I can read .hsp file from demo without any problem but whe I try to read my own .hsp file it seems map control came empy.
This, is what I did.
Firstly I have read all my .shp files whith Map Suite Explorer in order to create the index for each ones. no problem with that. then I wrote a piece of code like this:
Map1.MapUnit =
GeographyUnit.DecimalDegree;
ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"C:\Accendo\Projects\CAEME\Estadisticas\GIS_Ejemplos\GIS_Ejemplos\SanMartin\argentina.shp");// worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1;
worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel =
Map1.StaticOverlay.Layers.Add(worldLayer);
AreaStyles.CreateSimpleAreaStyle(GeoColor.SimpleColors.Transparent, GeoColor.FromArgb(100, GeoColor.SimpleColors.Green));ApplyUntilZoomLevel.Level20;
Map1.CurrentExtent =
new RectangleShape(5, 200, 200, 50);
Unfortunately the result of this code is an empty map. it seems there is not result or it can't not found the map. But if I change the path of the .shp file for one .shp file demo it works.
Does anyone know what the problem is ?
I would need solve this problem as soon as possible.
Cheers Dario
