I am trying to use the loadingiimage, but the image is off the map to the left side. I can not get this aligned properly. How do I get the loading image to be centered on the map, or at least on the map?
Loading image alignment
David,
Can you refer to the “ChangeLoadingImage” sample in our installed samples and you can find its source code at “Samples\GetStarted\ChangeLoadingImage.aspx”.
I don’t know how to use it. If you still have any problems about it, please provide us the necessary information about how you set it or the scenario of yours.
Khalil
