LegendItem text alignment
I am adding legends to our map, and am having issues with the text aligment.  If the legend item spans the entire width of the map, as some of ours do, and the item only contains text, with no images, I can't get the text to left-justify.  It either shows up indented a good bit, or, in some cases, we have seen it draw correctly initially, and then once anything is done to the map, if the extent is changed at all, the legend item redraws with the text indented again.  When creating legend items that don't span the entire width, I can add a new LegendItem to LedendAdornmentLayer, and the text will be left-aligned as expected.
Here is the code that is currently not working as expected:
Dim stormInfoBoxLayer As New LegendAdornmentLayer
        stormInfoBoxLayer.Name = layerName_StormInfoLegend
        stormInfoBoxLayer.BackgroundMask = AreaStyles.CreateLinearGradientStyle(New GeoColor(255, 255, 255, 255), New GeoColor(255, 230, 230, 230), 90, GeoColor.SimpleColors.Black)
        stormInfoBoxLayer.Location = AdornmentLocation.LowerRight
        stormInfoBoxLayer.Height = lineHeight + 8
        stormInfoBoxLayer.Width = Me.Map.Width
        Dim sibItemText As New LegendItem
        sibItemText.TextStyle = New TextStyle(stormInfoText, New GeoFont("Arial", 9, DrawingFontStyles.Regular), New GeoSolidBrush(GeoColor.SimpleColors.Black))
        sibItemText.ImageJustificationMode = LegendImageJustificationMode.JustifyImageRight
        sibItemText.Height = lineHeight
        sibItemText.TextLeftPadding = 0
        sibItemText.TextTopPadding = 1
        sibItemText.TextBottomPadding = 1
        sibItemText.TopPadding = 0
        sibItemText.BottomPadding = 0
stormInfoBoxLayer.LegendItems.Add(layerName_StormInfoLegend, sibItemText)
Me.Map.AdornmentOverlay.Layers.Add(layerName_StormInfoLegend, stormInfoBoxLayer)
A few more notes:
 I have my LegendAdornmentLayer .Location = AdornmentLocation.LowerLeft.  The map’s width is 718.  If I set the adornment layer to 301 or less (or lower than 43% of map width), the legend items stack on top of each other when added, so that they can be read easily.  If the width is set to 302 or higher (or 43% or higher) the second added legend item shows up on the same horizontal line as the first, around the midpoint of the first item.
Hi Dib,
 Thanks for your post, we have fix the bug, please get the 6.0.0.250 or 6.0.250.0 and have a try.
 One more thing is that if you need to display two legenditems in two rows, you need to make stormInfoBoxLayer.Height high enough to display them. otherwise they will be displayed in one row automatically.
 Hope it helps.
 Edgar
Will do.  I see the .250 eval version under Evaluation Daily Builds\Daily Productions Builds, but the full version isn’t available under My Product Downloads yet.  Once it is there I will get to work on it.
Looks good so far.  Thanks
You’re welcome, if you have any other questions, please let us know.
 Edgar
