Labels appear/disappear when panning or zooming
 I have a problem with applying labels to a layer where some of the labels show but not all of them. When I zoom in/out or drag to pan the map the labels change with some disappearing and others appearing. I have tried setting the AllowOverLapping, UnlimitedDuplicateLabels, SuppressPartialLabels = false and GridSize = 10 to try and solve the issue but I haven’t had any luck with any of them.
I have attached a zip file containing a version of my code and the shapefile I’m using, could you please check this and see if you have the same problem and how I might be able to fix it?
map.aspx.zip (6.2 KB)
Hi Simon,
 I have recreated your problem and solve that.
 Your question is you add the text style to custom styles but you still set the value to default text style.
Here I changed your code simply and it works well now.
                worldLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(classBreakStyle);
                worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level15;
                worldLayer.ZoomLevelSet.ZoomLevel16.CustomStyles.Add(classBreakStyle);
                TextStyle worldLayerTextStyle = TextStyles.CreateSimpleTextStyle("Ph", "Arial", 12, DrawingFontStyles.Bold, GeoColor.StandardColors.Black, 0, 0);
                worldLayerTextStyle.SuppressPartialLabels = true;
                worldLayerTextStyle.DuplicateRule = LabelDuplicateRule.UnlimitedDuplicateLabels;
                worldLayerTextStyle.OverlappingRule = LabelOverlappingRule.AllowOverlapping;
                worldLayerTextStyle.GridSize = 10;
                worldLayerTextStyle.BestPlacement = true;
                worldLayer.ZoomLevelSet.ZoomLevel16.CustomStyles.Add(worldLayerTextStyle);
                worldLayer.ZoomLevelSet.ZoomLevel16.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
                worldLayer.DrawingMarginPercentage = 50;
That works perfectly.
Thanks Don.
Simon,
 Any more questions please feel free to let us know.
