I would like to show the loading maptools image on partial postbacks. How can I do this?
David,
It will be easier if you use MS Ajax Extensions, the loading image can be installed “sample folder\theme\default\img\ loading.gif”, and the code is like below:
<asp:UpdatePanel ID="UpdatePanel1" runat="server">
<ContentTemplate>
<cc1:Map ID="Map1" runat="server" Width="100%" Height="100%">
cc1:Map>
// some custome controls…
ContentTemplate>
asp:UpdatePanel>
<asp:UpdateProgress ID="UpdateProgress1" runat="server">
<ProgressTemplate>
<img alt="loading image" src="loading.gif" />
ProgressTemplate>
asp:UpdateProgress>
I’m not sure if I understood you clearly, otherwise, could give us some details about what you want?
Everyone,
If you have the same question about this problem, please come with this link:
gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/12/aft/9337/afv/topic/Default.aspx#27066
