We recently tried printing using an area style with the GeoLinearGradientBrush as the Advanced property. We found that the gradient does not draw correctly when creating a pdf with PdfSharp or Microsoft PDF Printer. I have attached a sample project so you can see. Also attached is a sample pdf to demonstrate the problem.
Thanks to point that, it looks because the structure problem, we hadn’t implement the LinearGradientBrush succeed for PDF, when I test your sample and click “Make PdfSharp”, the result is print as the start color.
I had let our developer knows it.
And the Microsoft PDF print looks maybe a bug, our developer will look into it at the same time.
Here is an update, the old logic for LinearGradientBrush don’t works well for both PDF and for Printer, some result of them for example LinearGradientBrush for text style looks strange.
Our developer is busy for new release these days and don’t have enough time to complete the new logic, They will go on implement it after back from vacation.
Thanks. It still does not work for me with PdfSharp, but we don’t use PdfSharp anyway. And our users don’t seem to use LinearGradientStyle that much. Do you know when this fix will be available in a production build?
Do you means the PDF still don’t works well in latest development package? We test again and will look into that.
We will move the changes into production branch in next minor release, if that’s hurry for you please let us know, we can try to move it manual, but because this change related many classes, so it’s not easy to do that, we need to make sure it had been fixed and it’s stable at first.
