LineShape breaks around 180
LineShape that crosses 180 does not draw correctly.
Here is what I get when LineShape is:
LINESTRING(171.528 60.713,171.649 60.69,171.785 60.722,171.836 60.755,171.988 60.783,172.114 60.799,172.256 60.853,172.462 60.947,172.552 61.007,172.708 61.066,172.827 61.118,172.956 61.15,173.193 61.196,173.352 61.212,173.593 61.248,173.82 61.26,174.031 61.271,174.284 61.305,174.485 61.322,174.753 61.334,175.066 61.347,175.296 61.344,175.43 61.306,175.577 61.277,175.693 61.254,175.814 61.229,175.784 61.287,175.701 61.331,175.733 61.42,175.882 61.449,176.017 61.508,176.125 61.504,176.206 61.472,176.352 61.413,176.528 61.396,176.736 61.407,176.928 61.425,177.038 61.442,177.251 61.357,177.401 61.326,177.528 61.326,177.597 61.359,177.61 61.44,177.674 61.473,177.887 61.482,177.986 61.457,178.171 61.445,178.475 61.479,178.545 61.519,178.789 61.546,179.029 61.568,179.238 61.598,179.504 61.634,179.632 61.664,179.848 61.662,179.992 61.662,-179.859 61.662,-179.771 61.691,-179.704 61.769,-179.667 61.823,-179.511 61.874,-179.401 61.908,-179.261 61.924,-179.089 61.94,-179.048 61.912,-179.097 61.859,-179.222 61.813,-179.317 61.76,-179.442 61.7,-179.581 61.647,-179.685 61.598,-179.829 61.564,179.967 61.466,179.921 61.401,179.911 61.308,179.967 61.217,-179.887 61.132,-179.857 61.076,-179.852 61.013,-179.943 60.949,179.977 60.918,179.882 60.876,179.872 60.823,179.962 60.757,-179.928 60.699,-179.804 60.684,-179.552 60.61,-179.17 60.657,-179.041 60.665,-178.896 60.676,-178.82 60.732,-178.806 60.809,-178.683 60.888,-178.624 60.963,-178.581 61.036,-178.523 61.089,-178.515 61.138,-178.445 61.205,-178.441 61.273,-178.304 61.371,-178.196 61.463,-178.049 61.524,-177.837 61.547,-177.637 61.602,-177.413 61.646,-177.165 61.648,-176.964 61.609,-176.873 61.553,-176.811 61.507,-176.622 61.424,-176.559 61.319,-176.479 61.268,-176.378 61.221,-176.421 61.122,-176.469 61.065,-176.444 61.01,-176.426 60.971,-176.225 60.857,-176.126 60.781,-176.016 60.672,-175.896 60.612,-175.876 60.601,-175.845 60.54,-175.728 60.489,-175.622 60.416,-175.49 60.373,-175.272 60.284,-175.079 60.107,-175.003 59.923,-175.014 59.732,-174.933 59.587,-174.894 59.421,-174.756 59.315,-174.535 59.217,-174.396 59.088,-174.303 58.995,-174.162 58.919,-173.708 58.794,-173.488 58.759,-173.131 58.714,-172.943 58.702,-172.651 58.66,-172.398 58.62,-172.277 58.519,-172.163 58.339,-172.177 58.176,-172.119 58.011,-171.964 57.862,-171.835 57.837,-171.642 57.887,-171.6 58.014,-171.576 58.1,-171.528 58.192,-171.435 58.265,-171.338 58.272,-171.223 58.171,-171.088 58.06,-170.941 57.975,-170.674 57.906,-170.322 57.883,-170.283 57.868,-170.134 57.838,-170.041 57.857,-169.895 57.885,-169.819 57.897,-169.648 57.911,-169.503 57.912,-169.447 57.907,-169.238 57.886,-169.015 57.982,-168.877 58.022,-168.713 58.013,-168.575 57.936,-168.448 57.853,-168.261 57.775,-168.019 57.693,-167.764 57.734,-167.635 57.838,-167.594 57.954,-167.5 58.094,-167.324 58.147,-167.134 58.264,-167.076 58.397,-167.023 58.484,-166.812 58.59,-166.654 58.692,-166.443 58.79,-166.289 58.876,-166.23 58.971,-166.294 59.092,-166.365 59.183,-166.336 59.324,-166.385 59.448,-166.417 59.558,-166.338 59.627,-166.187 59.667,-166.024 59.713,-165.749 59.812,-165.643 59.806,-165.564 59.776,-165.462 59.641,-165.487 59.577,-165.417 59.47,-165.336 59.388,-165.322 59.296,-165.528 59.237,-165.641 59.165,-165.482 59.069,-165.309 59.066,-165.219 59.002,-165.196 58.929,-165.173 58.855,-165.106 58.763,-165.123 58.671,-165.181 58.601,-165.145 58.525,-165.097 58.471,-165.087 58.344,-165.067 58.251,-165.074 58.135,-165.151 58.04,-165.268 57.998,-165.38 57.919,-165.41 57.857,-165.282 57.746,-165.152 57.786,-164.961 57.904,-164.811 58.07,-164.851 58.193,-164.769 58.296,-164.596 58.369,-164.407 58.471,-164.372 58.679,-164.352 58.869,-164.444 59.139,-164.575 59.28,-164.745 59.438,-164.846 59.57,-164.974 59.694,-165 59.792,-165.112 59.981,-165.212 60.121,-165.236 60.195,-165.119 60.207,-164.943 60.105,-164.694 59.952,-164.503 59.855,-164.364 59.752,-164.119 59.614,-163.776 59.516,-163.406 59.481,-163.181 59.518,-162.935 59.588,-162.741 59.673,-162.613 59.741,-162.453 59.843,-162.283 59.836,-162.123 59.762,-162.048 59.706,-161.988 59.664,-161.876 59.643)
And here is how it looks in Google Earth:
Inna
Hi Inna,
Thanks for your data and pictures, attached is a walkaround, would you please check it out, following is the result what we got:
Post11237Sample.txt (6.49 KB)
Hi Johnny,
Thank you for your help.
