We have noticed a small issue with rendering a shape file that used to work seamlessly in V5.0. It used to take around 1 second, using V5.0 for the DrawingTime to complete, however, it now takes over 19seconds using V6.0. All in all most drawing layers seem to be around 5- 10% slower in drawing between versions. Any advice?
Hello Luke,
From V5.0 to V6.0 we have two way to render the map now, the default way is using GDI+, and another choice is using D2D, but both way will increase the speed than 5.0 time, so maybe it’s a bug in some special situation, could you please provide a sample with your shape file data to me to recreate this problem? If the data is private, you can send to forumsupport@thinkgeo.com.
Thanks for your help.
Hi Gary,
The files have just been sent to the email address supplied above
Luke
Hello Luke,
Yes, I got the data, but looks like it’s our data cntry02, is this right?
If I got the right data, I did some test on this and the render time is no problem, could you please send me your sample?
Hi Gary,
No the shape file is similar to yours but more detailed. The Country02.SHP file works fine and this cnty02.shp file used to work quickly in v5.
I have attached the MapSuiteExplorer example project and if you use the version 6.0.0.0 DLL's you should be able to replicate the issue.
Luke
MapSuiteExplorer.zip (219 KB)
Luke,
The sample you provided does not function. Please provide a solution that contains the necessary data and code to recreate the issue. We need to be able to narrow down where the slowdown is occurring before we can help formulate a resolution.
