Hi ThinkGeo,
Some problems
1) Label on marker reduces the visible size (see attached fig) based on the sample on Markers->Label & Rotate marker. Taken websamples.thinkgeo.com
2) As a affect on 1 above, If there is popup associated and markers are close by then popup shows up even when the mouse is not over the marker. This causes confusion to the user.
3) In the sample, Text does not rotate with the marker.
Anil
LabelOnMarkerReducesVisibleSize.zip (262 KB)
