Label Street name on a map layer
I understand the street names exist in the dbf file corresponding to a shp file which defines the ShapeFileFeatureLayer.
But I am not sure what are the API methods can be used to label those street segments shown in the street layer.
1.) How do you read the dbf file if one doesn't have FoxPro but only SQL 2008?
2.) What are the API syntax for adding the street labels? Thanks very much.
Franklin,
Thanks for your post and questions, hope my following answer can give you some hints.
1)      We read the dbf file with our own dbf library, we do not rely on FoxPro to read it, technique speaking, we read the dbf file bytes by bytes based on the full understanding of dbf file format. And now, we have public this library out, you can go to the class GeoDbf for more useful APIs.
2)      Generally we use the static APIs in TextStyles to create TextStyle for your shape file labeling, let’s say when you want label street, you can use the predefined style like TextStyles.MajorRoad1("LabelColumn") to label you street and here the “LabelColumn” is the column name to fetch label text from. Also, you can create your own style based on the APIs CreateSimpleTextStyle provided in the TextStyles class.
HI Yale,
  Thanks for the hints. I will try them out.
 Franklin
Franklin,
Thanks for your feedback, please go ahead and take your try.
