Issue with ShapeFileFeatureLayer and uppercase file extention
I do have unexpected result when loading a ShapeFileFeatureLayer from a file set (.shp, .shx, .dbf) when extentions are in uppercase.
renoming the file solves the issue.
may you double check your internal treatment in that case.
thank you
Patrick.
Hi Patrick,
Thanks for your feedback, the android edition is non-case sensitive for the Shapefile. Could you please append more information about the "unexpected result"? A simple sample would be better.
Peter
