Legend text style does not persistent
I have created a legend with a title and several items. Title and items have different text styles.
then set height and width as below:
legendLayer.Height = (cbStyle.ClassBreaks.Count) * 45;
 legendLayer.Width = 260;
 legendLayer.Title = title;
 legendLayer.Location =
AdornmentLocation.UpperRight;
 m.AdornmentOverlay.Layers.Add(LegendLayerName, legendLayer);
Legend item’s text style is set with font 8 to start. It works when first time loading the map. However, then if I zoom the map and change map scales, the fond changes to 10 and items are closer to each other: I noticed that the legend’s height/weight did not get changed. It did not call the function that created the legend.
Any ideas?
Guangming
Hi Guangming,
 Have you set ContentResizeMode of LegendAdornmentLayer to Fixed?
no. Seems set to Fixed fixes the problem. So what is default?
Hi Guangming,
 It looks Resizable should be the default value.
