I need to be able to have a style that shows the start and end points of a line.
I know this is a custom style, but I am unable to determine how to show the end points.
Elisa
Elisa
It is the end of my work day and I want to give you some response before I give you a more precise answer tomorrow. We already have two projects in the Code Community that are pretty similar to what you are asking for. I recommend you check out the project displaying One-way Street which is almost identical to what you are asking. code.thinkgeo.com/projects/show/onewaystreets
Also, the project Distance Line Style is pretty similar. code.thinkgeo.com/projects/show/distancelinestyle
If you are still struggling, let us know and we will give you the exact solution.
Val:
Thanks for the links. However, the most useful one is the distancelinestyle, and it is written for the Web Edition.
Could you give me a bit more direction in creating my own style? What I am looking for is a line with a small dot at the start,
and an arrow at the end pointing in the direction of the line. I have two different layers that will use the same style, but in different colors.
The sample shows adding text. I don’t know how to create a point style for the dot and arrow for the end points.
I am using Desktop Edition v4 using the winformsMap component
Elisa
Elisa,
I can point you to a video all about creating your own custom styles. Regardless of if the sample is written for one product or another the Style is part of the MapSuiteCore as thus the same for all editions. If you take any style from the sample and add it to the Desktop Edition it will compile and run fine. Check out the video and if you still need help let us know and we can do a sample to help.
Extending Map Suite: Creating Custom Styles - 3/11/2009
gis.thinkgeo.com/Products/GISComponentsforNETDevelopers/MapSuiteDesktopEdition/Videos/tabid/679/Default.aspx
Elisa,
I let you know that today, we published a project in the Code Community related to your topic of displaying a line with start and end points.
-Start End LineStyle: code.thinkgeo.com/projects/show/startendlinestyle
