Line Buffering Question
Hi.
I would like to know how buffering is applied to the line shape.
The bounding box height of the buffer result is more (270 feet) than expected (200 feet)
      'Create horizontal line 100 feet long
      Dim p1 As New PointShape(-95.606609822483733, 41.805456965812482)
      Dim p2 As New PointShape(-95.606609822483733, 41.805456965812482)
      p2.TranslateByOffset(100, 0, GeographyUnit.DecimalDegree, DistanceUnit.Feet)
      Dim ls As New LineShape
      ls.Vertices.Add(New Vertex(p1))
      ls.Vertices.Add(New Vertex(p2))
      'Check the length of the line = 100.974975459508 - Approximately correct
      Console.WriteLine("Length: " & ls.GetLength(GeographyUnit.DecimalDegree, DistanceUnit.Feet))
      'Apply 100 feet buffer to the line
      Dim mps As MultipolygonShape = ls.Buffer(100, GeographyUnit.DecimalDegree, DistanceUnit.Feet)
      'Get bounding box from the buffer result
      Dim ext As RectangleShape = mps.GetBoundingBox
      'Check the width of the bounding box = 302.92317075103 - Approximately correct
      ls = New LineShape
      ls.Vertices.Add(New Vertex(ext.UpperLeftPoint))
      ls.Vertices.Add(New Vertex(ext.UpperRightPoint))
      Console.WriteLine("Width: " & ls.GetLength(GeographyUnit.DecimalDegree, DistanceUnit.Feet))
      'Check the height of the bounding box = 270.923746270921 - Expected +- 200 feet
      'Where extra 70.92 feet come from?
      ls = New LineShape
      ls.Vertices.Add(New Vertex(ext.LowerLeftPoint))
      Console.WriteLine("Height: " & ls.GetLength(GeographyUnit.DecimalDegree, DistanceUnit.Feet))
 Hi Sergei,
Thanks for your post, the reason for this phenomenon is that both NTS and SqlTypes will buffer by decimal degree, our core will change the 100 feet distance to decimal degree by using
DecimalDegreeHelper. GetLongitudeDifferenceFromDistance(double distance, DistanceUnit distanceUnit, double latitude). And when latitude is 41.805456965812482, 100 feet longitude line covers more degrees than when latitude is 0, so the distance buffered latitude is larger than ecpected.
If you change
To
   Dim p1 As New PointShape(-95.606609822483733, 0)
   Dim p2 As New PointShape(-95.606609822483733, 0)
You will find out that the height will be about  200.
Hope it helps
Johnny,
thank you for response.
Calculating the height has nothing to do with the Y value.
Y can be any decimal degree value and when buffer is applied, height should be the same regardless of Y.
Here is the same example again but this time I'm using Micrsofoft Sql Server STBuffer function and height is correct now.
This is the new output:
Length: 100.974975459508
Width: 300.454959392744
Height: 200.228274310505
Imports ThinkGeo
Imports ThinkGeo.MapSuite
Imports ThinkGeo.MapSuite.Core
Imports ThinkGeo.MapSuite.DesktopEdition
Imports Microsoft.SqlServer.Types
Imports System.Data.SqlTypes
  Private Sub Form1_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load
    Try
      'Dim mps As MultipolygonShape = ls.Buffer(100, GeographyUnit.DecimalDegree, DistanceUnit.Feet)
      Dim ps As PolygonShape = Buffer(100, ls)
      'Dim ext As RectangleShape = mps.GetBoundingBox
      Dim ext As RectangleShape = ps.GetBoundingBox
      ls = New LineShape
      ls = New LineShape
  End Sub
  Private Function Buffer(feet As Double, ls As ThinkGeo.MapSuite.Core.LineShape) As ThinkGeo.MapSuite.Core.PolygonShape
    Dim wkt As String = ls.GetWellKnownText
    Dim srid As Integer = 4326
    Dim sc As New System.Data.SqlTypes.SqlChars(wkt)
    Dim geom As Microsoft.SqlServer.Types.SqlGeometry = Microsoft.SqlServer.Types.SqlGeometry.STGeomFromText(sc, srid)
    If Not geom.STIsValid Then
      geom = geom.MakeValid
      geom = geom.STUnion(geom.STStartPoint)
      sc = New System.Data.SqlTypes.SqlChars(geom.ToString)
    End If
    Dim geog As Microsoft.SqlServer.Types.SqlGeography = Microsoft.SqlServer.Types.SqlGeography.STGeomFromWKB(geom.STAsBinary, srid)
    'convert feet to meters
    wkt = geog.STBuffer(feet / 3.2808).ToString
    Dim bs As ThinkGeo.MapSuite.Core.BaseShape = ThinkGeo.MapSuite.Core.BaseShape.CreateShapeFromWellKnownData(wkt)
    Return CType(bs, ThinkGeo.MapSuite.Core.PolygonShape)
  End Function
  Here is buffer applied to the 100x100 feet rectangle:
Hi Sergei,
 Thanks for your further information, and I noticed that you are using SqlGeography.STBuffer, but inside our core we are using SqlGeometry.STBuffer, the same result with ours will be found by using the following code:
 geom.STBuffer(DecimalDegreesHelper.GetLongitudeDifferenceFromDistance(100, DistanceUnit.Feet, 41.805456965812482)).ToString());
 Instead of
 geog.STBuffer(feet / 3.2808).ToString();
 If you have any question, please feel free to let us know.
 Hope it helps.
 Edgar
