KML doesn't refresh after zoom is changed
I am getting a strange error with a kml file not displaying after zoom is changed. I have set it up exactly the same way as with other layers which are displaying no problem. Here is my code and i have attached the kml.
 Proj4Projection proj_KML = new Proj4Projection();
                proj_KML.InternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(4326);
                proj_KML.ExternalProjectionParametersString = Proj4Projection.GetGoogleMapParametersString();
                KmlFeatureLayer kmllayer = new KmlFeatureLayer(@"Data\Efate_GPS.kml");
                kmllayer.FeatureSource.Projection = proj_KML;
                kmllayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = new AreaStyle(new GeoPen(GeoColor.SimpleColors.Black), new GeoSolidBrush(GeoColor.SimpleColors.Yellow));
                kmllayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle = new LineStyle(new GeoPen(GeoColor.SimpleColors.Blue, 5));
                kmllayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.SimpleColors.BrightRed), 10);
                kmllayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
                LayerOverlay KMLOverlay = new LayerOverlay();
                KMLOverlay.Layers.Add("KmlLayer", kmllayer);
                wpfMap1.Overlays.Add("KMLOverlay", KMLOverlay);
                wpfMap1.Overlays.MoveToTop("KMLOverlay");
                wpfMap1.Refresh();
thanks
Phil
Efate_GPS.zip (369 KB)
 Phil,
Just confirm with you that we are using the same KmlFeatureLayer, is it get from KmlExtention in our code community?
wiki.thinkgeo.com/wiki/Map_Suite_Wpf_Desktop_Edition_Layers_%26_FeatureSources_Samples#KML_Extension
I can recreate your issue, it may cause that this layer not implement projection correct, because if I remove the projection, it works properly.
I am doing some deep research on KmlExtension to fix this bug, any progress I will let you know ASAP.
Hi James,
 Any luck finding the problem?
 thanks
 Phil
Here is another kml file with problems, and as a shapefile it also doesnt work. Lines up perfectly in Google earth but cant see it in mapsuite. Here is the shapefile code:
 ShapeFileFeatureLayer shp = new ShapeFileFeatureLayer(@"Data\HH Line Islands.shp");
                shp.RequireIndex = false;
                shp.Open();
                if (shp.UsingSpatialIndex == false)
                    shp.Close();
                    ShapeFileFeatureSource.BuildIndexFile(@"Data\HH Line Islands.shp", BuildIndexMode.Rebuild);
                shp.RequireIndex = true;
                //shp.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.SimpleColors.Transparent, GeoColor.FromArgb(100, GeoColor.SimpleColors.Green));
                shp.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.SimpleColors.BrightRed), 10);
                shp.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
                Proj4Projection proj_EEZs = new Proj4Projection();
                proj_EEZs.InternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(4326);
                proj_EEZs.ExternalProjectionParametersString = Proj4Projection.GetGoogleMapParametersString();
                shp.FeatureSource.Projection = proj_EEZs;
                shp.WrappingMode = WrappingMode.WrapDateline;
                shp.WrappingExtent = new RectangleShape(WrapExtentMinX, WrapExtentMaxY, WrapExtentMaxX, WrapExtentMinY); //new RectangleShape(17897271, -1367305, 19514067, -2411741);
                LayerOverlay shpOverlay = new LayerOverlay();
HH_Line_islands.zip (23.5 KB)
 Phil,
The first kml problem you can change the code of GetAllFeatureCore as following:
        protected override Collection<Feature> GetAllFeaturesCore(IEnumerable<string> returningColumnNames)
            Collection<Feature> returnFeatures = new Collection<Feature>();
            foreach (Feature feature in inMemoryFeatureLayer.InternalFeatures)
                Feature newFeature = GetClonedFeature(feature, returningColumnNames);
                returnFeatures.Add(newFeature);
            return returnFeatures;
        private static Feature GetClonedFeature(Feature feature, IEnumerable<string> returningColumnNames)
            Dictionary<string, string> columnValues = new Dictionary<string, string>();
            foreach (string columnName in returningColumnNames)
                if (feature.ColumnValues.ContainsKey(columnName))
                    columnValues.Add(columnName, feature.ColumnValues[columnName]);
                else
                    columnValues.Add(columnName, string.Empty);
            byte[] wellKnownBinary = feature.GetWellKnownBinary();
            byte[] projectedWellKnownBinary = new byte[wellKnownBinary.Length];
            Buffer.BlockCopy(wellKnownBinary, 0, projectedWellKnownBinary, 0, wellKnownBinary.Length);
            Feature insideFeature = new Feature(projectedWellKnownBinary, feature.Id, columnValues);
            insideFeature.Tag = feature.Tag;
            return insideFeature;
Phil,
 About the shape file problem, I couldn’t figure out the source reason, could you provide the shape files as well?
thanks James,
When i paste this into my code i get an error on "inMemoryFeatureLayer.InternalFeatures". Saying it doesnt exist in the current context. What am i missing?
thanks
Phil
 Phil,
I think you may changed some code of the orginal code community sample, I have attached the whole project you can look at it.
KmlExtensionSample.zip (336 KB)
