"Load a MS SQL 2008 feature layer" example modification
In the Winforms Sample Application there is a sample called "Load a MS SQL 2008 feature layer".
Is it possible for ThinkGeo to only load part of the information (i.e. only some rows that meet a SQL select criteria) from a SQL Server table? Say for example, only load all states that start with the letter "I"?
I want to limit the amount of data that comes into the system right at the outset rather than filter off some of it later.
Dave
Sorry, managed to find it:
 sql2008LayerA.WhereClause = "WHERE ID <= 300000000"
 (which was just testing filtering out anything with ID more than 300000000)
David,
 Thanks for your posts and sharing.
 Yes, the WhereClause is a recently added new features, you are getting it into the right place.
