Load the map which is in your shape file when the page is loaded
I have shape file for the map of Pakistan and it is getting displayed with some other information which I am loading from my SQL Server database. I want to display the Map of Pakistan when the Page is loaded, but it is coming on the right side and I have to drag it to view. I think by using currentExtent property we can setup, but I have tried different options not able to do so. I need help to sort this.
Hi Naeem,
 I don’t think that’s related with your loading from SQL server.
 If possible please upload a sample which can reproduced that.
 If you don’t want to upload a sample please do something as below:
 Test 1. Disable loading SQL server related code and test whether the issue still there. If the issue still there, go test 2. If the issue won’t happen, we still need your sample project.
 Test 2. Put your code into any sample in our HowDoISamples project, and use our data in the project instead of your Pakistan data. Then test whether it solved. If it still can be reproduced, please just sent us your test code. If it cannot be reproduced by our data, you should want to sent us your Pakistan data also.
Thanks Don for your reply.
Following is my code, I want to show Map of Pakistan on screen when the page is loaded. currently I have to drag it from right side.
map = New Map(“Map1”, New System.Web.UI.WebControls.Unit(100, System.Web.UI.WebControls.UnitType.Percentage), 510)
                map.CurrentExtent = New RectangleShape(-1.4575022977941, 41.96396484375, -1.2297679227941, 30.36240234375)
                map.MapUnit = GeographyUnit.DecimalDegree
                usStatesLayer = GetCustomDataShapeFileFeatureLayer()
                Dim TextLayer As New ShapeFileFeatureLayer(Server.MapPath("~/Content/Shapes/PAK_adm1.shp"))
                TextLayer.RequireIndex = False
                TextLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.City1
                TextLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.City1("[Abbr]")
                TextLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
                'Dim TextOverlay As New LayerOverlay()
                'TextOverlay.Layers.Add(“Names”, TextLayer)
                'TextOverlay.IsBaseOverlay = True
                Dim staticOverlay As New LayerOverlay()
                staticOverlay.Layers.Add(“Names”, TextLayer)
                staticOverlay.Layers.Add(“Cities”, usStatesLayer)
                staticOverlay.IsBaseOverlay = False
                map.AdornmentOverlay.Layers.Add(BuildLegend())
                map.CustomOverlays.Add(staticOverlay)
Thanks Don,
I am able to figure it out.
Naeem,
Great to hear you figure it out. Please let us know if any questions.
