Labeling long road lines
We are having issues with some World Mapkit Roads and labeling them.  Users only get to see a label in the center of the line shape.  This is typically fine in towns and some rural areas, but in multiple instance in Texas there are roads that are over 30 miles in length.  In order to know what road you are looking at you have to scroll or zoom quite far.  Is there a way to label the shapes in the center of the currently viewed portion of the road?
As you can see above, this road is extremely long, and only has 1 label for the entire portion.   If I view this same road in OpenStreetMap.org (the source of my world mapkit data), they label this road several times in the screen, regardless of what portion of the road I am viewing:
Is it possible to label my roads like they do?  What settings are needed for that?  Here are my current label settings:
var txt = new TextStyle(“name”, new GeoFont(“Verdana”, fontSize), new GeoSolidBrush(new GeoColor(255, 102, 102, 102)))
    HaloPen = new GeoPen(new GeoColor(200, 255, 255, 255), 3),
    DuplicateRule = LabelDuplicateRule.UnlimitedDuplicateLabels,
    ForceLineCarriage = true,
    LabelAllLineParts = true,
    LabelAllPolygonParts = true,
    OverlappingRule = LabelOverlappingRule.AllowOverlapping,
    PolygonLabelingLocationMode = PolygonLabelingLocationMode.Centroid,
    GridSize = 5,
    FittingPolygon = false,
    SplineType = SplineType.StandardSplining
I should have taken a longer look at my options, I was able to get this working much better by using the FittingLineInScreen = true; setting.
Hi Jake,
 I am glad to hear that works by set the FittingLineInScreen property.
 Any question please let me know.