My situation is more complicated than that.
I’m using kml file to get the lines and also using Mercator projection, so the shapes are in meters.
Anyway, I tried to implement your logic into my code, but it does not work, how it supposed to – it cuts the line at 180.
Here is how I’m getting LineShape from kml file (in degrees) and later I’m using KmlStyle (based on Wiki samples). All the features in DrawCore are in meters.
Am I missing something?
foreach (KmlCore.Geometry.Point3D coord in lineString.coordinates)
    Vertex vertex = new Vertex(coord.X, coord.Y);
    lineShape1.Vertices.Add(vertex);
for (int i = 1; i < lineShape1.Vertices.Count; i++)
    if (lineShape1.Vertices[i].X - lineShape1.Vertices[i - 1].X > 180)
    { lineShape1.Vertices[i] = new Vertex(lineShape1.Vertices[i].X - 360, lineShape1.Vertices[i].Y); }
    else if (lineShape1.Vertices[i - 1].X - lineShape1.Vertices[i].X > 180)
    { lineShape1.Vertices[i] = new Vertex(lineShape1.Vertices[i].X + 360, lineShape1.Vertices[i].Y); }
lineFeatures.Add(new Feature(lineShape1, columnValues));
Thank you,
Inna
Hi Inna
Attached sample is using Mercator projection, would you please try it? Following is a result picture from our test:
Hope it helps
Post11237Sample_.txt (7.03 KB)
Hi Johnny,
  As there is a WrapDateline property, why don’t shapes have this workarround build in in the ThinkGeo’s draw core method?, I guess that everybody activating WrapDateline mode would want their shapes to be 180 border crossing, isn’t it?
Hi Johnny,
Carlos is right. When using WrapDateLine, all the shapes should work around 180 seamlessly, without adding any workarounds.
But anyway, the workaround works. Thanks.
Could you please explain what does  line.TranslateByOffset(-360, 0, GeographyUnit.Meter, DistanceUnit.Meter) mean? Is 360 supposed to be in degrees or in meters?
Inna
Hi Guys,
 I think you are correct, we will integrate this into products after the upcoming 7.0 release. For the method line.TranslateByOffset(-360, 0, GeographyUnit.Meter, DistanceUnit.Meter), the 360 is supposed to be in Meter, because the input unit is GeographyUnit.Meter, it means that we will make the vertexes of LineShape move to west by 360 meters.
I’ve encountered another problem with LineShapes.
If a line is crossing 180, canvas.DrawLine method is failing to draw line correctly.
In my test application (attached), it does not draw the portion of the line from 180 and west , when you zoom in or in a virtual world only, but in my production application it does not draw the line if you pan outside 180 (west extent is only visible).
I could not recreate production behavior, but maybe test application will give you a starting point.
Thank you for your help,
Inna
007_006_005_004_003_002_001_TestShapeFile.zip (16.3 KB)
Hi Inna
Thanks for your query, would you please set “overlay1.TileType = TileType.SingleTile;” attached is the amended sample, would you please try it, following is the result image for your information.
Best Regards
Summer
008_007_006_005_004_003_002_001_TestShapeFile.zip (10.8 KB)
Hi Summer,
I would like to set TileType.SingleTile, but unfortunately it creates other problems - please see ticket #7318.
Inna
Hi Inna,
Thanks for your information, please correct if I am wrong,  as the line is in overlay1 rather worldOverlay, so to set overlay1.tiletype should not affect worldoverlay rendering, in the following picture,
I set worldOverlay.TileType = TileType.SingleTile;  On worldOverlay there is a bug which is the same with what is discriped in the ticket .
then set Overlay1.TileType=TileType.SingleTile,       but On overlay1, the bug didn't show up, so I think to set overlay1.TileType=TileType.SingleTile should work.
Best Regards
Summer
Hi Summer,
Apparently SingleTile was already set in my production environment. When I set SingleTile mode in my test program line disappears when panning.
180 is inside current extent:
180 is outside of current extent (no line):
Inna
Hi Inna,
 Thanks for your further information, the problem has been recreated, would you please rplace "line.TranslateByOffset(-40067780.91867692, 0, GeographyUnit.Meter, DistanceUnit.Meter);" in "private static void HandleLine180Crossing()" in "CustomStyle.cs"
 with
 Now it should work.
 Hope it helps
 Summer
