I am using the JPG map files for our application. I am unable to get the map on the map control without giving the world extent for the map in the GdiPlusRasterLayer, constructor even though the jgw files is available for the same.I also tried getting the bounding box for the map files and adding the same to the current extent for the map control. It did not work.
Can i get some sample code which supports the JPG map files with jgw files with it?
Bhavya
