Large ShapeFile printing problem
I'm trying to print large shape file (200 MB).
I use "Large Scale Map Printing"  sample codes.
Print preview and printing works fine, The problem ist MapPrinterLayer doesn't show the shape .
I don't see this problem with small shapes.
Thanks in advance.
Shaahin
Hi Shaahin,
 Thanks for your post, please get the latest 6.0.348.0 or 6.0.0.348 and have a try.
 Edgar
Thanks for your response.
Using latest version solved my problem but now send to printer doesn't work with any shape file.
Stack trace :
System.NotSupportedException: "Specified method is not supported."
   at ThinkGeo.MapSuite.Core.PrinterGeoCanvas.NDQ=(GeoBrush NTQ=)
   at ThinkGeo.MapSuite.Core.PrinterGeoCanvas.EzQ=(IEnumerable`1 FDQ=, GeoPen FTQ=, GeoBrush FjQ=, Single FzQ=, Single GDQ=, PenBrushDrawingOrder GTQ=, PrintPageEventArgs GjQ=)
   at ThinkGeo.MapSuite.Core.PrinterGeoCanvas.EDQ=(Collection`1 ETQ=, PrintPageEventArgs EjQ=)
   at ThinkGeo.MapSuite.Core.PrinterGeoCanvas.CTQ=(Object CjQ=, PrintPageEventArgs CzQ=)
   at System.Drawing.Printing.PrintController.PrintLoop(PrintDocument document)
   at System.Drawing.Printing.PrintController.Print(PrintDocument document)
   at System.Drawing.Printing.PrintDocument.Print()
   at ThinkGeo.MapSuite.Core.PrinterGeoCanvas.EndDrawingCore()
   at ThinkGeo.MapSuite.Core.GeoCanvas.EndDrawing()
Printing code : (This is ThinkGeo large scale printing example code and it works wth previous version of DLLs)
 var printerInteractiveOverlay =
                (PrinterInteractiveOverlay) MapControl.InteractiveOverlays[Printpreviewoverlay];
            var pagePrinterLayer = printerInteractiveOverlay.PrinterLayers["PageLayer"] as PagePrinterLayer;
            var printDocument = new PrintDocument {DefaultPageSettings = {Landscape = true}};
            if (pagePrinterLayer != null && pagePrinterLayer.Orientation == PrinterOrientation.Portrait)
                printDocument.DefaultPageSettings.Landscape = false;
            printDocument.DefaultPageSettings.PaperSize = GetPrintPreviewPaperSize(pagePrinterLayer);
            var printerGeoCanvas = new PrinterGeoCanvas
                                           DrawingArea = new Rectangle(0, 0,
        Convert.ToInt32(
        PrintableArea.Width),
        Convert.ToInt32(
        PrintableArea.Height))
            if (pagePrinterLayer != null)
                printerGeoCanvas.BeginDrawing(printDocument, pagePrinterLayer.GetBoundingBox(), MapControl.MapUnit);
            var labelsInAllLayers = new Collection<SimpleCandidate>();
            foreach (PrinterLayer printerLayer in printerInteractiveOverlay.PrinterLayers)
                printerLayer.IsDrawing = true;
                if (!(printerLayer is PagePrinterLayer))
                    printerLayer.Draw(printerGeoCanvas, labelsInAllLayers);
                printerLayer.IsDrawing = false;
            printerGeoCanvas.EndDrawing();
Hi Shaahin,
 Sorry the the confusing, please use the development branch 6.0.348.0 which works fine, the release branch 6.0.0.348 does not support the GeoLinearGradientBrush in PrinterGeoCanvas, so you got the exception.
 Edgar
