Label Plotting on Map
Dear All,
I am able to plot label on map, for that I am using following code,
Dim CustomTextStyle As TextStyle = New TextStyle
Dim colName As String = drpField.Text.Trim  'List of column in drop down
Dim Layer As FeatureLayer = WinformsMap1.FindFeatureLayer("WorldLayer")
CustomTextStyle = TextStyles.CreateSimpleTextStyle(colName, CustomTextStyle.PointPlacement = PointPlacement.Center
CustomTextStyle.OverlappingRule = LabelOverlappingRule.NoOverlapping
CustomTextStyle.DuplicateRule = LabelDuplicateRule.UnlimitedDuplicateLabels
Layer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(CustomTextStyle)Layer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
 The above code placed label at desired position.
1.  Now I want to change label with help of select column from dropdown (drpField) and click to show label, it shows label, but old label is also there, I want to before display the current label old label should be clear.
2. If user don't want to show any label, that should be clear on map.
Regards
Sanjay
Hi Sanjay,
From your code snippet, it seems that you didn't modify old text style, you just kept the old text style untouched and added new text style, so the old style is still visible.
Please check the following solutions for your questions:
Find the old text style and modify "TextColumnName" property, then refresh the map.
Reomve the old text style from "CustomStyles" collection.
Ivan
Hi Ivan,
 THanks for reply.
 Actually I trired to remove the custome style like below:
 If Layer.ZoomLevelSet.ZoomLevel01.CustomStyles.Contains(CustomTextStyle) Then
                 Layer.ZoomLevelSet.ZoomLevel01.CustomStyles.Remove(CustomTextStyle)
             End If
 But the condition always returns false. So please brief above points with example, it will help me.
 Regards
 Sanjay
Hi Sanjay,
Although I don't know the detailed logic about your application, it should be convenient to modify this text style by using local variable as the follwing code.
private TextStyle textStyle;
private void LoadEvent(object sender, EventArgs e)
    // Initialize
    textStyle = TextStyles.City1("CNTRY_NAME");
    winformsMap1.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(textStyle);
private void SomeEvent(object sender, EventArgs e)
    FeatureLayer layer = winformsMap1.FindFeatureLayer("WorldLayer");
    if (layer.ZoomLevelSet.ZoomLevel01.CustomStyles.Contains(textStyle))
        // Modify
        textStyle.TextColumnName="RECID";
        // Clear
        layer.ZoomLevelSet.ZoomLevel01.CustomStyles.Remove(textStyle);
        winformsMap1.Refresh();
Ivan
Hi Ivan
 Thanks for reply,
 1. Now my first point is resolved. Now I am able to change the current label. Now old label removed and new label coming.
 2. Now, When I am trying to display map without any label, its not working for me.
 Dim layer As FeatureLayer = WinformsMap1.FindFeatureLayer("WorldLayer")
 If layer.ZoomLevelSet.ZoomLevel01.CustomStyles.Contains(CustomTextStyle) Then
             layer.ZoomLevelSet.ZoomLevel01.CustomStyles.Remove(CustomTextStyle)
 End If
 layer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
 Application.DoEvents()
 WinformsMap1.Refresh()
 when I am cheking condition, it returns true, but label not removed from map.
 Regards
 Sanjay
Hi Sanjay,
 I have tested the code snippet I provided in the previous post, it works for both updating and removing. So if you can provide us a self-contained sample to re-produce your issue, it will be helpful to find the root cause.
 Ivan
Hi Ivan,
 Thanks for replay.
 I have tested the code on seperate project and its working for both purpose. So I will implement this in my main project.
 Regards
 Sanjay
Sanjay,
 Thanks for your post and letting us know your status.
