeatureLayer(@"C:\ThinkGeo\Support\MapData\Austinstreets.shp");
ImageStyle imageStyle = new ImageStyle(new GeoImage(@"C:\ThinkGeo\Support\Posts\10037\Pavement.png"), 5);
TextStyle textStyle = new TextStyle("FENAME", new GeoFont("Arial", 10), new GeoSolidBrush(GeoColor.StandardColors.Maroon));
textStyle.HaloPen = new GeoPen(GeoColor.StandardColors.White, 3);
streetLayer.ZoomLevelSet.ZoomLevel18.CustomStyles.Add(imageStyle);
streetLayer.ZoomLevelSet.ZoomLevel18.CustomStyles.Add(textStyle);
streetLayer.ZoomLevelSet.ZoomLevel18.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
streetLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(new LineStyle(new GeoPen(GeoColor.StandardColors.DarkGray,3)));
streetLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level17;
layerOverlay.TileType = TileType.SingleTile;
layerOverlay.Layers.Add(streetLayer);
wpfMap1.Overlays.Add(layerOverlay);
streetLayer.Open();
wpfMap1.CurrentExtent = new RectangleShape(-97.7231, 30.2752, -97.7212, 30.2740);
streetLayer.Close();
         private int lineWidth;
        public ImageStyle(GeoImage geoImage, int lineWidth)
            this.lineWidth = lineWidth;
                else if (shapeWellKnownType == WellKnownType.Line)
                    LineShape lineShape = new LineShape(feature.GetWellKnownBinary());
                    double worldDistance = ExtentHelper.GetWorldDistanceBetweenTwoScreenPoints(canvas.CurrentWorldExtent, new ScreenPointF(0,0),new ScreenPointF(lineWidth,0),canvas.Width,
                        canvas.Height,canvas.MapUnit,DistanceUnit.Meter);
                     MultipolygonShape multiPolygonShapeBuffer = lineShape.Buffer(worldDistance, canvas.MapUnit, DistanceUnit.Meter);
                     canvas.DrawArea(multiPolygonShapeBuffer, new GeoTextureBrush(geoImage), DrawingLevel.LevelOne);
                else if (shapeWellKnownType == WellKnownType.Multiline)
                    MultilineShape multilineShape = new MultilineShape(feature.GetWellKnownBinary());
                    double worldDistance = ExtentHelper.GetWorldDistanceBetweenTwoScreenPoints(canvas.CurrentWorldExtent, new ScreenPointF(0, 0), new ScreenPointF(lineWidth, 0), canvas.Width,
                        canvas.Height, canvas.MapUnit, DistanceUnit.Meter);
                    MultipolygonShape multiPolygonShapeBuffer = multilineShape.Buffer(worldDistance, canvas.MapUnit, DistanceUnit.Meter);
Hello!
This is to inform everybody that a sample project in relation to this post was added recently to the Code Community in ThinkGeo Wiki. The sample, ImageStyle, can be found a the following link:
wiki.thinkgeo.com/wiki/Map_Suite_Wp...mage_Style
