Layer.DrawPolygonLayer failed Error
Please note the the following error is occuring with DesktopEdition 2.0.  We are currently coverting over to version 6.0, for our release next year, but the current version is using v2.0.  We are not seeing the error in the version 6.0 code.
As of this morning, I have started getting a new error, Layer.DrawPolygonLayer failed.  This error occurs whenever the function MyMap.GetBitmap is called.  The inner exception is "Unable to read beyond the end of the stream."
This error only started occuring today following a reboot after Microsoft updates downloaded and installed.  We are only seeing it on this one machine.  The code was running fine as of yesterday.  It is happening both with the installed application, and when running Visual Studio.  The machine has been rebooted several times.  Also, v2.0 has been uninstalled and reinstalled, but the error still occurs.
I don't expect any support on v2.0, but I wanted to see if there have been other reports of something like this, or if this has been seen in the past.
Dib Oglesby
Sea Island Software
Hi Dib,
 V2.0 is a very very old version of out product, as far as I know, I’ve not seen the exception before, and as you said, there is no such exception in 6.0, it’s a good choice to upgrade to 6.0 :)
 Edgar
