Load large ECW - InvalidOperation exception
I'm trying to load a very large ECW image - 680MB. It displays fine in Map Suite Explorer. I had problems with this image in version 2 but another even larger worked fine (in V2). I can send it to you if you have an ftp address.
Here is the exception. It is thrown when I call Refresh.
 System.InvalidOperationException was unhandled
  Message="This method will return too many cells that might cause performance problem. Please using GetIntersectingRowColumnRange method instead."
  Source="MapSuiteCore"
  StackTrace:
       at ThinkGeo.MapSuite.Core.Matrix.GetIntersectingCells(RectangleShape worldExtent)
       at ThinkGeo.MapSuite.Core.BitmapTileCache.GetTiles(RectangleShape worldExtent)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.xf12dc5c7e687c240(Boolean x991dc8ddc7528b44, RectangleShape x178b193eec228e6e)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.x9ac8c50f434f4b39(Int32 xb565f4681f05557a)
       at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.Refresh()
       at HelloWorld.Form1.button1_Click(Object sender, EventArgs e) in C:\Source\HelloWorld\HelloWorld\Form1.cs:line 40
       at System.Windows.Forms.Control.OnClick(EventArgs e)
       at System.Windows.Forms.Button.OnClick(EventArgs e)
       at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
       at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.ButtonBase.WndProc(Message& m)
       at System.Windows.Forms.Button.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
       at System.Windows.Forms.Application.Run(Form mainForm)
       at HelloWorld.Program.Main() in C:\Source\HelloWorld\HelloWorld\Program.cs:line 18
       at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
  InnerException:
Here is the code:
string imgPath = @"c:\images\Mildura_photos2006.ecw";
EcwRasterLayer ecwImageLayer = new EcwRasterLayer(imgPath);
ecwImageLayer.Open();
winformsMap1.CurrentExtent = ecwImageLayer.GetBoundingBox();
ecwImageLayer.UpperThreshold = double.MaxValue;
ecwImageLayer.LowerThreshold = 0;
LayerOverlay imageOverlay = new LayerOverlay();
imageOverlay.Layers.Add("EcwImageLayer", ecwImageLayer);
winformsMap1.Overlays.Add(imageOverlay);
winformsMap1.Refresh();
Any ideas?
Cheers
Steve
Fixed by changing units from DecimalDegree to Meter.
Steve,
 That is right, that would be the problem!
 Thanks for your post and sharing!
