Hi Ben, sure! Here are inefficiencies we found while working with the MCP - Sorry for the AI summary
The largest cost was obtaining reliable answers for the specific SDK version. Ranked by impact:
MCP coverage misses the APIs we actually need.
I rechecked: WmsRasterTileSource and FeatureSourceVectorTileSource both return zero results, although they exist in the installed package. That forces assembly inspection and forum follow-ups.
Improvement: Index the current GPU/native-grid API reference and matching samples, with exact-symbol lookup.
The MCP duplicates forum content and labels it as documentation.
tg_index_stats shows docs and community pointing to the same directory. Searching WmsAsyncLayer returns the same forum thread twice, under those two namespaces. This wastes result slots and obscures whether something is an authoritative API reference.
Improvement: Separate documentation from forum sources, deduplicate results, and expose the source type clearly.
Search results lack SDK-version context.
The search interface has no SDK-version filter, and results do not identify their applicable package version. The index timestamp cannot tell us whether an example matches beta174, beta179 or beta181.
Improvement: Include version/branch metadata, version filters, and links to relevant breaking changes. Label material whose version is unknown.
Coordinate and tile-grid contracts require too much investigation.
Understanding the relationship between DisplayProjection, source coordinates, tile grids, WMS CRS, converters and style scales required combining forum explanations with implementation inspection. The new constructors solve the functional gap, but the complete usage contract remains difficult to discover.
Improvement: Provide one complete native projected-map sample covering vectors, WMS, local rasters, highlights and scale-dependent styling. Document coordinate expectations beside each relevant API.
Upgrade guidance arrives piecemeal.
Removing IRasterTileSource, changing override signatures and introducing grid constructors affected several integration points. Individual forum replies explained these, but assembling the migration remained manual.
Improvement: Publish a versioned migration checklist and compile-checked samples covering the affected APIs.
Projected PMTiles support remains an optimization gap.
The inspected beta181 generator and reader do not expose the native-grid configuration needed here. Consequently, this integration uses runtime vector cutting instead of the archive path. Its performance cost has not been measured.
Improvement: Support consistent grid configuration during both archive generation and reading. This is recorded in the remaining API request (see WMS/WFS Feedback / Wishes - #10 by Ben)
