I have two shape files one for state and one for cities.On first load it should display states and when i zoomin it should display the cities.The below code displays only state even if i zoom in.Can somebody advice how to achieve this.Expected outputs are attached.
protectedvoidPage_Load(objectsender, EventArgs e){
Map1.MapBackground.BackgroundBrush =newGeoSolidBrush(GeoColor.FromHtml("#E5E3DF"));Map1.CurrentExtent =newRectangleShape(-125, 72, 50, -46);Map1.MapUnit = GeographyUnit.Meter;LayerOverlay staticOverlay =newLayerOverlay("WorldStaticOverlay");ShapeFileFeatureLayer worldLayer =newShapeFileFeatureLayer("C:\\Work\\Maps\\States.shp");worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.SimpleColors.Transparent, GeoColor.FromArgb(100, GeoColor.SimpleColors.DarkRed));worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level05;staticOverlay.Layers.Add("worldLayer", worldLayer);
ShapeFileFeatureLayer worldLayer1 =newShapeFileFeatureLayer("C:\\Work\\Maps\\Cities.shp");worldLayer1.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.SimpleColors.Transparent, GeoColor.FromArgb(100, GeoColor.SimpleColors.Green));worldLayer1.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;LayerOverlay staticOverlay1 =newLayerOverlay();staticOverlay1.Layers.Add(worldLayer1);Map1.CustomOverlays.Add(staticOverlay);Map1.CustomOverlays.Add(staticOverlay1);}
Loading state and city shape files together to display cities when zoom in
Hi Ugendran,
The cities don’t display is because the layer is a point layer but you are using the AreaStyle for this layer rather than the point style. Here are some guidance on those styles:
Examples of styles include…
- AreaStyle - Designed to render areas such as polygons, ellipses and rectangles.
- LineStyle - Renders lines and multilines.
- PointStyle - Draws points on the map using various symbols.
- TextStyle - Labels features on the map.
- ClassBreakStyle - Used to render feature groups differently based on their data values, ie. 0-100 Red, 100-200 Blue.
- ValueStyle - Renders features differntly based on absolute values in their data, ie. MiddleSchool = Red, HighSchool=Blue.
So, in order to display the point style, we should some codes like the below:
ShapeFileFeatureLayer worldLayer1 = new ShapeFileFeatureLayer(“C:\Work\Maps\Cities.shp”);worldLayer1.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.City1;worldLayer1.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
Hope it helps.
