I am tryiyng to plot a LAT LONG on google map layer. For that I have used following Attached code:
The Points are plotted but its fall outside location, while the same lat long I am plooting on google map, its plotted on location. Please help in what is the missing part in my code, so that points can be plot as desired location.
What is the format of Meter Map data. Please give example. Can I convert my cordinate data as per google map required format, becuase I set the projection and still, its not supporing.
Dim latitude As Double Dim longitude As Double Dim FileName As String = RootFolderName & "\Images\Aqua.png" Dim winformsMap1 As WinformsMap = DirectCast(Me.WinformsMap1, WinformsMap) Dim pointLayer As InMemoryFeatureLayer = Nothing
Dim txtLatitude As String = "27.13102" Dim txtLongitude As String = "78.00735" latitude = Convert.ToDouble(txtLatitude, CultureInfo.InvariantCulture) longitude = Convert.ToDouble(txtLongitude, CultureInfo.InvariantCulture) pointLayer = DirectCast(winformsMap1.FindFeatureLayer("PointLayer"), InMemoryFeatureLayer) Dim proj4 As Proj4Projection = New Proj4Projection proj4.InternalProjectionParametersString = ManagedProj4Projection.GetEpsgParametersString(4326) proj4.ExternalProjectionParametersString = ManagedProj4Projection.GetGoogleMapParametersString() Try If pointLayer Is Nothing Then pointLayer = New InMemoryFeatureLayer pointLayer.Open() pointLayer.Columns.Add(New FeatureSourceColumn("ID")) pointLayer.Close() pointLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.PointType = PointType.Bitmap pointLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.Image = New GeoImage(FileName) pointLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20 Dim dynamicOverlay As New LayerOverlay() dynamicOverlay.Layers.Add("PointLayer", pointLayer) dynamicOverlay.IsBase = False winformsMap1.Overlays.Add("PointOverlay", dynamicOverlay) End If Catch ex As KeyNotFoundException pointLayer = New InMemoryFeatureLayer pointLayer.Open() pointLayer.Columns.Add(New FeatureSourceColumn("ID")) pointLayer.Close() pointLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.PointType = PointType.Bitmap pointLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.Image = New GeoImage(FileName) pointLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20 Dim dynamicOverlay As New LayerOverlay() dynamicOverlay.Layers.Add("PointLayer", pointLayer) dynamicOverlay.IsBase = False winformsMap1.Overlays.Add("PointOverlay", dynamicOverlay) Finally SearchId = SearchId + 1 Dim feature As New Feature(longitude, latitude, SearchId) feature.ColumnValues.Add("ID", SearchId) pointLayer.InternalFeatures.Add(SearchId, feature) pointLayer.FeatureSource.Projection = proj4 winformsMap1.CenterAt(New PointShape(longitude, latitude)) winformsMap1.Refresh(winformsMap1.Overlays("PointOverlay")) End Try
It will work as soon as you set the right projection to pointlayer. What’s the situation you met? It did’nt shows on the map, or actually it shows but you didn’t see it because your extent is in wrong place? Because I saw this code:
