Hello ThinkGeo,
In our WPF application, I need load the kml files of pipe lines and show them on the map. I found Bingmaps always has an offset compared to google map and open street map as following screenshots:
Open street map:
Bingmaps:
I still have problem to show google map in my application as what I said in my last post, so I use Google earth to show it.
You can see the line’s location on BingMaps is slightly different to the other maps.
Even the GPS coordinates are slightly different.
Do you have any idea about this?
Thanks for your help.
Cheers
Min
