Licensing error upon reinstall?
Dear Sirs.
I am writing a (for us) largish application, in which we use Map Suite.
I can run and debug the map parts of the program without problems, but when I try to run any of the samples, I get an exception, telling me that I should get a copy of the evaluation version, or use the Product Center to register a version.
Product Center for both version 8.0 and 9,0 both lists my license as activeted on this machine.
Any indications on what to do to be able to run the samples.
I have tried to create a micro test program, just instantiating a map. This also fails.
Best regards,
Keld List Laursen
Hi Keld,
The exception is thrown when you are using the Evaluation DLLs without “Start Evaluation” in Product Center, as you bought the license, I guess you should do the “Activate License” directly in Product Center, that’s the reason your application runs well with FULL Edition DLLs, but the samples reference the EVALUATION Edition DLLs by default after installation. Please try referencing the FULL edition DLLs in the sample project as well.
