Javascript
hi,can routing services be called from javascript in a client bowser ?
thnks.
Filipe,
Thanks for your post,  here is a sample for you showing how to use JavaScript calling routing service from client browser.
This sample uses Map Suite web edition so you need to install that first.
Note:
You need to copy the relative data to App_Data from MapSuite Routing folder to make it working.  If you are using IE8, you need to switch to “Compatibility View” to avoid some compatibility problem.
1251-JavaScriptRoutingDemo.zip (9.1 KB)
