Labels on InMemoryFeatureLayer
 I have a function called AddPoint that adds a symbol to an InMemoryFeatureLayer on the map.  I need to be able to label the symbol.  I can get the symbol to display, but not the label.
I'm using Visual Studio 2010, vb.net.  Here's the code.    It is a simplified piece of a much larger application.
Imports ThinkGeo.MapSuite.Core
Imports ThinkGeo.MapSuite.DesktopEdition
Imports System.Collections.ObjectModel
Public Class MapLabels
    Public workLayers As New LayerOverlay
    Public workSLayer As New InMemoryFeatureLayer()    'standard work layer
    Public Sub AddPoint(ByVal Longitude As Double, ByVal Latitude As Double, ByVal PointName As String, _
                     ByVal SymbolSize As Single, ByVal SymbolColor As GeoColor, ByVal SymbolChar As PointSymbolType)
        Dim f As Feature
        Dim pt As PointShape
        On Error GoTo AddPoint_ErrorHandler
        'set the style for the work layer
        workSLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.CreateSimpleTextStyle("pt_name", "Arial", 10, DrawingFontStyles.Regular, GeoColor.StandardColors.Black, 0, -12)
        workSLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimplePointStyle(SymbolChar, SymbolColor, SymbolSize)
        workSLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
        pt = New PointShape
        pt.Y = Latitude
        pt.X = Longitude
        f = pt.GetFeature
        f.ColumnValues.Add("pt_name", PointName)
        'add the feature to the work layer
        workSLayer.InternalFeatures.Add(f)
        'zoom to the feature
        AtisMap.CurrentExtent = New RectangleShape(Longitude - 0.004, Latitude + 0.004, Longitude + 0.004, Latitude - 0.004)
        AtisMap.Refresh()
        Exit Sub
AddPoint_ErrorHandler:
        MsgBox("Error:" & Err.Number & " " & Err.Description)
        Resume
    End Sub
    Public Function CreateWorkLayer() As Boolean
        On Error GoTo CreateWorkLayers_errorhandler
        workLayers.Layers.Add("WorkS", workSLayer)
        AtisMap.Overlays.Add("workLayer", workLayers)
        CreateWorkLayer = True
        Exit Function
CreateWorkLayers_errorhandler:
        MsgBox("ERROR: " & Err.Number & " " & Err.Description)
    End Function
    Private Sub showShape()
        Dim worldMapKitDesktopOverlay As WorldMapKitWmsDesktopOverlay = New WorldMapKitWmsDesktopOverlay()
        Dim staticOverlay As New LayerOverlay()
        AtisMap.MapUnit = GeographyUnit.DecimalDegree
        AtisMap.ThreadingMode = MapThreadingMode.SingleThreaded
        AtisMap.Overlays.Add(worldMapKitDesktopOverlay)
        AtisMap.CurrentExtent = New RectangleShape(-74.011701, 40.712748, -74.009, 40.71)
        AtisMap.BackColor = Color.GhostWhite
        AtisMap.Refresh()
        CreateWorkLayer()
    End Sub
    Private Sub btnAddPoint_Click(sender As System.Object, e As System.EventArgs) Handles btnAddPoint.Click
        On Error GoTo data_err
        Dim s As New PointSymbolType
        Dim c As New GeoColor
        Select Case cmbSymbol.Text
            Case "Star"
                s = PointSymbolType.Star
            Case "Square"
                s = PointSymbolType.Square
            Case "Circle"
                s = PointSymbolType.Circle
            Case Else
                s = PointSymbolType.Diamond
        End Select
        Select Case cmbColor.Text
            Case "Red"
                c = GeoColor.StandardColors.Red
            Case "Blue"
                c = GeoColor.StandardColors.Blue
            Case "Green"
                c = GeoColor.StandardColors.Green
            Case Else
                c = GeoColor.StandardColors.Purple
        End Select
        AddPoint(txtLong.Text, txtLat.Text, txtDesc.Text, 36, c, s)
        Exit Sub
data_err:
        MsgBox("Error in data entered")
    End Sub
    Private Sub MapLabels_Load(sender As Object, e As System.EventArgs) Handles Me.Load
        Me.Cursor = Cursors.WaitCursor
        Application.DoEvents()
        showShape()
        Me.Cursor = Cursors.Default
    End Sub
End Class
Hi Serena,
Thanks for your question!
I believe the issue is that your workSLayer - InMemoryFeatureLayer does not have the FeatureSourceColumn that MapSuite needs to read your label from. You successfully added a ColumnValue (pointName) for the Feature's column named "pt_name", but you also need to specify the Column at the InMemoryFeatureLayer level.
InMemoryFeatureLayer workSLayer = new InMemoryFeatureLayer();
workSLayer.Columns.Add(new FeatureSourceColumn("pt_name"));
That worked!  Couldn't find that in any of the samples.
Thank you!
Thank you!
You are welcome!
