Layers Geometry
 Hello ,
Im having the following problem i need to be able to load different layers without knowing what each layer displayes. Is there a way after selecting the db Table with the layer finding out if the records of the table are poinst or  polygons e.t.c
Thanks in advance
dom
Hello Dimitris,
 Thanks for your post, which layer are you using? For most layers, after you get your featuresource, you can use GetWellKnownType method that can return every feature’s type, then you can determine the pointshape or polygons.
 Hello Gary ,
Thank you for your reply, i managed to solve this problem using the WellKnownType. The problem im having now is removing an overlay from the map.
Im having a list of layers that the user can check or uncheck in order to show them on the map the problem is that when i uncheck a layer and i remove it from the code it stayes on the map
Every overlay is declared like this
TestOverlay = new LayerOverlay("TOverlay" + tblName, false, TileType.SingleTile);
in order to be unique So when i uncheck the checkbox i just declare the Overlay and then i remove it
Map1.CustomOverlays.Remove(TestOverlay);
But it does not work . whereas if i declared manually an overlay for each layer then the .Remove method works fine
Any thoughts
thanks in advance
dom
Hello Dimitris,
Thanks for your further information, I think the problem is you should use the overlay's key value(id) instead of using overlay's name when you remove.
Map1.CustomOverlays.Remove("TOverlay" + tblName);
Hi Gary ,
you are right
thanks for your help
Hello Dimitris,
 You are welcome, please feel free to let us know your questions.
