I was wondering about the Legend and OverlaySwitcher. I want to have the functionality of an OverlaySwitcher with the features style associated with the item. Here is an example of the desired outcome is screencast.com/t/bpIojzbr.
I have found other forum examples that seem to suggest that the OverlaySwitcher would need to be edited on client side thinkgeo.com/forums/MapSuite/tabid/143/aft/12161/Default.aspx. Is this a effective way to accomplish this outcome? I also noticed this example screencast.com/t/Pyl5KdhSkC which divs an area. Would this be the way you suggest?
Thank you,
Neil
Legend and/or OverlaySwitcher
Hi Neil,
The item in OverlaySwitcher is our overlay, so you cannot shows layer in it.
You should want to put layer to separated overlay, then assign name or id to overlay, the overlays should be listed in overlaySwitcher, please try that.
To implement the div like screencast.com/t/Pyl5KdhSkC should not be so easy, but if you want to do that, you can view our code in the sample.
