Latitude and logitude
hi
I want that Latitude and logitude lines should be displayed in my map.How to do this??
I am using Mapsuite full edition 3.0
Bhagyashree,
 I think that you are refering to graticule with parallels and meridians. For this, you can refer to the Code Community sample, Graticule with Projection wiki.thinkgeo.com/wiki/Map_Suite_We...Projection. It shows how to use the GraticuleAdornmentLayer and also how to have it to the projection of your map if it is in a projection other then Geodetic. Dealing with projection for GraticuleAdornmentLayer might also be relevant for your case, if not,  ignore this aspect.  The sample is in the Wpf edition but the same principles apply for the Web edition too. Thank you.
Bhagyashree,
 I saw the sample app for graticule,but I unable to understand it .
 Reply soon.
Bhagyashree,
  You are going to have to elaborate a little more on what you did not understand. Are the graticule not what you are expecting? Couldn’t you run the app? Maybe you want to see that same sample in the web version? Tell us how you want us to help you exactely. Thank you.
