Labels not showing at zoom levels 17 - 20
We have defined custom text styles for labeling roads, as you can see below, however when you get to zoom level 17 the labels do not appear to change and by the time you get to zoom level 20 you cannot see the road name.  Any and all suggestions would be greatly appreciated.
'Line Text Styles
        Dim textStyle As TextStyle = TextStyles.Utility1(MyDataRow.Item("MapLLabelField"))
        textStyle.Font = New GeoFont("Arial", 4)
        textStyle.TextLineSegmentRatio = Double.MaxValue
        textStyle.DuplicateRule = LabelDuplicateRule.UnlimitedDuplicateLabels
        textStyle.SplineType = SplineType.Default
        textStyle.OverlappingRule = LabelOverlappingRule.NoOverlapping
        textStyle.SuppressPartialLabels = True
        textStyle.GridSize = 1
        Dim textStyle2 As TextStyle = TextStyles.CreateSimpleTextStyle(MyDataRow.Item("MapLLabelField"), "Arial", 7, DrawingFontStyles.Bold, GeoColor.StandardColors.Black)
        textStyle2.TextLineSegmentRatio = Double.MaxValue
        textStyle2.DuplicateRule = LabelDuplicateRule.UnlimitedDuplicateLabels
        textStyle2.SplineType = SplineType.StandardSplining
        textStyle2.BestPlacement = True
        textStyle2.GridSize = 1
myLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = textStyle
        myLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level16
        myLayer.ZoomLevelSet.ZoomLevel17.DefaultTextStyle = textStyle2
        myLayer.ZoomLevelSet.ZoomLevel17.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
Tim,
 It should be working, so if you set two text styles to the same, does it work?
 if you can provide your sample data we can easy to test and find the problem.
 Let me clarify my issue.  When using the text styles defined above and applying them to the roads the labels appear on the map for all of the zoom levels however when the zoom level is greater than or equal to 17 the labels do not seem to move from their original position and thus cannot be seen in certain areas of the map when you pan around.  I hope that better defines the situation we are facing.
TIM,
 I hope my understanding is on the right direction. Yes, as you already have noticed, the labeling position for a specified line shape will not change according to zoom levels; it will always be labeled at its center location. So, when you zoom into detailed zoom levels such as ZoomLevel17 or even ZoomLevel20, the label position is still the center of the whole lineshape, which probably exceed the current extent.
 Hope that can explain what is happening in your case.
Tim,
 I did some test by your code, I think another possible to cause the problem is that your data is not suitable for SplineType.StandardSplining, could you set SplineType of textStyle2 to Default or None and see if the labels can show on zoomlevel 17 to 20.
James,
 I tried out your suggestion and it did not make a difference in the way the labels were displayed.  I have a small project that will hopefully clarify the issues we are experiencing.  If you zoom down to level 20 you will notice that on certain roads you cannot see a label.  Please advise on how this can be corrected.
Public Class Form1
    Private text1 As TextStyle
    Private text2 As TextStyle
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        text1 = TextStyles.Utility1("Street")
        text1.Font = New GeoFont("Arial", 4)
        text1.TextLineSegmentRatio = Double.MaxValue
        text1.DuplicateRule = LabelDuplicateRule.UnlimitedDuplicateLabels
        text1.SplineType = SplineType.Default
        text1.OverlappingRule = LabelOverlappingRule.NoOverlapping
        text1.SuppressPartialLabels = True
        text1.GridSize = 1
        text2 = TextStyles.CreateSimpleTextStyle("Street", "Arial", 7, DrawingFontStyles.Bold, GeoColor.StandardColors.Black)
        text2.TextLineSegmentRatio = 100
        text2.DuplicateRule = LabelDuplicateRule.UnlimitedDuplicateLabels
        text2.SplineType = SplineType.None
        text2.BestPlacement = False
        text2.GridSize = 1
        LoadMap()
    End Sub
    Private Sub LoadMap()
        map.MapUnit = GeographyUnit.DecimalDegree
        map.BackColor = Color.White
        Dim shapeOverlay As LayerOverlay = New LayerOverlay()
        Dim di As DirectoryInfo = New DirectoryInfo("…/…/Shape")
        For Each fi As FileInfo In di.GetFiles("*.shp")
            Dim myLayer As ShapeFileFeatureLayer = New ShapeFileFeatureLayer(fi.FullName)
            myLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle = LineStyles.CreateSimpleLineStyle(GeoColor.StandardColors.Red, 2, True)
            myLayer.ZoomLevelSet.ZoomLevel17.DefaultLineStyle = LineStyles.MajorRoad1()
            myLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = text1
            myLayer.ZoomLevelSet.ZoomLevel17.DefaultTextStyle = text2
            myLayer.Open()
            map.CurrentExtent = myLayer.GetBoundingBox()
            myLayer.Close()
            shapeOverlay.Layers.Add(fi.Name, myLayer)
        Next
        map.Overlays.Add("ShapeOverlay", shapeOverlay)
        map.Refresh()
    End Sub
End Class
TIM,
Thanks for your post and feedback.
Can you have a try to use the same text style (style1 or style2) from ZoomLevel01 to ZoomLevel20 all the time like as following code snippet shows?
myLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
Or
myLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = text2
I am sorry to say that, I could not recreate your problem as the missing of the test files, if you want, could you send me some test data for it?
I am trying to send the file(s) with the project and the shape files I used.  They should be included with this post.
001_ZoomLevelTest.zip (498 KB)
TIM,
Thanks for your post and sample code.
I tested against the sample code you provided and it works fine, following is the screenshot for ZoomLevel19, the labels display as expected.
As I addressed above, the label positions will not change when zooming in or zooming out, so it is possible for some roads the label “disappear” because its label position is outside of the current extent.
